Document Management System - Revisions & Out of Date Documents
1. What happens when a document undergoes the revision process? Is the original document kept online until the revised document replaces it or does the original document get pulled until the revisions are complete (and thereby leaving users with no document to reference).
2. What happens when a document goes past designated review time frame (annually, every 3 years, or whatever)? Does it remain online for viewing by all?
John Broomfield
You could mark the obsolescent document “about to be updated - see <name of process owner>“.
And you could mark the document overdue its review likewise “review is overdue - see <name of process owner>“.
insect warfare
QA=Question Authority
1. Typically, in most situations the latest revision of a system document is kept public, until new changes are drafted, reviewed and approved by relevant authorities in the organization. Assuming your document control process is solid, the quicker this happens the better. For additional clarification, you should also refer to your organization's requirements and (if applicable) whatever your industry's (ISO/AS/TS) requirements mandate.
2. In cases like these I would recommend starting the review process for those documents well before the expiration date. During the review keep the current versions public (and somehow denote that they are undergoing a review) until your organization confirms that they are OK, require changes or needs archived. Pulling a document from online viewing prior to a review may result in double work (if your organization determines there are no changes needed to that document and you end up having to re-publish the very same document).
In both situations time is of the essence, so as long as you go about doing things without undue delay you should be fine.
Brian :rolleyes:
John Broomfield
Yes, we must stop inadvertent use of obsolete docs so they’d be kept in a separate archive. Such docs are still available with planned retrieval.
Kronos147
If you don't keep the last revision (preferable offline in a controlled manner), how do you revert back if the new practice is not as good as what you had (i.e. control of changes)?
How do you assess the effectiveness of the change?
How do you do root cause analysis to see if the change cause the problem if you don't keep the history?
And finally, does the practice of getting rid of documents meet your own internal policy of retention (as per 7.5)?
If you use a document change notice of some kind - with details of the actual change - you won't need to keep the document as a history. Just as with engineering drawings, if the correct level of detail is included, a change notice should be sufficient to track wuch things.
I think that you are confusing "documents" and the need to maintain and retain... You may wish to check your understanding. Having worked for some period in a design engineering function, I can confidently state, they didn't keep the actual previous drawings (pre CAD) for all revisions, but they did file all related ECNs. It's the same practice as makes good document control for a QMS.
R ISO13485/ISO9001 Convenient Document Management System Document Control Systems, Procedures, Forms and Templates 3
alonFAI Document Numbering System For ISO/Quality Management Document vs. All Other Documents Document Control Systems, Procedures, Forms and Templates 44
R Quality Management System Template (Quality Management Procedure document) Document Control Systems, Procedures, Forms and Templates 8
Q Evidence of Approval in an Electronic Document Management System ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
J Qumas as an EDM (Electronic Document Management System) Quality Manager and Management Related Issues 2
G ISO 17025 definitions - Requirements for document management system ISO 17025 related Discussions 5
S Customized EDMS (Electronic Document Management System or ADMS) Document Control Systems, Procedures, Forms and Templates 4
M What is the best Electronic Document Control Management System? Document Control Systems, Procedures, Forms and Templates 46
D Document Control Management System (MyDMS) & Revision Time Frames Document Control Systems, Procedures, Forms and Templates 3
T Training on SOPs through our Electronic Document Management System ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
P Fw: Management System document compiling method? IATF 16949 - Automotive Quality Systems Standard 2
C QMS Document Management Software Recommendations Quality Assurance and Compliance Software Tools and Solutions 15
M Informational Health Canada – Notice: Revisions to the Guidance Document: Management of Applications for Medical Device Licences Medical Device and FDA Regulations and Standards News 0
D Risk management according to ISO 14971 - When to document risk controls? ISO 14971 - Medical Device Risk Management 10
D AS9100 Document Management (Advice Needed) AS9100, IAQG 9100, Nadcap and related Aerospace Standards and Requirements 4
L Moving from ProArc to IFS Document Management Document Control Systems, Procedures, Forms and Templates 1
M Document Control Management - External documents flowed down from customers Document Control Systems, Procedures, Forms and Templates 2
R Document Management Software : Validation and other requirements Medical Information Technology, Medical Software and Health Informatics 8
R How to document the Risk Management on Rework activities ? ISO 14971 - Medical Device Risk Management 6
C Document Management Solution for Routing Documents for Approval Manually Document Control Systems, Procedures, Forms and Templates 18
drgnrider Job descriptions (4.4.1): Management Rep, Document Author, Document Approver Miscellaneous Environmental Standards and EMS Related Discussions 13
Q Method of Document Management (Control) in Engineering - Please Review ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
E Implementing Risk Management - Required Document Types ISO 14971 - Medical Device Risk Management 8
M Document Control (with Revisions Control) Management Database Document Control Systems, Procedures, Forms and Templates 4
3 Document Control & Storage - Project Management Organization and Implementation ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
L Data Management and Web based Document Control Software Document Control Systems, Procedures, Forms and Templates 18
M Document for the management of employee activity - Suggest? Document Control Systems, Procedures, Forms and Templates 3
S Special 510k for Data Management Software Document Requirements IEC 62304 - Medical Device Software Life Cycle Processes 1
C Can an MR (Management Representative) be a Document Controller as well? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 12
A Management Review Process Document Management Review Meetings and related Processes 5
D Specifications - All the same type of document? Change Management part of our QMS Document Control Systems, Procedures, Forms and Templates 4
S DMS (Document Management Software) vs. Paper Copies - Cataloging all of our docs. Document Control Systems, Procedures, Forms and Templates 8
B Responsibilities for Record and Document Management, Development and Control ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 12
A 21 CFR part 11 compliant Electronic Document Management Systems Document Control Systems, Procedures, Forms and Templates 20
R Document Control and Agile Product Lifecycle Management software Document Control Systems, Procedures, Forms and Templates 4
D What companies do a great job at engineering document management systems and control? Document Control Systems, Procedures, Forms and Templates 3
C Combining Separate Document Management Systems Document Control Systems, Procedures, Forms and Templates 3
Z Document Control in a Construction Management Company Document Control Systems, Procedures, Forms and Templates 5
R Upgrading to TS 16949 - A Management Overview and Kickoff Document IATF 16949 - Automotive Quality Systems Standard 5
P Looking for a Closing Document Template/Sample (Project Management) Six Sigma 3
T Document Management Software for Personal Use Coffee Break and Water Cooler Discussions 4
A How to Document the Design & Development and Resource Management Process in IT Firm? Design and Development of Products and Processes 2
K Software suggestions for Document Management, Audits, and CAPAs? Quality Assurance and Compliance Software Tools and Solutions 10
U Document Management, Version Control & Document Storage Software Quality Assurance and Compliance Software Tools and Solutions 11
T Document management software - Legacy document approval history Document Control Systems, Procedures, Forms and Templates 3
Marc Document Management and Version Control Document Control Systems, Procedures, Forms and Templates 0
J Corporate Procedures and document management/control procedure IATF 16949 - Automotive Quality Systems Standard 6
B FDA Quality Plan - Document Management Responsibility, section 820.20 d 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 16
M Document Control and Configuration Management Book Document Control Systems, Procedures, Forms and Templates 15
P Responsibility and Document Management Requirements for Management Representative IATF 16949 - Automotive Quality Systems Standard 2
