Document Revision Numbers and Control of Documents
Helmut Jilling
Auditor / Consultant
#11
This is really how I felt about it also. The only time I can see it as a problem would be for documents that are used externally (such as a print given to a supplier, or a quality directive provided to a supplier, etc.) but with these we would always insure a revision number was present.
A revision DATE would also be acceptable. Anything that is traceable or can make the revision link.
Manix
Get Involved!!!
#12
We have a document management system that handles all revisioning of documents for us. We have established in our quality manual that documents are only considered to be controlled if: 1) Viewing directly from our intranet on which we store a read-only copy; 2) If viewing directly from our document management system; 3) For a period of 12 hours after printing (from either of these locations) when a hard copy is required.
With this system we have not been putting revision numbers on documents since the revision number and change history is maintained by our doc. management system and this would be a reduntant step that we would have to make sure was performed. It has been suggested to us by an auditor that we have to have the revision number on the document itself. I think that we are meeting section 4.2.3 with our current system.
Any thoughts?
I use a similar system. But I always ensure that revision numbers are updated in line with the electronic system. That way, as many of you have said, if it get's pulled from the system it can be at least referenced to the system to ensure it is current.
However, I have issues with rules 1) & 2).
1) Is your read only copy on the intranet instantly updated the moment a document is updated in your controlled system?
2) If the 12 hour rule applies, do printed copies contain the date and time that the document has been printed? Otherwise this rule is useless because who knows when it was last printed.
Obviously I don't know your system so I cannot comment completely on it's effectiveness, I would just be happier to see references on "Non COntrolled" copies so we know at what level these are at!!!!!
Of couse I have dreamed of a document control system that does the revision number updating automatically onto the document LIVE!
#13
This question made me think about a possibility I hadn't thought of before. It might be possible, through the phenomenon of browser disk-caching (and the user settings for same) for an intranet-based system to produce an obsolete (i.e., cached) version of a document without the user's being aware of what is happening.
Short explanation: Browser (Internet Explorer, Firefox, whatever) performance is enhanced by caching of web pages (or portions of them) on the local hard disk. This means that after the first time a page is downloaded, the browser, before downloading the same page again, will look in the local cache for the information and load it from there, which is much faster. There are user settings (under Internet Options in IE, for example) that control how this happens: Always download from the server, regardless of cache content; check the server version first to see if it's different from the cached version, etc.
It's conceivable that if the browser cache settings aren't controlled, a user could load an old version from the cache while thinking he's looking at the most recent version on the server.
Just some food for thought, speaking of which, it's lunch time:bigwave:
SteelMaiden
#14
I like to include a rev number or rev date just because it is possible to get a cached version from the browser, or for people to select text and copy and paste it even if you do have read only. I love electronic document control, but there is always somebody out there that can figure out how to mess you up, sometimes without really meaning to.
Wes Bucey
#15
Let me mess with your heads just a little.
Even if you have rigid, never-screwed-up systems for ensuring only the most recent version of a hard paper copy or electronic copy is issued from the central storage place (file drawer or server farm), you probably need a "push/pull system" to ensure the folks using that copy do NOT continue to use it once a new version is issued. This probably means keeping a hard copy or electronic record of everyone who had access to the previous versions and alerting them a new version has been issued and getting acknowledgement from each to the effect they have destroyed or deleted previous versions (even cleaning out local computer caches)
The intensity of doing this varies with both the effect using an obsolete version may have on finished product, service, inspection, etc. and the frequency with which changes may occur.
The consideration of steps necessary to integrate a new version throughout a system is all part of the process we call "Configuration Management."
Helmut Jilling
#16
While this might be possible, I think we are trying to hard. All we are trying to do is ensure that people have and are using current, accurate, approved info. Any method, or combination of methods can achieve this, without expending too much effort.
Electronic read-only is a good step forward. Reduce the number of unneeded paper copies. And do a little training to help people understand the basic steps.
Wouldn't that handle almost all of it?
Wes Bucey
#17
It might. Each case is different. The cardinal rule is "each system is tailored to fit the organization's needs."
I can envision (and have witnessed) oganizations where very few controls are needed because the culture is efficient and professional. Other situations are just downright scary. We write here for a generic world usually and only deal with "outliers" when they are specifically identified.
P
potdar
#18
Its a nicely designed system and should work well inhouse. However, as already discussed, documents do get printed and go out for reference. They are meant to remain updated. A system for ensuring that these remain upadated will still need to be defined.
E.g. engineering specs given to a supplier. Does purchase send a drawing / document with every purchase order or only when there is a change? How do they come to know that there is a change?..
Same will be true for documents of external origin. The standards, customer specific requirements..
