CSullivan6
Good Afternoon, This might be an oddball question, but I haven't really gotten a clear answer in researching so I thought I would ask here.
Process background: My corrective action system is part of a larger MS Access database and the entire database is revision controlled and changes well documented. This database is internal only, the supplier cannot log in and fill out things. So, if I issue a supplier CA, I fill out basic information and export the info into an MS Excel workbook template. The supplier fills out restricted cells with the required information and returns it to me with supporting evidence. Once I review and approve the workbook, I then import into the Access database.
The workbook contains various worksheets, including 8D, fishbone, and 5why.
The question is more geared to those that use an online corrective action system such as ETQ, Reliance, etc, and or a database I suppose. If the workbook is an integral part of the database process, does the workbook and or each worksheet in the workbook template require a form ID and revision number? Keep in mind, this is an output of the database and revisions to all parts of the database are controlled and documented. When a change is made, the entire database is up revved. The functionality of the export and import processes is dependent on the workbook remaining unchanged. Is the workbook considered a part of the database application or its own form?
Second question if the answer to the above question is yes: If I create and format a workbook on the fly... meaning I code it all into the database application, and document changes to the workbook the same manner, do I still need a form number?
Third question: if the answer to the first question is no. Can I identify the workbook noting if is a "part of the Quality DB?" I think it needs something to note it is controlled in the database.
I am probably WAY overthinking this, but the workbook template is NOT available in our standard forms library. It is only available through the application.
Opinions and past experiences are certainly welcome.
