Document ownerships
qcman
Registered Visitor
In our ISO 9001 documents we have the Org chart, Overall Sequence and Interaction and Responsibility Matrix. In reviewing them I see there are no ownership called out on them as is with the rest of the QMS documents. This is a mature system and this has not been noted in any past audits. Question to those who utilize these 3 documents in their systems, do you note ownerships of these?
Ninja
Looking for Reality
We did not define "ownership" per se...but did list author(s) on the docs.
If any doc was revised, the previous author (if still employed) was required to be an approver of the revision...so I guess you could call that "ownership".
We had it that way so that original intent could be maintained, and preserve know-how through revisions.
All of that said, an org chart would be 'owned' by the person in authority over it (in my case, the company owner).
Overall sequence, owner and/or VP-Operations whoever looks at things on the 'overall' level.
We didn't have those docs as stand alones...but the thinking is the same...who knows best which pieces are crucial and which pieces are fluff?
There's your owner.
Tagin
Do you define 'ownership' in your QMS?
We specify the roles of the doc approver(s) in a document's approval electronic signature boxes. I suppose that implies 'ownership' of a sort, but we do not use the term 'ownership' in our QMS.
qcman
Registered Visitor
Most of the documented procedures we have in our manual such as "Purchasing" has an author, approver and owner. The org chart was recently revised by the President and only shows revision date which is ok. The other 2 need to be updated and I believe they should call out an owner so that person / position will do the updating.
Ninja
Looking for Reality
Sounds like you need to revisit "why?" you have so much unrequired stuff in your system...
If author, and owner, are... are or can be... two different people...it sounds like you're spending a lot of calories for no reason...
Reset your thinking...That's my thinking...
qcman
Registered Visitor
Actually the system is pretty lean. As with any system there's room for improvement but it's effective. Appreciate the feedback.
It's not clear whether the documents cited in the first post are a part of the manual cited in the second post. If so, then someone should have responsibility for updating the manual as needed. This shouldn't be a matter of who's responsible for the individual documents, but rather who's responsible for the relevant processes. That person (or persons) should have responsibility for the documentation that supports the processes. The map is not the territory it depicts.
qcman
Registered Visitor
The documents referenced as well as others are in our QMS manual and outline individual processes of the organization. Each process, purchasing for instance has a process map which is owned by the Purchasing Manager. Relevant updates to the process would be determined by the owner and or management team and the process owner is responsible for updating the process map. Other than the 3 documents in my original question the map author and owner are one in the same. Maps also include inputs, outputs and KPI's
If the originally-referenced documents form a part of the manual, who is responsible for updating the manual?
A Document Review and Document Approval --- 2 Signatures needed acc. §820.40? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 3
K 25-year lifetime of medical device - document storage period EU Medical Device Regulations 1
J UDI - Where to document it? EU Medical Device Regulations 8
S Changing revision status of a reviewed document Manufacturing and Related Processes 4
shimonv Document Control Procedure Header Content Document Control Systems, Procedures, Forms and Templates 3
E Document Change Request forms (or no forms)? ISO 13485:2016 - Medical Device Quality Management Systems 9
O Any info on release date of FDA “Computer Software Assurance for Manufacturing and Quality System Software” document? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 0
B Document Approval Matrix Benchmarking Document Control Systems, Procedures, Forms and Templates 3
J Document Approval Signature Order Document Control Systems, Procedures, Forms and Templates 10
M What is the proper way to document measurements Measurement Uncertainty (MU) 1
P Equipment 21 CFR 820.70(g) - User Requirements Document for Off the shelf equipment 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 7
B Do IFU designs have to be document controlled under ISO 13485? Document Control Systems, Procedures, Forms and Templates 2
C Certificate of Conformance Form - COC for each customer a controlled document? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
A Document "Correspondence IATF 16949 vs ISO13485" available? IATF 16949 - Automotive Quality Systems Standard 0
R Document Retention - Discard hard-copies after scanning? ISO 13485:2016 - Medical Device Quality Management Systems 2
P Mylar plot suppliers in accordance with D6-51991 document AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
A Document Change Notice vs complete System re-write Manufacturing and Related Processes 4
Q Document approval through SharePoint (without signature) Records and Data - Quality, Legal and Other Evidence 4
S What is considered a "core algorithm"? (From an FDA guidance document) Medical Information Technology, Medical Software and Health Informatics 4
U Document Approval - Software company ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
O Please, help with document on ISO/ TS 17758 and (IDF 87: 1979). Thank you. Manufacturing and Related Processes 1
I Nitpicking on document released dates ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
I Document Control on Log Files ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
Q Refusal to Document Complaints Customer Complaints 39
Q Tracking Procedure Revisions (Document Control) Document Control Systems, Procedures, Forms and Templates 9
I Can a document (form) approval record be separate? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
T Advice needed - Environmental MS - unwritten but customer requests policy document ISO 14001:2015 Specific Discussions 5
T Control of downloaded document copies by employees Document Control Systems, Procedures, Forms and Templates 3
T Document control ISO 13485:2016 ISO 13485:2016 - Medical Device Quality Management Systems 5
I Is highlighting on a printed document considered a change? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
C QMS Document Management Software Recommendations Quality Assurance and Compliance Software Tools and Solutions 14
E Part 11 Compliance, Excel living documents (i.e. document master list, equipment list, approved supplier list) Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 3
Sidney Vianna Informational New IAQG Document - AS9100 Clarifications of Intent AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
S How to determine & document Organizational Knowledge of a company Document Control Systems, Procedures, Forms and Templates 4
D Are medical device companies required to document every change made to their website? Document Control Systems, Procedures, Forms and Templates 2
M Informational IMDRF draft document – Principles and Practices for Medical Device Cybersecurity Medical Device and FDA Regulations and Standards News 0
M Nonconformity for missing form number on the job description document Nonconformance and Corrective Action 1
R Training Matrix for Document revisions ISO 13485:2016 - Medical Device Quality Management Systems 4
S Controlled Document Location Document Control Systems, Procedures, Forms and Templates 3
M Setting deadlines (ex. 45 days) for Document Registration & Review Cycle Document Control Systems, Procedures, Forms and Templates 3
M Informational IMDRF draft document – Requirements for Regulatory Authority Recognition of Conformity Assessment Bodies Conducting Medical Device Regulatory Reviews Medical Device and FDA Regulations and Standards News 0
B AS9110 Audit Check Sheet wanted Excel or Word Document AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
