Document Version vs. Revision - Semantics?
V
venkat - 2011
Version vs Revision
I would like to know the difference between revision number and version number.
The english meaning of revision and version are different.
From the quality perspective I feel that both are synonymous.
I would like to have inputs from other readers
Please let me have your thoughts on this
regards
Mike S.
Happy to be Alive
Venkat,
I use only revision in my doc system, but I think it goes like this:
Let's say you write a procedure for document control for the first time ever and call it DC-1 Ver. 0 Rev. 0 and send it around for approval. Someone asks you to change a few things before they will approve it. You make the changes and call it DC-1 Ver. 1 Rev. 0 and send it around again for approvals. Someone again asks for changes before they will approve it. You make the changes and call it DC-1 Ver. 2 Rev. 0 and send it around again for approvals. This time they approve it. A month later, someone asks for a revision to be made, so you make the changes and call it DC-1 Ver. 3 Rev. 1.
Anyone else?
howste
Thaumaturge
I agree with Mike S - the definitions are probably accurate. I typically don't worry about the differences though. Most of the time I see them used interchangeably.
CarolX
I use the term "Revision" when I have made a change to a document.
I use the term "Edition" when releasing a complete re-wrtite of a document.
For example...when I release my new Quality Manual for the 9K2K upgrade, it will be "Edition 2, Revision 0".
Just the way I do it.
CarolX
Douglas E. Purdy
Versions of Un-Issued Docs Mean What?
As a participant in Mike S.'s example, I would be confused if the original release of a document is issued with a Version 3 Revision 0. I would probably want to see Versions 1 & 2. Are Versions only controlling the changes of drafts being reviewed by the Process Owners?
Doug
Wes Bucey
CarolX
There is an SAE Standard
Revision of Engineering Drawings and Associated Documents Y14.35M-1997
available from the Society of Automotive Engineers, which discusses the issue of changes to documents and how to number them. The treatment of the terms version versus revision is pretty much ignored.
When a document (part drawing, text, Procedure, etc.) is revised to a point where it is completely different from the original and "Configuration Management" (search this term in the Cove for my other discussions on CM) determines the document deserves a new name or number rather than an additional "revision" designation, most organizations do not bother to keep any reference to the original in the naming or numbering.
There is discussion on this process in the Standard.
An interesting point is that the Standard suggests Revisions be given an alphabet letter rather than a number (A, B, . . . AA, AB, . . . XX) The Standard is quite clear an organization may adapt the Standard to its own purposes!
Mike S.
Happy to be Alive
Doug
This is what I have seen in the past. I do not particularly like this method, so I use revision numbers or letters only, not versions as well. If I give someone a Rev. A to approve for the first time ever, and they want a change, I destroy the old Rev. A and give them a new Rev. A with the changes they wanted for approval. But I can see where in some complex or large organizations that the Version/Revision system might be required, but it should be clearly stated what each means. JMO.
ben sortin
A version is a draft which can change based on the audience prior to release.
A revision is a change after release that must be communicated to one audience.
mshell
We use a rev level for all approved documents. The rev level is not effective until formal approval has been given. This allows users to review and modify the contents without having to change the level during document development.
Also, my last auditor suggested that we use something similar to the following:
Rev 0 (this is for initial release)
Rev 0a (this indicates a minor change)
Rev 0b (this indicates a second minor change)
Rev 0c (this indicates a third minor change)
Rev 0d (this indicates a fourth minor change and further changes would require a Rev change)
Minor changes are defined as changes that do not have an effect on the reqponsibilities, duties or authorities contained within the document. This method allows for the changes to be made without having to train on each little addition, deletion and/or correction.
Craig H.
Venkat:
I think you can see that the confusion you may have felt is rooted not in your English (which seems fine to me) but by the various interpretations attached to the question of version/revision levels. The fact that many people have a (different) system to control documents means the situation is widespread. Fortunately, as long as a workable system is adhered to within a given organization, there is no problem.
I wish I could remember who gave us the idea for our system. I like it for several reasons, but mostly because its simple. Say I have document A ready to go. When its time to give the document a revision number I look at the calender. So, today's revision/issue/version number is 102303 (for October 23, 2003).
