Document Numbers (Identification) on Forms (AS9100)
SpaceCase
So the package we bought indicates that all of our forms will be labeled according to the corresponding clause in the standard.
731 is Key Characteristics so our Work Order and Traveler are F-731-001 and F-731-002 respectively because the key characteristics are called out on those forms. (i.e. material type, length, width, height, cleaning spec and level, test pressures, etc...)
We are having a problem figuring out how to label the rest of our forms
(Certifications)...
Cold Shock Report
NVR Analysis
Bubble Point Cert
Particulate Count Cert
Cleaning Cert
Calibration Cert
Tube Bending & Flaring Cert
Hydrostat Cert
Hydraulic Cert
If you can offer any advice in any way, we would greatly appreciate it! :thanx:
Michael_M
Re: Question about Form numbering
We use the same basic process, naming our forms on the standard clause they most refer to. However, we have several forms that are for the same basic clause so we add a number at the end, for example:
L-7.6 1 Personal Tool Calibration record.
L-7.6 2 Company Tool Calibration record.
L-7.6 References the standards clause 7.6, 1 or 2 following are saying "form 1 or form 2".
Space Case: Tell the software company you don't want to link your documents to clauses of the standard and want them to remove it, at their cost, since it's NOT an ISO requirement to do this and you've encountered a problem - what IS a cert? Document? Record? It's not a procedure, or work instruction...
They have made this too complex for your own good...
insect warfare
QA=Question Authority
(Certifications)...
Cold Shock Report
NVR Analysis
Bubble Point Cert
Cleaning Cert
Calibration Cert
Hydrostat Cert
Hydraulic Cert
I would like to play devil's advocate here by bringing up a few counter-points....
1) What if the clause numbers change due to an update in the AS9100 standard? Will your numbering system still be able to align with the new clause structure? This is not really new territory, largely in part because of the Annex SL global harmonization structure that is currently being incorporated (which I'm not sure if this standard has been upgraded to yet), but nonetheless even routine updates to any standard always carries with it the potential to structurally change clauses and to create an undesirable situation for your organization.
2) What if your organization decides to adopt more than one standard (i.e. an integrated management system, or IMS)? My organization currently employs an IMS, and using multiple numbering systems from multiple standards would result in so much unnecessary duplication of documents, therefore it is imperative that we utilize an alternative system that is unique to us, and is also effective in discouraging such redundancy from occurring.
3) What if you don't even need a numbering system? If you are a mom-and-pop shop and your system is not that complex to begin with, why bother with a numbering system at all? No need for a complex solution to a simple problem, a lot of us would say. In the end, it really comes down to what methods would reduce the most friction to your company's efficiency or bottom line, right?
Just some things to think about....
Brian :rolleyes:
I have my forms to AS9100, I am not worried about ISO9001****
**** Caveat, YET
But why even set it up to HAVE to change? The actual users of the document don't need to know anything about clauses of the standard, and, frankly, such numbering systems go to confirm their darkest fears - that "doing ISO" is a bureaucracy. All it LOOKS like, is making work for someone to justify "doing ISO"...
Michael_M
Honest answer: this was the numbering system that was in place when I got tasked with getting the AS9100 qualification (stage 2 was at the end of November) from an ISO (semi) compliant system (no certification). If I was to completely rewrite, renumber, and reorganize everything, I would have created the mass bureaucracy (and missed something somewhere). The form number is for document control. If the standard changes, what matter if the calibration record (document) is 7.6 1 or 10001 so long as the I have control and know what revision I am using.
I know I am still new to having an actual 'standard' to follow, but it kinda sounds like you are forcing your requirements of document control on others. I was answering the original posters question on 'how to'. I know I can use any numbering system and for the most part those who use the forms only worry about the revision level. The document (form) is clearly labeled on the top, for example "Personal Tool Calibration". The bottom of the form has L-7.6 1.
In 15 years the form number can still be L-7.6 1 as that would just be a unique identifier.
Re: A Question on Document number for the Forms
I'm not forcing any requirements, Michael, simply pointing out - mainly for those who come, read and go away without an alternative example - that the use of these type of numbering systems are, for the most part, entirely unnecessary! As I've been at pains to point out previously, people recognize documents from formats, titles, contents - not ISO cross referenced numbering systems.
