Document Numbering and Identification Systems Advice wanted
Seirpin
Hi quick background, I am new to ISO 9000 the company I work for is creating a QMS and striving for ISO 9000. I took over someone else’s work and that person is no longer with the company.
My question is about the numbering system he set up. It is kind of complicated, it consists of 3 parts. First a alphabet code for what type of document it is, meaning “WI” for work instruction, “F” for form, “AP” for administrative procedure, and so on. Second a 3 digit code that relates to what section in the quality manual the document falls under, example 622 for work instructions because 622 is the section on “competence, awareness and training”. And the third part is just a sequential number given to differentiate documents that fall under the same section of the quality manual. The last part is further broken down as to state what area is being referred too. Example 0001-9999 is the BR line 2000-2999 is the PECVD line, and so on.
So does this sound like a good setup? Is it normal to reference the section of the quality manual that the document falls under?
Thanks,
Matt
Duke Okes
I've seen companies do this and I've also seen them not even have numbers for their documents ... just names. It's really up to you. However, usually simpler is better.
Marc
<snip> Is it normal to reference the section of the quality manual that the document falls under? <snip>
Nothing is "normal". There are many different ways companies do documentation. The document prefixes you note are quite common.
Question:
Do you mean is it 'normal' to reference a section of the quality manual within a procedure or other system document?
If you mean the second part of the number being a reference to the quality manual, then NO, that is not commonly done. I've never hear of that method, but I can see the reasoning behind it. Since this is about ISO 9001 which I think it will be stable with respect to clause numbering for the foreseeable future, I don't see it as a particular problem.
harry
If you are interested, there are a few threads on the same topic in the 'Similar Discussion Threads' box below (just scroll down the page).
Thanks,
Matt
Matt - welcome. It seems to me that you've answered your own question! "It is kind of complicated" is a very fair comment, given what you've described. Since you've inherited it, perhaps you're in a great place to simplify it. As guided by others, this topic is well covered here, so good luck - FWIW - 'K.I.S.S' is always best!
Chance
FWIW - 'K.I.S.S what is the meaning of this? Sorry I really dont know.
CaseyAnn
I find number codes and ranges in document numbers very confusing. They are not easily identifiable at a first glance and more often than not you would need to refer to a separate document to decode the numbers.
Acronyms in document numbers are always a tough one. Acronyms anywhere are tough! Especially for the uninitiated. But they are much more easily identifiable than number ranges.
We use an document numbering system for our key business documentation and project documentation that consists of four parts - 3x three letter acronyms (organisation, function, doc type) and a unique number - but we have very definitive acronym creation rules that ensure that there is: 1. no duplication 2. consistency and 3. control.
We also maintain an online Acronym Dictionary that all of our employees have access to and can update. All new entries are reviewed and approved prior to publication in the dictionary and anything that is not in the dictionary is an unaccepted acronym. It can be difficult to police, but if the communication and education is right, people will be compliant (just like pantene - it won't happen overnight, but it will happen!!) - partly because everyone understands the pain of not understanding a document that is littered with acronyms! But acronyms are a whole other discussion!!! *LOL* :topic:
Back to document numbering... Our document identifiers not only provide key documentation with a unique ID (to help with maintaining a fully transparent audit trail and document history) but they also assist with information classification.
e.g.
LPG-HSE-PRO-0001
LPG = business unit identification (LP gas)
HSE = functional area (health, safety & environment)
PRO = document type (procedure)
0001 = unique identifier
GEN-ENG-GUI-0012
GEN = business unit identification (Generation)
ENG = functional area (engineering)
GUI = document type (guide)
0012 = unique identifier
Our electronic key doc files are not only identified by the number, but they also have file names which help those out there who really don't care about document numbering!! <document number> - <document title>
I've seen all kinds of document numbering systems and have failed to see the logic - for the user - in them! Surely, if a form is entitled 'Non-Conformance Report' it doesn't matter what number it is - everyone knows it by its name? Perhaps someone might need to know what requirement of ISO it relates to, but as for building that ref. into the numbering system, heaven forbid...
