Document Numbering (Identification) System
kdburkh0214
I'm in the process of restructuring our document numbering system. Right now we have QCWF-1.1.1.1-01 (Name of Document). I think it's silly I want to change procedures to P001 and so on, Forms to F001 and so on, Work Instructions to WI001 and so on. We have a lot of other documents that don't really fall into any of those categories. More of reference documents. I don't want to call them R001 because I think people would assume they are records. Any suggestions?
qualprod
I always have used this method and works well.
Eg.
Pro-qms-001, for-hr-001, sd-qms-001,pur-wi-001,
Pro=procedure, for= format for records, sd=special documents (policy, objectives, context,etc ), wi=work instructions, pur-001, , qms is acronym of quality management system process, pur= purchase process,hr =human resource process, and so on, the last , 001 is the consecutive.
Hope this helps
Marc
Hunkered Down for the Duration
Also see the Similar Threads list below, and check the "document identification and numbering" thread tag above for more "food for thought". There are many ways to identify documents.
Ninja
Looking for Reality
FWIW, you don't have to have a numbering system at all...though I always found it useful (if it is made to be useful)...
We had groups of Docs with subsections:
MP = Manufacturing Procedure (How to make stuff)
MM = Machine Method (How to use the equipment)
TM = Test method
AD = Administrative
My section of the company used MP12-XXX, MM3-XXX and TM8-XXX...docs were always easy to find, I just had to remember those three and scroll through.
If you are publishing electronically, with a search function...searchable titles are even more useful.
Eredhel
Quality Manager
We have Procedures, Instructions, and Documents. A couple examples of titles from our Procedures server folder are "P-30 Contract Review" and "P-50 Document Control". We don't have to do it that way but it has worked out well with what this shop already had from the owner's prior business.
Scanton
Wearer of many hats
When I was an apprentice (many decades ago) and was working on some documentation with the quality dept, they had set categories for documents i.e. procedures=PR, work instructions=WI, specifications=SP, manuals=MA etc followed by a three digit number (I suppose they didn't expect to have more than 999 of any one type of document), and I asked "what do you do if your type of document doesn't fall into one of these categories" and that answer was "the catch all is, Information Sheet=IS" which turned out to be any piece of paper with information on it that didn't fit anywhere else. :)
kdburkh0214
Well let me ask another (probably dumb) question; Do I have to have a statement on the footer of controlled document? e.g. "Printed Documents are uncontrolled. The user is responsible for verifying the current revision."
Ninja
Looking for Reality
You need "control"...how you get it is pretty wide open...
We chose to publish electronically, and only the electronic one was "authoritative".
When we needed a printed copy (for writing data on a form, etc) we had a sig block to initial that it was compared to the controlled doc to verify correct rev...that's just one way to handle it...
S Document Numbering and Identification Methods ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 21
G Requirement for Form Numbering (Document Identification) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
S Document Numbering and Identification Systems Advice wanted Document Control Systems, Procedures, Forms and Templates 14
N Unique Document Identification Numbering System Document Control Systems, Procedures, Forms and Templates 69
D Documentation System Document Numbering and Identification Document Control Systems, Procedures, Forms and Templates 4
J Document Numbering (Identification) Scheme Document Control Systems, Procedures, Forms and Templates 17
T Document numbering - What is your favorite identification scheme? Document Control Systems, Procedures, Forms and Templates 31
D Organization Chart Document Numbering ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
dubrizo Restructuring Document Control Numbering System Document Control Systems, Procedures, Forms and Templates 3
C Document Numbering Matrix showing how to number all documents by type Document Control Systems, Procedures, Forms and Templates 2
alonFAI Document Numbering System For ISO/Quality Management Document vs. All Other Documents Document Control Systems, Procedures, Forms and Templates 44
C Document Numbering and Hierarchy Requirements for ISO 13485 Document Control Systems, Procedures, Forms and Templates 3
D Include as an attachment or make a separate document? Advise on Document Numbering Document Control Systems, Procedures, Forms and Templates 1
K Document Revision Numbering and Related Requirements Document Control Systems, Procedures, Forms and Templates 12
D Multiple Format Document and Part Numbering Systems ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
V Document Numbering Systems Question Document Control Systems, Procedures, Forms and Templates 5
T Performance Document vs. Project Document Numbering Convention Document Control Systems, Procedures, Forms and Templates 4
J Large Projects, large number of partners? Document Numbering/Identifying Issues Benchmarking 6
S Correct Document Control - Does each Document need its own Unique Numbering? Document Control Systems, Procedures, Forms and Templates 13
M Internal Document Numbering System - Please review and advise Document Control Systems, Procedures, Forms and Templates 7
V Document Version Numbering Document Control Systems, Procedures, Forms and Templates 3
C Certificate of Conformance Form - COC for each customer a controlled document? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
A Document "Correspondence IATF 16949 vs ISO13485" available? IATF 16949 - Automotive Quality Systems Standard 0
R Document Retention - Discard hard-copies after scanning? ISO 13485:2016 - Medical Device Quality Management Systems 2
P Mylar plot suppliers in accordance with D6-51991 document AS9100, IAQG 9100, Nadcap and related Aerospace Standards and Requirements 4
A Document Change Notice vs complete System re-write Manufacturing and Related Processes 4
Q Document approval through SharePoint (without signature) Records and Data - Quality, Legal and Other Evidence 4
S What is considered a "core algorithm"? (From an FDA guidance document) Medical Information Technology, Medical Software and Health Informatics 4
U Document Approval - Software company ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
O Please, help with document on ISO/ TS 17758 and (IDF 87: 1979). Thank you. Manufacturing and Related Processes 1
I Nitpicking on document released dates ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
I Document Control on Log Files ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
Q Refusal to Document Complaints Customer Complaints 39
Q Tracking Procedure Revisions (Document Control) Document Control Systems, Procedures, Forms and Templates 9
C Document Control Stamps - Does anyone still stamp their documents? Document Control Systems, Procedures, Forms and Templates 21
I Question 1 - Nitpicking on Document Approval - can a document approval record be separate? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
T Advice needed - Environmental MS - unwritten but customer requests policy document ISO 14001:2015 Specific Discussions 5
T Control of downloaded document copies by employees Document Control Systems, Procedures, Forms and Templates 3
T Document control ISO 13485:2016 ISO 13485:2016 - Medical Device Quality Management Systems 5
I Is highlighting on a printed document considered a change? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
C QMS Document Management Software Recommendations Quality Assurance and Compliance Software Tools and Solutions 15
E Part 11 Compliance, Excel living documents (i.e. document master list, equipment list, approved supplier list) Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 3
Sidney Vianna Informational New IAQG Document - AS9100 Clarifications of Intent AS9100, IAQG 9100, Nadcap and related Aerospace Standards and Requirements 3
S How to determine & document Organizational Knowledge of a company Document Control Systems, Procedures, Forms and Templates 4
D Are medical device companies required to document every change made to their website? Document Control Systems, Procedures, Forms and Templates 2
M Informational IMDRF draft document – Principles and Practices for Medical Device Cybersecurity Medical Device and FDA Regulations and Standards News 0
M Nonconformity for missing form number on the job description document Nonconformance and Corrective Action 1