Jen Kirley
Quality and Auditing Expert
(Certifications)...
Cold Shock Report
NVR Analysis
Bubble Point Cert
Cleaning Cert
Calibration Cert
Hydrostat Cert
Hydraulic Cert
Yuck. Can you get your money back? Or, can you over-write that numbering format in favor of something your organization is more comfortable with?
If not, I suppose the forms can be included under their element group:
procedure in 7.5 group and inspection/test in 8.1 or 8.2 group.
If it's possible, I would lump them in a small element number, for example 7.0 or 8.0.
M Document Identification and Control Numbers ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
Q Document Numbers for Same Document but in Different Languages? Document Control Systems, Procedures, Forms and Templates 4
C Changing Document Names/Control Numbers and Obsoleting Document Control Systems, Procedures, Forms and Templates 5
T Document Numbers vs. SW (software) version Document Control Systems, Procedures, Forms and Templates 5
D Document Revision Numbers and Control of Documents Document Control Systems, Procedures, Forms and Templates 18
Manix Automotive Headunit Sizes - Standard Numbers - DIN size with No Document Reference Other ISO and International Standards and European Regulations 2
K Using Document IDs - Seeking references that support the use of document ID numbers Document Control Systems, Procedures, Forms and Templates 11
D Do Procedures and Work Instructions have to have Document Numbers? Document Control Systems, Procedures, Forms and Templates 9
A Document Review and Document Approval --- 2 Signatures needed acc. §820.40? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 3
K 25-year lifetime of medical device - document storage period EU Medical Device Regulations 1
J UDI - Where to document it? EU Medical Device Regulations 8
S Changing revision status of a reviewed document Manufacturing and Related Processes 4
shimonv Document Control Procedure Header Content Document Control Systems, Procedures, Forms and Templates 3
Q Document ownerships Document Control Systems, Procedures, Forms and Templates 14
E Document Change Request forms (or no forms)? ISO 13485:2016 - Medical Device Quality Management Systems 9
O Any info on release date of FDA “Computer Software Assurance for Manufacturing and Quality System Software” document? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 0
B Document Approval Matrix Benchmarking Document Control Systems, Procedures, Forms and Templates 3
J Document Approval Signature Order Document Control Systems, Procedures, Forms and Templates 10
M What is the proper way to document measurements Measurement Uncertainty (MU) 1
P Equipment 21 CFR 820.70(g) - User Requirements Document for Off the shelf equipment 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 7
B Do IFU designs have to be document controlled under ISO 13485? Document Control Systems, Procedures, Forms and Templates 2
C Certificate of Conformance Form - COC for each customer a controlled document? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
A Document "Correspondence IATF 16949 vs ISO13485" available? IATF 16949 - Automotive Quality Systems Standard 0
R Document Retention - Discard hard-copies after scanning? ISO 13485:2016 - Medical Device Quality Management Systems 2
P Mylar plot suppliers in accordance with D6-51991 document AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
A Document Change Notice vs complete System re-write Manufacturing and Related Processes 4
Q Document approval through SharePoint (without signature) Records and Data - Quality, Legal and Other Evidence 4
S What is considered a "core algorithm"? (From an FDA guidance document) Medical Information Technology, Medical Software and Health Informatics 4
U Document Approval - Software company ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
O Please, help with document on ISO/ TS 17758 and (IDF 87: 1979). Thank you. Manufacturing and Related Processes 1
I Nitpicking on document released dates ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
I Document Control on Log Files ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
Q Refusal to Document Complaints Customer Complaints 39
Q Tracking Procedure Revisions (Document Control) Document Control Systems, Procedures, Forms and Templates 9
I Can a document (form) approval record be separate? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
T Advice needed - Environmental MS - unwritten but customer requests policy document ISO 14001:2015 Specific Discussions 5
T Control of downloaded document copies by employees Document Control Systems, Procedures, Forms and Templates 3
T Document control ISO 13485:2016 ISO 13485:2016 - Medical Device Quality Management Systems 5
I Is highlighting on a printed document considered a change? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
C QMS Document Management Software Recommendations Quality Assurance and Compliance Software Tools and Solutions 14
E Part 11 Compliance, Excel living documents (i.e. document master list, equipment list, approved supplier list) Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 3
