Document Revisions - How do I track the Form Revision History/Approvals?
G
glider_wings
Good day,
I have been assigned by my small company to start implementing our QMS, most specifically Document Control.
I'm slowly starting get a handle of things, but I have a very simple question.
For procedures etc, I have no problem with having the approvals, revision history, etc on the document. However, for forms (we have tons of forms for incidents, safety reporting, etc) how do I track the form revision history/approvals? Most of our forms would go from 1 page to 2-3 pages. Is that the way it's done? How do we print them? Do you always just select the last page (the actual form?). Or can I somehow split the form from the approvals/etc?
Any help appreciated!
RY
Marc
Fully vaccinated are you?
<snip> Most of our forms would go from 1 page to 2-3 pages. Is that the way it's done? How do we print them? Do you always just select the last page (the actual form?). Or can I somehow split the form from the approvals/etc? <snip>
Since it sounds like they are electronic originals, just print out the part which is the actual form. Typically I see forms as completely separate documents so what to print isn't an issue.
Colin
I agree with Harry and Marc - keep it simple. I usually a number and keep a register of the forms used (on a spreadsheet if you like) and keep only latest version as the master copy from which people can print. That way they can only print the latest version. If you prepare the master list electronically you can of course hyperlink to the form itself which makes it even easier.
I also keep a superseded folder and drop old copies in there just for reference.
K
ktmt520
I have a similar problem as OP's, and thank you for the help so far!
I'm currently revising SOPs for a small company and not quite sure if our system has adequate control for forms.
As of right now, the forms are listed on the SOPs themselves but they are separate from the SOP files, mainly for ease of printing. We link them by putting them in the same unique folder as the SOP they're associated with. Is this system good enough to show that revision and approval of the parent SOP also extends to the forms within that unique folder?
I've only started two weeks ago and I've always thought separate forms that are not written into the SOP files should have its own approval process. I would love to keep the current system, but I suppose I could separate the forms completely and have Document Change Form for each of them in their own folder, and also have a Master List for forms separate from the SOPs' Master List. I've already drafted revisions for a few forms and I'm stuck on the approval process for them.
I'm so new and confused! Thank you for any help anyone could offer. I love reading through the forum threads, but still so confused.
- KT
mitch_chel
Good day!
I am a DCC in a construction firm.
1. When I create a procedure, I fill-up the Document Control Notice then route it for review and approval. I only fill-up Document Control Notice whenever I create or revise a procedure, but I don't fill-up DCN whenever I create or revise a form because forms are attachments to my procedure. My procedure has several forms attached to it, I called it attachments. All my procedure has identification number (Doc. No. DCC-001) and all my forms has identification number (Doc. No. DCC-QF-001) also. Now, I want to revise a form, how do I do it? What form do I need to fill-up to revise a certain form?
2. Is it okay to create a form called Master List of Documents and Forms? That is my master list for all my Procedure (Internal Documents), all my Forms and all External Documents. All in one form. Then I'm going to put a column for Doc. Ref. No., Document Title, Revision No., Effectivity Date as well as retention time (active and inactive records) and its disposal method of the records. And also, can I include the distribution and retrieval in this form?
3. What form do I use to list all the Inactive/Archival records in DCC Archive Room? I have Retention Label Sheet to put in a box but how to determine if a certain records is due for disposal?
4. How to I retrieve a certain form in a department in case there is revision of that form? What form do I use?
5. Do i need Master List of Obsolete Documents/ Forms?
6. How to use Records Retention Matrix and when to use it?
Many thanks.
