U
Hello Covers!
We are a small medical device firm. We are virtual, in that we own the design, registration, etc. but we contract all manufacturing, and perform lot release testing, document verification and final product release. Apart from lot release samples, we never actually see the product.
We are updating the DMR at one of our Contract Manufacturer (CM) facility. The CM has a 21CFR11 Compliant Document Management System. The DMR exists within that system as an index (think BOM indented by sub-assy levels, Work Instructions {WI} and Inspection Procedures {IP}listed with components at the proper indent/sub-assy level).
CM states they do not require the DMR to list the actual Revision Level, and instead contains a pointer to the approved file location within their doc control system for the current revision of each drawing, WI, IP, etc.
Conflict exists around the actual requirement. Some state the DMR must refer to the location of the current file, and hyperlink is not sufficient.
(It seems that belief originates here: 1st Paragraph of DMR section. 3 lines down.)
From reading other discussions in this forum, I believe Revision Control on the DMR is a best practice. As such, whenever a document is added or removed, the DMR must be updated. However, the debate remains on revision levels within the DMR.
My proposal: Identify the actual server location/document ID for each line item in the CM DMR Index, and rely on Doc Control at CM and Internally to assure those are always up-to-date. (Note: we have very good change notification agreements in place, and reliable document review/implementation processes.)
Your feedback on my proposal is greatly appreciated. Also, any comments detailing how you manage this at your firm would be helpful.
