Document levels and approval requirements for lower level documents like work instructions, forms etc.
ISO_Man
I'm looking at a current document control system (manual) and the higher level documents (SOPs) all require approval, but as I go into the lower level documents like work instructions, forms etc. I see that do they don't have approvals for those individual documents. Is this normal?
CCaantley
I was told by the company that helped us update to 9001:2015 that anything that gives instructions needs to be a controlled document... signature and date at least.
Ninja
Looking for Reality
Note that "Controlled" and "Approved" are different things.
How are you 'lower level' documents "controlled" ?
Everyone can make it however they want...isn't "controlled"... Having only one source to get it, and controlling that source (even without a singoff) may be control.
That said, the vast majority I've seen show an approval signature...
dubrizo
I would suggest that you do what's right with respect to the business (risk tolerance). What I mean by that is to evaluate risk/opportunity with document reviewers and signers. I.E. is the document a plan vs. a record. The plan/protocol should probably be reviewed/signed by more individuals (consider R&D, Cognizant Review, Quality, Regulatory, etc.) than the subsequent record of the protocol being run.
ISO_Man
___
All of our documents are controlled. Still working with some former professional auditor friends to figure this one out.
Al Rosen
I don't know what standard you are addressing, but according to ISO 9001:2015
9001:2015 said:
7.5.1 General
The organization’s quality management system shall include:
a) documented information required by this International Standard;
b) documented information determined by the organization as being necessary for the effectiveness
of the quality management system.
7.5.2 Creating and updating
When creating and updating documented information, the organization shall ensure appropriate:
a) identification and description (e.g. a title, date, author, or reference number);
b) format (e.g. language, software version, graphics) and media (e.g. paper, electronic);
c) review and approval for suitability and adequacy
So you determined that the WIs & forms are necessary otherwise why have them? They need to be approved.
skb76
hi!
Just give opinion
even it is low level document/form
(for first time when the form/document been created ~ approved/sign ~ group them to Master List)
~ Until the format of the forms been 'modify/revise'
(#based on my experience, WI cant actually consider as low-level document, the Auditor will look into it (moreover with the 7.1.6clause)
RoxaneB
I was just passing on what I was told. If it is wrong, I have a lot of work to do to fix everything.
No, you don't need to FIX everything. But a document with a signature and a date doesn't necessarily make it controlled. Your company probably has more to its document control process than just those two items. Before trying to fix a process, best to determine if it is indeed broken.
A Confused about Document Levels and Quality Manual ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
D Skipping Document Revision Levels Document Control Systems, Procedures, Forms and Templates 20
W Controlled Documents - Trying to differentiate document control levels Document Control Systems, Procedures, Forms and Templates 5
A Classifying Documents for Different Document Levels ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
M Definition Document Levels - Definition of what Level 1, 2, 3 documents are Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 4
A Document Review and Document Approval --- 2 Signatures needed acc. §820.40? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 3
K 25-year lifetime of medical device - document storage period EU Medical Device Regulations 1
J UDI - Where to document it? EU Medical Device Regulations 8
S Changing revision status of a reviewed document Manufacturing and Related Processes 4
shimonv Document Control Procedure Header Content Document Control Systems, Procedures, Forms and Templates 3
Q Document ownerships Document Control Systems, Procedures, Forms and Templates 14
E Document Change Request forms (or no forms)? ISO 13485:2016 - Medical Device Quality Management Systems 9
O Any info on release date of FDA “Computer Software Assurance for Manufacturing and Quality System Software” document? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 0
B Document Approval Matrix Benchmarking Document Control Systems, Procedures, Forms and Templates 3
J Document Approval Signature Order Document Control Systems, Procedures, Forms and Templates 10
M What is the proper way to document measurements Measurement Uncertainty (MU) 1
P Equipment 21 CFR 820.70(g) - User Requirements Document for Off the shelf equipment 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 7
B Do IFU designs have to be document controlled under ISO 13485? Document Control Systems, Procedures, Forms and Templates 2
C Certificate of Conformance Form - COC for each customer a controlled document? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
A Document "Correspondence IATF 16949 vs ISO13485" available? IATF 16949 - Automotive Quality Systems Standard 0
R Document Retention - Discard hard-copies after scanning? ISO 13485:2016 - Medical Device Quality Management Systems 2
P Mylar plot suppliers in accordance with D6-51991 document AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
A Document Change Notice vs complete System re-write Manufacturing and Related Processes 4
Q Document approval through SharePoint (without signature) Records and Data - Quality, Legal and Other Evidence 4
S What is considered a "core algorithm"? (From an FDA guidance document) Medical Information Technology, Medical Software and Health Informatics 4
U Document Approval - Software company ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
O Please, help with document on ISO/ TS 17758 and (IDF 87: 1979). Thank you. Manufacturing and Related Processes 1
I Nitpicking on document released dates ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
I Document Control on Log Files ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
Q Refusal to Document Complaints Customer Complaints 39
Q Tracking Procedure Revisions (Document Control) Document Control Systems, Procedures, Forms and Templates 9
I Can a document (form) approval record be separate? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
T Advice needed - Environmental MS - unwritten but customer requests policy document ISO 14001:2015 Specific Discussions 5
T Control of downloaded document copies by employees Document Control Systems, Procedures, Forms and Templates 3
T Document control ISO 13485:2016 ISO 13485:2016 - Medical Device Quality Management Systems 5
I Is highlighting on a printed document considered a change? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
C QMS Document Management Software Recommendations Quality Assurance and Compliance Software Tools and Solutions 14
E Part 11 Compliance, Excel living documents (i.e. document master list, equipment list, approved supplier list) Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 3
Sidney Vianna Informational New IAQG Document - AS9100 Clarifications of Intent AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
S How to determine & document Organizational Knowledge of a company Document Control Systems, Procedures, Forms and Templates 4
D Are medical device companies required to document every change made to their website? Document Control Systems, Procedures, Forms and Templates 2
