Document replacement - How would you migrate the old to the new?
G
gfreely
I searched thru the site and couldn't find anything directly addressing my question...
I have a document with all of the signed steps accomplished in completing the Product Realisation process. To put it succinctly, it got 'mangled'. I don't want to hand it over to our customer :nope: or their independant surveyor (for review) :read: in that condition, so I had our P&S dept. print a new blank one.
Question: How would you migrate the old to the new? What source do YOU use to know?
I am only asking because, after a thorough review of our QMS, we have NOTHING to cover this scenario! :mad: Part of my job is to implement "consistency", so I will be addressing this quickly, but in the meantime, I have a document to prepare to hand over to the customer...:mg:
Looking for ideas...any takers?
SteelMaiden
Re: Document replacement
Was this document like a work instruction? or a form?
If it is a work instruction/procedure type of document, can you not just call it a revision? I'm slightly confused, so maybe some clarification will help me. (remember I'm one of the senior set now, so I get easily confused.:lmao:)
G
gfreely
It's a type of "job traveller". The original is bent, ripped, pages have incorrect page numbering from the various revisions...but it has the original signatures and notes from the people who performed the work.
I understand that the "old" one will need to be retained for the very reason that it has the signatures/notes, but I am looking for ideas of how to present the "new" one. I can't forge the signatures, obviously, but one idea was to refer each item on the new traveller to the corresponding signature of the old one....then sign by it so nobody thinks it was a random act of cleanliness....
B.Read - 2010
Present your new one, but have a photocopy of the old with it if you need to have the signatures. Reference where needed.
Going forward, I recommend scanning all signed docs where you need to retain a signature as a .PDF. If lost, destroyed, whatever, you simply print a new one signatures and all.
SteelMaiden
could you straighten, tape, and otherwise "fix" the physical defects, and then correct the page numbering (mark through the incorrect, correct and initial, and add an explanation somewhere)?
Travellers can get a lot of wear and tear, depending upon what your operations are. I wouldn't think twice about seeing a document that showed some physical wear. Your bigger issue is why is there "incorrect page numbering from the various revisions"? Was your traveller revised in the middle of a job? Did someone use an old version when he should have used a newer one? Or, are you saying that there were "revisions" (what I would call change orders) to the job during the production cycle and thus various pages were inserted into the original traveller to show the change order status?
I would also scan the documents to a pdf file and save the e-file, not the paper (unless you are regulated to have original.)
G
gfreely
I can "neaten it up" a bit, but you are correct, it is evidence of another problem altogether...but that problem points back to my dilemma. If the traveller revision changed, this problem should have been addressed earlier on. Maybe I'll go have a talk with the people whose names I have on the document...:argue:
SteelMaiden
Looks like a perfect opportunity for a corrective action, and some real root cause analysis. It happens to the best of us.;)
A Document Review and Document Approval --- 2 Signatures needed acc. §820.40? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 3
K 25-year lifetime of medical device - document storage period EU Medical Device Regulations 1
J UDI - Where to document it? EU Medical Device Regulations 8
S Changing revision status of a reviewed document Manufacturing and Related Processes 4
shimonv Document Control Procedure Header Content Document Control Systems, Procedures, Forms and Templates 3
Q Document ownerships Document Control Systems, Procedures, Forms and Templates 14
E Document Change Request forms (or no forms)? ISO 13485:2016 - Medical Device Quality Management Systems 9
O Any info on release date of FDA “Computer Software Assurance for Manufacturing and Quality System Software” document? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 0
B Document Approval Matrix Benchmarking Document Control Systems, Procedures, Forms and Templates 3
J Document Approval Signature Order Document Control Systems, Procedures, Forms and Templates 10
M What is the proper way to document measurements Measurement Uncertainty (MU) 1
P Equipment 21 CFR 820.70(g) - User Requirements Document for Off the shelf equipment 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 7
B Do IFU designs have to be document controlled under ISO 13485? Document Control Systems, Procedures, Forms and Templates 2
C Certificate of Conformance Form - COC for each customer a controlled document? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
A Document "Correspondence IATF 16949 vs ISO13485" available? IATF 16949 - Automotive Quality Systems Standard 0
R Document Retention - Discard hard-copies after scanning? ISO 13485:2016 - Medical Device Quality Management Systems 2
P Mylar plot suppliers in accordance with D6-51991 document AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
A Document Change Notice vs complete System re-write Manufacturing and Related Processes 4
Q Document approval through SharePoint (without signature) Records and Data - Quality, Legal and Other Evidence 4
S What is considered a "core algorithm"? (From an FDA guidance document) Medical Information Technology, Medical Software and Health Informatics 4
U Document Approval - Software company ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
O Please, help with document on ISO/ TS 17758 and (IDF 87: 1979). Thank you. Manufacturing and Related Processes 1
I Nitpicking on document released dates ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
I Document Control on Log Files ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
Q Refusal to Document Complaints Customer Complaints 39
Q Tracking Procedure Revisions (Document Control) Document Control Systems, Procedures, Forms and Templates 9
I Can a document (form) approval record be separate? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
T Advice needed - Environmental MS - unwritten but customer requests policy document ISO 14001:2015 Specific Discussions 5
T Control of downloaded document copies by employees Document Control Systems, Procedures, Forms and Templates 3
T Document control ISO 13485:2016 ISO 13485:2016 - Medical Device Quality Management Systems 5
I Is highlighting on a printed document considered a change? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
C QMS Document Management Software Recommendations Quality Assurance and Compliance Software Tools and Solutions 14
E Part 11 Compliance, Excel living documents (i.e. document master list, equipment list, approved supplier list) Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 3
Sidney Vianna Informational New IAQG Document - AS9100 Clarifications of Intent AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
S How to determine & document Organizational Knowledge of a company Document Control Systems, Procedures, Forms and Templates 4
D Are medical device companies required to document every change made to their website? Document Control Systems, Procedures, Forms and Templates 2
M Informational IMDRF draft document – Principles and Practices for Medical Device Cybersecurity Medical Device and FDA Regulations and Standards News 0
M Nonconformity for missing form number on the job description document Nonconformance and Corrective Action 1
R Training Matrix for Document revisions ISO 13485:2016 - Medical Device Quality Management Systems 4
S Controlled Document Location Document Control Systems, Procedures, Forms and Templates 3
M Setting deadlines (ex. 45 days) for Document Registration & Review Cycle Document Control Systems, Procedures, Forms and Templates 3
