Document Revision Numbers and Control of Documents
dlipdlip
We have a document management system that handles all revisioning of documents for us. We have established in our quality manual that documents are only considered to be controlled if: 1) Viewing directly from our intranet on which we store a read-only copy; 2) If viewing directly from our document management system; 3) For a period of 12 hours after printing (from either of these locations) when a hard copy is required.
With this system we have not been putting revision numbers on documents since the revision number and change history is maintained by our doc. management system and this would be a reduntant step that we would have to make sure was performed. It has been suggested to us by an auditor that we have to have the revision number on the document itself. I think that we are meeting section 4.2.3 with our current system.
Any thoughts?
Marc
Are you using document control software or just putting documents in a 'Read Only' directory?
Personally I'd be wary about no document revision / version identification on documents.
Re: Document revision numbers and control of docs
Any thoughts?
I think you're in the clear. The questions that any document control system must answer are, "How can you be sure you're using the current version?" and "How do you make sure that obsolete versions are not used?" Your system addresses both questions. The standard requires you to "...ensure that...the current revision status of documents [is] identified." This does not say that the identification must be on the document itself.
Marc
Don't forget the revision history aspect. While revision history is more important in some cases than others, revision history should not be totally ignored.
dlipdlip
We're using document control software that handles approvals, revision history, archiving previous revisions and etc.
I agree. I ellipsed-out the language about changes in the snip I quoted because it wasn't directly relevant to the question. Old versions can be archived in such a way as to satisfy the requirement to identify changes. Again, there's nothing that requires either changes or revision levels to be identified on each document (although I would do it that way).
Helmut Jilling
Auditor / Consultant
Any thoughts?
As an auditor, I can't be certain without seeing how it works, but what you described certainly can be approrpiate. Many of my clients use something similar. Thekey is simply if your system can ensure that only current, accurate, approved docs are being used. If you can demonstrate your system does that, it should work. Sounds like a simple, sweet solution.
Wes Bucey
FWIW:
I have faith in electronic doc management/control (EDM) systems.
The primary reason for the anal retentive systems for revision numbering and control systems [of who could read/make copies/change/delete/etc. a document] was to offset the problems inherent in trying to keep track of hard paper documents once they left the file cabinet. If a person picked up a paper document that had dropped from the chain of custody, the only way to identify it as valid or obsolete was by the revision number. With EDM (especially as described by dlipdlip), the document is NEVER out of the chain of custody. Ergo, the auditor cannot justify demanding additional marking of a document any more than he could demand the client use a particular brand of file cabinet for paper copies. The essence of configuration management is to assure no obsolete documents are used to the detriment of the organization or its customers. The description given by dlipdlip seems to provide that assurance.
Helmut Jilling
FWIW:
I fully agree with Wes' premise.
dlipdlip
FWIW:
This is really how I felt about it also. The only time I can see it as a problem would be for documents that are used externally (such as a print given to a supplier, or a quality directive provided to a supplier, etc.) but with these we would always insure a revision number was present.
S Changing revision status of a reviewed document Manufacturing and Related Processes 4
I Tracking Protoype Changes; 8D or simple document revision? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
M Document Control - Revision Number in Document Names Document Control Systems, Procedures, Forms and Templates 4
C Document Control - old revision vs new revision Document Control Systems, Procedures, Forms and Templates 22
Q Change revision number in document when only codification was changed Document Control Systems, Procedures, Forms and Templates 8
M Where does Document Revision Control Start? Rev 0 or Rev 1 Document Control Systems, Procedures, Forms and Templates 19
I Document Control - Document Revision History Question Document Control Systems, Procedures, Forms and Templates 16
M Is a New Revision Required for Minor Document Changes? Document Control Systems, Procedures, Forms and Templates 15
C Document Revision for each new Preventative Maintenance Checklist? Document Control Systems, Procedures, Forms and Templates 5
L Document Control Procedure - Revision Control ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 15
G Document issued with incorrect Revision Number Quality Manager and Management Related Issues 8
G Document Revisions - How do I track the Form Revision History/Approvals? Document Control Systems, Procedures, Forms and Templates 5
S Change and Revision Status Identification for a Document ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
A ISO13485 - Document Revision Tracking Document Control Systems, Procedures, Forms and Templates 4
C Documents sent to Suppliers - Document Revision Level Identification question Document Control Systems, Procedures, Forms and Templates 2
T Document Control Revision - Starting Over Document Control Systems, Procedures, Forms and Templates 1
K Document Revision Numbering and Related Requirements Document Control Systems, Procedures, Forms and Templates 12
Z Revision Number vs. Issue Number - Document Control in ISO 17025:2005 ISO 17025 related Discussions 8
G Revision Control - Per document vs Universal control Document Control Systems, Procedures, Forms and Templates 7
D Skipping Document Revision Levels Document Control Systems, Procedures, Forms and Templates 20
F Document Control and Document Revision Control ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 14
W Redundant Documents - A version of the document that was in pre-revision status Document Control Systems, Procedures, Forms and Templates 5
J Document Format vs Content Revision - Form changed from MS Word to MS Excel Document Control Systems, Procedures, Forms and Templates 7
M Document Control Software Program with Revision Tracking Recommendations Document Control Systems, Procedures, Forms and Templates 7
A Document Revision Control - Use alphabets or date? Quality Manager and Management Related Issues 18
P Revision History in an MS Word document Document Control Systems, Procedures, Forms and Templates 37
P Please comment on revision status of document on a per page basis Document Control Systems, Procedures, Forms and Templates 25
R Document and Quality Manual Revision Control requirements - Alpha or Numeric Document Control Systems, Procedures, Forms and Templates 4
A Is revision level required in the document / form? Document Control Systems, Procedures, Forms and Templates 7
V What Constitutes a Document Change? Company Logo Revision Miscellaneous Environmental Standards and EMS Related Discussions 12
D Document Control Management System (MyDMS) & Revision Time Frames Document Control Systems, Procedures, Forms and Templates 3
J Print (Drawing) Document Revision History Identification Indicators Document Control Systems, Procedures, Forms and Templates 5
L Document Control - Document Version or Document Revision? Document Control Systems, Procedures, Forms and Templates 12
L Document Version or Document Revision? Document Control Document Control Systems, Procedures, Forms and Templates 18
kisxena Issued travelers that have out-dated revision - 21 CFR 820.40 - Document Control Document Control Systems, Procedures, Forms and Templates 10
L New Document Number for Every Revision? Document Control Systems, Procedures, Forms and Templates 16
D Documenting Revision History - Single ?Revision Record? Document Document Control Systems, Procedures, Forms and Templates 4
R Document Revision Identification Requirements - ISO 9001 Clause 4.2.3(c) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
H Document Revision Service? Auditor wants a service for document revision/renewal ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 12
V Document Version vs. Revision - Semantics? Document Control Systems, Procedures, Forms and Templates 18
T Document Control Revision History in Manually Created BOM's (Bill of Materials) Document Control Systems, Procedures, Forms and Templates 6
M Missing a Revision in a Document's Revision History Document Control Systems, Procedures, Forms and Templates 2
A Document Review and Document Approval --- 2 Signatures needed acc. §820.40? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 3
K 25-year lifetime of medical device - document storage period EU Medical Device Regulations 1
J UDI - Where to document it? EU Medical Device Regulations 8
shimonv Document Control Procedure Header Content Document Control Systems, Procedures, Forms and Templates 3