That way, in use I can see how old the document is. Even though the document is controlled, and our system works well, finding a document with, say, 041392 as the revision number would likely make me want to double check on the master list to make sure it is the last revision.
Hope this helps.
Craig
W Redundant Documents - A version of the document that was in pre-revision status Document Control Systems, Procedures, Forms and Templates 5
L Document Control - Document Version or Document Revision? Document Control Systems, Procedures, Forms and Templates 12
L Document Version or Document Revision? Document Control Document Control Systems, Procedures, Forms and Templates 18
L Medical Device Software Document released version (article 5.8.4) IEC 62304 - Medical Device Software Life Cycle Processes 7
J How to document discontinuation or end of life for a software version ? IEC 62304 - Medical Device Software Life Cycle Processes 3
A Document Version for Website Help/Training 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 3
N Using ISO document number, version number in Software based solution. ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
S Cool Minitab Document 'Sample' - Help with FULL Version location/access? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
L Do Memos have to be under Version (Document or Record) Control? Document Control Systems, Procedures, Forms and Templates 17
N ISO 9001:2000 version to ISO 9001:2008 - Necessary Document Revisions ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
T Document Numbers vs. SW (software) version Document Control Systems, Procedures, Forms and Templates 5
U Document Management, Version Control & Document Storage Software Quality Assurance and Compliance Software Tools and Solutions 11
S Question regarding document control - Control EVERY version of the same graphic? Document Control Systems, Procedures, Forms and Templates 5
Marc Document Management and Version Control Document Control Systems, Procedures, Forms and Templates 0
J How to determine which is the 'master' "controlled" version of document Document Control Systems, Procedures, Forms and Templates 9
V Document Version Numbering Document Control Systems, Procedures, Forms and Templates 3
A Document Review and Document Approval --- 2 Signatures needed acc. §820.40? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 3
K 25-year lifetime of medical device - document storage period EU Medical Device Regulations 1
J UDI - Where to document it? EU Medical Device Regulations 8
S Changing revision status of a reviewed document Manufacturing and Related Processes 4
shimonv Document Control Procedure Header Content Document Control Systems, Procedures, Forms and Templates 3
Q Document ownerships Document Control Systems, Procedures, Forms and Templates 14
E Document Change Request forms (or no forms)? ISO 13485:2016 - Medical Device Quality Management Systems 9
O Any info on release date of FDA “Computer Software Assurance for Manufacturing and Quality System Software” document? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 0
B Document Approval Matrix Benchmarking Document Control Systems, Procedures, Forms and Templates 3
J Document Approval Signature Order Document Control Systems, Procedures, Forms and Templates 10
M What is the proper way to document measurements Measurement Uncertainty (MU) 1
P Equipment 21 CFR 820.70(g) - User Requirements Document for Off the shelf equipment 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 7
B Do IFU designs have to be document controlled under ISO 13485? Document Control Systems, Procedures, Forms and Templates 2
C Certificate of Conformance Form - COC for each customer a controlled document? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
A Document "Correspondence IATF 16949 vs ISO13485" available? IATF 16949 - Automotive Quality Systems Standard 0
R Document Retention - Discard hard-copies after scanning? ISO 13485:2016 - Medical Device Quality Management Systems 2
P Mylar plot suppliers in accordance with D6-51991 document AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
A Document Change Notice vs complete System re-write Manufacturing and Related Processes 4
Q Document approval through SharePoint (without signature) Records and Data - Quality, Legal and Other Evidence 4
S What is considered a "core algorithm"? (From an FDA guidance document) Medical Information Technology, Medical Software and Health Informatics 4
U Document Approval - Software company ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
O Please, help with document on ISO/ TS 17758 and (IDF 87: 1979). Thank you. Manufacturing and Related Processes 1
I Nitpicking on document released dates ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
I Document Control on Log Files ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
Q Refusal to Document Complaints Customer Complaints 39
Q Tracking Procedure Revisions (Document Control) Document Control Systems, Procedures, Forms and Templates 9