Q Tracking Procedure Revisions (Document Control) Document Control Systems, Procedures, Forms and Templates 9
R Training Matrix for Document revisions ISO 13485:2016 - Medical Device Quality Management Systems 4
M Informational Health Canada – Notice: Revisions to the Guidance Document: Management of Applications for Medical Device Licences Medical Device and FDA Regulations and Standards News 0
D Document Management System - Revisions & Out of Date Documents Document Control Systems, Procedures, Forms and Templates 17
L Preparation for ISO 9001:2015 - Required Document Revisions Document Control Systems, Procedures, Forms and Templates 10
J Question about training on document revisions Training - Internal, External, Online and Distance Learning 3
U Document Revisions Required in DMR Index? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 10
S How to document revisions after Periodic Review of documents ? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
A How to handle the various Document Revisions Document Control Systems, Procedures, Forms and Templates 2
R Document Changes (Revisions) and associated Risk Analysis ISO 13485:2016 - Medical Device Quality Management Systems 15
M Document Control (with Revisions Control) Management Database Document Control Systems, Procedures, Forms and Templates 4
D Document Revisions when a different company takes control ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
T Document Control Checklist for use after Document Revisions ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
N ISO 9001:2000 version to ISO 9001:2008 - Necessary Document Revisions ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
K Document Revisions BEFORE Certification Audit General Auditing Discussions 10
A Training on Document Revisions - ISO 9001 Clause 6.2.2 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
J Re-Issue of Documents - Requirement to re-issue a document after so many revisions? Document Control Systems, Procedures, Forms and Templates 2
M Document Revisions - Renumbering All Our Documents Document Control Systems, Procedures, Forms and Templates 2
Ed Panek MR Mandate Document EU Medical Device Regulations 0
C Document Index Document Control Systems, Procedures, Forms and Templates 4
K ASME, ANSI, ASTM and similar specifications and their requirements for document control. Inspection, Prints (Drawings), Testing, Sampling and Related Topics 8
H If we use agile - do we still need to document TF as a waterfall just for the notified bodies need? IEC 62304 - Medical Device Software Life Cycle Processes 2
Q ISO 9001/IATF 16949 Audit Finding Question - Document Retention IATF 16949 - Automotive Quality Systems Standard 10
B Document Issued with incorrect Document number code Document Control Systems, Procedures, Forms and Templates 2
J Requirement for Signature on Document Document Control Systems, Procedures, Forms and Templates 10
A Document Review and Document Approval --- 2 Signatures needed acc. §820.40? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 6
Sidney Vianna Interesting Discussion Should ISO 9004 be changed from a guidance document to a requirements standard? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
K 25-year lifetime of medical device - document storage period EU Medical Device Regulations 1
J UDI - Where to document it? EU Medical Device Regulations 8
S Changing revision status of a reviewed document Manufacturing and Related Processes 11
shimonv Document Control Procedure Header Content Document Control Systems, Procedures, Forms and Templates 3
Q Document ownerships Document Control Systems, Procedures, Forms and Templates 14
E Document Change Request forms (or no forms)? ISO 13485:2016 - Medical Device Quality Management Systems 9
O Any info on release date of FDA “Computer Software Assurance for Manufacturing and Quality System Software” document? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 0
B Document Approval Matrix Benchmarking Document Control Systems, Procedures, Forms and Templates 3
J Document Approval Signature Order Document Control Systems, Procedures, Forms and Templates 10
M What is the proper way to document measurements Measurement Uncertainty (MU) 1
P Equipment 21 CFR 820.70(g) - User Requirements Document for Off the shelf equipment 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 7
B Do IFU designs have to be document controlled under ISO 13485? Document Control Systems, Procedures, Forms and Templates 2
C Certificate of Conformance Form - COC for each customer a controlled document? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
A Document "Correspondence IATF 16949 vs ISO13485" available? IATF 16949 - Automotive Quality Systems Standard 0
R Document Retention - Discard hard-copies after scanning? ISO 13485:2016 - Medical Device Quality Management Systems 2
P Mylar plot suppliers in accordance with D6-51991 document AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
A Document Change Notice vs complete System re-write Manufacturing and Related Processes 4
Q Document approval through SharePoint (without signature) Records and Data - Quality, Legal and Other Evidence 4