I think I am adding questions. Not solutions.
dlipdlip
#19
Concerning 1) people can obtain the most current version from the intranet (for people without access to and training on usage of the doc. management system) or from the doc. management system. It's the quality managers responsibility to immediately update the intranet once a new doc. revision is approved. The QM is notified through routings defined by the Doc management system. Pretty simple process really compared to trying to find hardcopy controlled versions.
Concering 2), documents must either be printed with a time and date stamp or immediately signed with a time and date stamp, if not they are just uncontrolled documents.
S Changing revision status of a reviewed document Manufacturing and Related Processes 4
I Tracking Protoype Changes; 8D or simple document revision? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
M Document Control - Revision Number in Document Names Document Control Systems, Procedures, Forms and Templates 4
C Document Control - old revision vs new revision Document Control Systems, Procedures, Forms and Templates 22
Q Change revision number in document when only codification was changed Document Control Systems, Procedures, Forms and Templates 8
M Where does Document Revision Control Start? Rev 0 or Rev 1 Document Control Systems, Procedures, Forms and Templates 19
I Document Control - Document Revision History Question Document Control Systems, Procedures, Forms and Templates 16
M Is a New Revision Required for Minor Document Changes? Document Control Systems, Procedures, Forms and Templates 15
C Document Revision for each new Preventative Maintenance Checklist? Document Control Systems, Procedures, Forms and Templates 5
L Document Control Procedure - Revision Control ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 15
G Document issued with incorrect Revision Number Quality Manager and Management Related Issues 8
G Document Revisions - How do I track the Form Revision History/Approvals? Document Control Systems, Procedures, Forms and Templates 5
S Change and Revision Status Identification for a Document ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
A ISO13485 - Document Revision Tracking Document Control Systems, Procedures, Forms and Templates 4
C Documents sent to Suppliers - Document Revision Level Identification question Document Control Systems, Procedures, Forms and Templates 2
T Document Control Revision - Starting Over Document Control Systems, Procedures, Forms and Templates 1
K Document Revision Numbering and Related Requirements Document Control Systems, Procedures, Forms and Templates 12
Z Revision Number vs. Issue Number - Document Control in ISO 17025:2005 ISO 17025 related Discussions 8
G Revision Control - Per document vs Universal control Document Control Systems, Procedures, Forms and Templates 7
D Skipping Document Revision Levels Document Control Systems, Procedures, Forms and Templates 20
F Document Control and Document Revision Control ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 14
W Redundant Documents - A version of the document that was in pre-revision status Document Control Systems, Procedures, Forms and Templates 5
J Document Format vs Content Revision - Form changed from MS Word to MS Excel Document Control Systems, Procedures, Forms and Templates 7
M Document Control Software Program with Revision Tracking Recommendations Document Control Systems, Procedures, Forms and Templates 7
A Document Revision Control - Use alphabets or date? Quality Manager and Management Related Issues 18
P Revision History in an MS Word document Document Control Systems, Procedures, Forms and Templates 37
P Please comment on revision status of document on a per page basis Document Control Systems, Procedures, Forms and Templates 25
R Document and Quality Manual Revision Control requirements - Alpha or Numeric Document Control Systems, Procedures, Forms and Templates 4
A Is revision level required in the document / form? Document Control Systems, Procedures, Forms and Templates 7
V What Constitutes a Document Change? Company Logo Revision Miscellaneous Environmental Standards and EMS Related Discussions 12
D Document Control Management System (MyDMS) & Revision Time Frames Document Control Systems, Procedures, Forms and Templates 3
J Print (Drawing) Document Revision History Identification Indicators Document Control Systems, Procedures, Forms and Templates 5
L Document Control - Document Version or Document Revision? Document Control Systems, Procedures, Forms and Templates 12
L Document Version or Document Revision? Document Control Document Control Systems, Procedures, Forms and Templates 18
kisxena Issued travelers that have out-dated revision - 21 CFR 820.40 - Document Control Document Control Systems, Procedures, Forms and Templates 10
L New Document Number for Every Revision? Document Control Systems, Procedures, Forms and Templates 16
D Documenting Revision History - Single ?Revision Record? Document Document Control Systems, Procedures, Forms and Templates 4
R Document Revision Identification Requirements - ISO 9001 Clause 4.2.3(c) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
H Document Revision Service? Auditor wants a service for document revision/renewal ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 12
V Document Version vs. Revision - Semantics? Document Control Systems, Procedures, Forms and Templates 18
T Document Control Revision History in Manually Created BOM's (Bill of Materials) Document Control Systems, Procedures, Forms and Templates 6
M Missing a Revision in a Document's Revision History Document Control Systems, Procedures, Forms and Templates 2
A Document Review and Document Approval --- 2 Signatures needed acc. §820.40? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 3
K 25-year lifetime of medical device - document storage period EU Medical Device Regulations 1
J UDI - Where to document it? EU Medical Device Regulations 8
shimonv Document Control Procedure Header Content Document Control Systems, Procedures, Forms and Templates 3
