Document Matrix - Can the Server Directory Listing(s) be used?
Marc
#12
Originally posted by Sam:
In our system we are still required to have the master list as required by QS9000.
Where does QS9000 require a master list?
QS9000 (Version 3)
4.5.2 – Document and Data Approval and Issue
The documents and data shall be reviewed and approved for adequacy by authorized personnel prior to issue. A master list or equivalent document control procedure identifying the current revision status of documents shall be established and be readily available to preclude the use of invalid and/or obsolete documents.
#13
At our military aircraft and component overhaul facility, we are setting our system to the ISO 9000:2000 requirements and are blending in the AS9100:1999 requirements. AS9000 has added two additional requirements to our 5.5.6 Control of Document system. They are
5.5.6(b) (i) Document change incorporation: the organization shall establish a process to ensure the timely review, distribution, implementation and maintenance of all authorized and released drawings, standards, specifications, planning, and changes. The organziation shall maintain a record of change incorporation and, when required, shall coordinate these incorporations with the customer and/or regulatory authority. (from AS9100:1999. para. 4.5.3).
5.5.6(h) When customer furnished digital data is used for design, production and/or inspection, the Depot shall establish system controls in accordance with customer requirements. (from AS9100:1999. para. 4.5.3).
While we know that a "Master Document List" is NOT an ISO or AS requirement, the standard basically requires that documents be controlled and retrievable. We have chosen to use an on-line approach that just happens to appear as a list of documents that the users can click and open. People, by nature, like lists. The added plus with our on-line DCS system is that you can do a "keyword" search to help you sort things out.
Also, as we proceed down the document pyramid to the actual work documents, the level of control (open loop vs. closed loop) increases.
Andy Bassett
#14
OK folks. So i guess for my EDP documents i dont need a matrix or a master list. I can point at the Server and describe how it is managed in a controlled manner to ensure that the latest documents are available.
But what about drawings from the customer. The company in question (small electronics assembler) has a good system with a SINGLE file for each product and a golden rule that when a new document is inserted the old one is MARKED and stored in the obsolete section. If you want the latest issue document you look in these files.
There is no single matrix/master list that you can look into which instantly tells you what the latest status is.
Can i get away with this?.
Can i use the same technique for other documents such as Standards/Parts Specifications/Supplier catalogues etc.?
Living in hope
Andy B
B Document Approval Matrix Benchmarking Document Control Systems, Procedures, Forms and Templates 3
R Training Matrix for Document revisions ISO 13485:2016 - Medical Device Quality Management Systems 4
C Document Numbering Matrix showing how to number all documents by type Document Control Systems, Procedures, Forms and Templates 2
Uriel Alejandro Problems with the Employee Skills Matrix - Document Control System Quality Manager and Management Related Issues 8
A Document Relationship Matrix - Keeping Track of References to Related Documents ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
P Document and Records Matrix example wanted Document Control Systems, Procedures, Forms and Templates 3
B Document and Record Matrix - A controlled document? Document Control Systems, Procedures, Forms and Templates 10
S Document Approval Matrix - What manager needs to sign what documents Document Control Systems, Procedures, Forms and Templates 11
L Must All Documents be on a Document Matrix including Each Job Description? Document Control Systems, Procedures, Forms and Templates 32
M Document Control Matrix - Will it ever be used? Document Control Systems, Procedures, Forms and Templates 11
A Document Review and Document Approval --- 2 Signatures needed acc. §820.40? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 3
K 25-year lifetime of medical device - document storage period EU Medical Device Regulations 1
J UDI - Where to document it? EU Medical Device Regulations 8
S Changing revision status of a reviewed document Manufacturing and Related Processes 4
shimonv Document Control Procedure Header Content Document Control Systems, Procedures, Forms and Templates 3
Q Document ownerships Document Control Systems, Procedures, Forms and Templates 14
E Document Change Request forms (or no forms)? ISO 13485:2016 - Medical Device Quality Management Systems 9
O Any info on release date of FDA “Computer Software Assurance for Manufacturing and Quality System Software” document? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 0
J Document Approval Signature Order Document Control Systems, Procedures, Forms and Templates 10
M What is the proper way to document measurements Measurement Uncertainty (MU) 1
P Equipment 21 CFR 820.70(g) - User Requirements Document for Off the shelf equipment 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 7
B Do IFU designs have to be document controlled under ISO 13485? Document Control Systems, Procedures, Forms and Templates 2
C Certificate of Conformance Form - COC for each customer a controlled document? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
A Document "Correspondence IATF 16949 vs ISO13485" available? IATF 16949 - Automotive Quality Systems Standard 0
R Document Retention - Discard hard-copies after scanning? ISO 13485:2016 - Medical Device Quality Management Systems 2
P Mylar plot suppliers in accordance with D6-51991 document AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
A Document Change Notice vs complete System re-write Manufacturing and Related Processes 4
Q Document approval through SharePoint (without signature) Records and Data - Quality, Legal and Other Evidence 4
S What is considered a "core algorithm"? (From an FDA guidance document) Medical Information Technology, Medical Software and Health Informatics 4
U Document Approval - Software company ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
O Please, help with document on ISO/ TS 17758 and (IDF 87: 1979). Thank you. Manufacturing and Related Processes 1
I Nitpicking on document released dates ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
I Document Control on Log Files ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
Q Refusal to Document Complaints Customer Complaints 39
Q Tracking Procedure Revisions (Document Control) Document Control Systems, Procedures, Forms and Templates 9
I Can a document (form) approval record be separate? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
T Advice needed - Environmental MS - unwritten but customer requests policy document ISO 14001:2015 Specific Discussions 5
T Control of downloaded document copies by employees Document Control Systems, Procedures, Forms and Templates 3
T Document control ISO 13485:2016 ISO 13485:2016 - Medical Device Quality Management Systems 5
I Is highlighting on a printed document considered a change? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
C QMS Document Management Software Recommendations Quality Assurance and Compliance Software Tools and Solutions 14
