Document Index
contigo123
We are a medical device company following ISO 13485 and currently maintain our documents on paper (active and obsolete versions). We also keep a master index at the front of the filing cabinet that lists the document names, revision numbers, and revision dates. This index gets updated whenever an SOP is revised. My question is: do we need to keep old versions of the master index? Other than a nice to have snapshot of what document revisions were in place on a given day, is there a requirement to keep the obsolete index?
Thank you
Is the index value added for your organization? There is no requirement in ISO 13485 that you keep a separate index with revision numbers and revision dates. The documents themselves show the revision and date (or reference to change order), correct? Do you also have a change order log and/or a training matrix that shows the same information?
If you have an SOP that that specifically calls out the index record, then yes, you should keep those records. But again, I'm not sure what this index does for you. How do you use it?
contigo123
Thanks, the index just helps when we have audits, etc, so that we can show a list of current procedures. Your suggestion that maybe we don't need the revision numbers/dates is valid, perhaps we remove those and then just keep the list of documents. And our SOP just says that an index is created, but no indication of retention. I think we can probably do away with the old rev's...
Thee Bouyyy
Multiple Personalities
Thank you
There aren't any criteria for this. I recommend that you simply keep track of the most recent ones. It will assist you in recognising SOP overviews. There is no need to keep track of the obsolete one since it would cause confusion.
Also, if you haven't written about it in your SOP, I recommend that you don't generate unnecessary papers if they won't provide any value to your organisation.
pbojsen
Hi. Actual Doc Control person here. Have done this for MANY years.
1. The Master Document Register is usually maintained in an Excel spreadsheet, password protected, that anyone can view, but only Doc Control can revise. Doctypes are kept on different tabs by doc number.
2. While it is not a requirement to have a Master Document Register, how are you going to know what documents are controlled and which are not without one? Controlled documents should be in the MDR, and nothing else.
3. The Master Document Register itself is not a revision controlled document, it is a living document that has access controlled. Our group updates it every day so change control on it would be burdensome.
4. 13485 requires that you keep Obsolete copies. 4.2.4 Control of documents, last paragraph of the standard "The organization shall define the period for which at least one copy of obsolete documents shall be retained. . . . . at least the lifetime of the medical device as defined by the organization, but not less than the retention period of any resulting record, or as specified by applicable regulatory requirements."
5. When auditors as for the MDR, we go into the spreadsheet to the QMS SOPs, filter to the active SOPs (no Obsoletes, no Drafts) and give them the doc number, revision, Title, date released, and change order number, all of which is in the Master Document Register
Hope this helps.
U Document Revisions Required in DMR Index? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 10
D DMR (Device Master Record) Index as a Controlled Document 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 7
C Document Record/Template Minimum Requirements ISO 13485:2016 - Medical Device Quality Management Systems 0
E Do anyone have document of automotive production risk and control of risk? Lean in Manufacturing and Service Industries 1
Q Document representation ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
J Document Control of Online Management Software ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
W Document control Document Control Systems, Procedures, Forms and Templates 10
D Increasing efficiency - Capt. Proj. Document Review Matrix Document Control Systems, Procedures, Forms and Templates 4
A ISO 9001:2015 8.5.6 and 7.5.3 Document Control Questions ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
qualprod Sheets into a spreadsheet document control ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
J Document Changes that don't have to be approved Document Control Systems, Procedures, Forms and Templates 11
D Electronic Document Management System ISO 13485:2016 - Medical Device Quality Management Systems 16
M Document Control - Applying Suitable Identification to Obsolete Documents ISO 13485:2016 - Medical Device Quality Management Systems 5
D Document Control Question involving DocuSign US Food and Drug Administration (FDA) 6
M Document Control ISO and FDA ISO 13485:2016 - Medical Device Quality Management Systems 7
D Document Change Approval ISO 13485:2016 - Medical Device Quality Management Systems 6
R Does anyone use iQMS for their ISO based document control? Manufacturing and Related Processes 1
C Document Identification Question ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
B Document retention Policy for Japan's PMDA Japan Medical Device Regulations 1
B Document Retention Policy for NMPA China Medical Device Regulations 1
B Document Retention period for MHRA submission UK Medical Device Regulations 0
A If document coding is change will there be a revision Document Control Systems, Procedures, Forms and Templates 1
S Document numbering question? ISO 13485:2016 - Medical Device Quality Management Systems 7
R Quality policy review document IATF 16949 - Automotive Quality Systems Standard 3
dpenbert AS9100 7.5.3 - Manual Document Control AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 6
S Software design document NMPA guidance and consultant China Medical Device Regulations 4
qualprod Is it worth to document all the processes? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
S Help in document control procedure Document Control Systems, Procedures, Forms and Templates 14
P Which MDCG Document should I use for PMS Plan and PSUR? EU Medical Device Regulations 2
N API Q1, Management of Change & Document Change Request Oil and Gas Industry Standards and Regulations 4
J Project management Document. IATF 16949 - Automotive Quality Systems Standard 4
S Master Document Register Document Control Systems, Procedures, Forms and Templates 3
M Preparing a document for Raw Material of Medical Device EU Medical Device Regulations 1
R Regulations on Controlled Document Size (Paper Size) Document Control Systems, Procedures, Forms and Templates 4
M Document Architecture ISO 13485:2016 - Medical Device Quality Management Systems 8
cgaro62 Using internal audits as part of document reviews Document Control Systems, Procedures, Forms and Templates 21
J Training on the importance of Document Control Document Control Systems, Procedures, Forms and Templates 3
Ed Panek External Standards List - Should this document include previously revised standards? ISO 13485:2016 - Medical Device Quality Management Systems 4
H Document retention period Canada Medical Device Regulations 2
S Document Notes ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
M ISO 13485 and document control for programs ISO 13485:2016 - Medical Device Quality Management Systems 6
Ed Panek MR Mandate Document EU Medical Device Regulations 1
K ASME, ANSI, ASTM and similar specifications and their requirements for document control. Inspection, Prints (Drawings), Testing, Sampling and Related Topics 8
H If we use agile - do we still need to document TF as a waterfall just for the notified bodies need? IEC 62304 - Medical Device Software Life Cycle Processes 2
Q ISO 9001/IATF 16949 Audit Finding Question - Document Retention IATF 16949 - Automotive Quality Systems Standard 11
B Document Issued with incorrect Document number code Document Control Systems, Procedures, Forms and Templates 3
J Requirement for Signature on Document Document Control Systems, Procedures, Forms and Templates 13
A Document Review and Document Approval --- 2 Signatures needed acc. §820.40? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 6
Sidney Vianna Interesting Discussion Should ISO 9004 be changed from a guidance document to a requirements standard? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 13