K Document Numbering (Identification) System Document Control Systems, Procedures, Forms and Templates 10
S Document Numbering and Identification Methods ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 21
G Requirement for Form Numbering (Document Identification) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
N Unique Document Identification Numbering System Document Control Systems, Procedures, Forms and Templates 69
D Documentation System Document Numbering and Identification Document Control Systems, Procedures, Forms and Templates 4
J Document Numbering (Identification) Scheme Document Control Systems, Procedures, Forms and Templates 17
T Document numbering - What is your favorite identification scheme? Document Control Systems, Procedures, Forms and Templates 31
D Organization Chart Document Numbering ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
dubrizo Restructuring Document Control Numbering System Document Control Systems, Procedures, Forms and Templates 3
C Document Numbering Matrix showing how to number all documents by type Document Control Systems, Procedures, Forms and Templates 2
alonFAI Document Numbering System For ISO/Quality Management Document vs. All Other Documents Document Control Systems, Procedures, Forms and Templates 44
C Document Numbering and Hierarchy Requirements for ISO 13485 Document Control Systems, Procedures, Forms and Templates 3
D Include as an attachment or make a separate document? Advise on Document Numbering Document Control Systems, Procedures, Forms and Templates 1
K Document Revision Numbering and Related Requirements Document Control Systems, Procedures, Forms and Templates 12
D Multiple Format Document and Part Numbering Systems ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
V Document Numbering Systems Question Document Control Systems, Procedures, Forms and Templates 5
T Performance Document vs. Project Document Numbering Convention Document Control Systems, Procedures, Forms and Templates 4
J Large Projects, large number of partners? Document Numbering/Identifying Issues Benchmarking 6
S Correct Document Control - Does each Document need its own Unique Numbering? Document Control Systems, Procedures, Forms and Templates 13
M Internal Document Numbering System - Please review and advise Document Control Systems, Procedures, Forms and Templates 7
V Document Version Numbering Document Control Systems, Procedures, Forms and Templates 3
A Document Review and Document Approval --- 2 Signatures needed acc. §820.40? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 3
K 25-year lifetime of medical device - document storage period EU Medical Device Regulations 1
J UDI - Where to document it? EU Medical Device Regulations 8
S Changing revision status of a reviewed document Manufacturing and Related Processes 4
shimonv Document Control Procedure Header Content Document Control Systems, Procedures, Forms and Templates 3
Q Document ownerships Document Control Systems, Procedures, Forms and Templates 14
E Document Change Request forms (or no forms)? ISO 13485:2016 - Medical Device Quality Management Systems 9
O Any info on release date of FDA “Computer Software Assurance for Manufacturing and Quality System Software” document? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 0
B Document Approval Matrix Benchmarking Document Control Systems, Procedures, Forms and Templates 3
J Document Approval Signature Order Document Control Systems, Procedures, Forms and Templates 10
M What is the proper way to document measurements Measurement Uncertainty (MU) 1
P Equipment 21 CFR 820.70(g) - User Requirements Document for Off the shelf equipment 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 7
B Do IFU designs have to be document controlled under ISO 13485? Document Control Systems, Procedures, Forms and Templates 2
C Certificate of Conformance Form - COC for each customer a controlled document? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
A Document "Correspondence IATF 16949 vs ISO13485" available? IATF 16949 - Automotive Quality Systems Standard 0
R Document Retention - Discard hard-copies after scanning? ISO 13485:2016 - Medical Device Quality Management Systems 2
P Mylar plot suppliers in accordance with D6-51991 document AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
A Document Change Notice vs complete System re-write Manufacturing and Related Processes 4
Q Document approval through SharePoint (without signature) Records and Data - Quality, Legal and Other Evidence 4
S What is considered a "core algorithm"? (From an FDA guidance document) Medical Information Technology, Medical Software and Health Informatics 4
U Document Approval - Software company ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
O Please, help with document on ISO/ TS 17758 and (IDF 87: 1979). Thank you. Manufacturing and Related Processes 1
I Nitpicking on document released dates ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
