Document Version vs. Revision - Semantics?
mshell
#11
Rev change?
Question:
If I have two forms that contain the same fields, and the operators only complete the fields on one of the forms can I delete the unnecessary fields from the other form without changing the rev level? Our procedure says that I can make minor changes without changing the rev level.
Thanks for the input.
Mshell
David Hartman
#12
mshell said:
Question:
Mshell
I personally would change the rev level, but would add a statement that "previous versions/revisions may continue to be used". This will allow the users to deplete the previous version, before implementing the new revision (saves money and waste). :bigwave:
Peter Fraser
#13
venkat said:
I would like to know the difference between revision number and version number.
The english meaning of revision and version are different.
Please let me have your thoughts on this
regards
Taking a slightly different viewpoint - when we make a change to our software, we call it a "revision" if it is a minor change (ie bug fix or minor enhancement) and a "version" if it is more significant. We are currently at "v2.07b" - v2.07 was a new version, since it had several additional features, and v2.07a and v2.07b have included a couple of fixes.
It's interesting, though, that one of the enhancements in v2.07 was to allow a user to copy a process definition and call it a "version"! This was done at the request of a user who wants to issue "versions" of a current process definition to nominated managers (1 each) who will then edit them and make their own suggestions for improvements. I assume that there will then be a vote to decide which of these versions will be approved as the next "revision" of the authorised process definition. Which seems to contradict the way we number our software releases!
If you weren't confused before, you should be now!
Jay Sturgeon
#14
Revision vs Version
From the quality perspective I feel that both are synonymous.
I would like to have inputs from other readers
I use revision numbers only. The difference is that I start with 0.1 to infinity until the document is approved, at which point it goes to 1.0. Any changes from that point on move up one rev. level. Example 1.0 to 2.0.
By the way we don't make that many changes after approval.
Hope this helps some.
Jay
:thedeal:
Cari Spears
#15
Mike S. said:
This is what I have seen in the past. I do not particularly like this method, so I use revision numbers or letters only, not versions as well. If I give someone a Rev. A to approve for the first time ever, and they want a change, I destroy the old Rev. A and give them a new Rev. A with the changes they wanted for approval. But I can see where in some complex or large organizations that the Version/Revision system might be required, but it should be clearly stated what each means. JMO.
Same here. I've worked in organizations that need the type of control of rough draft versions you described in your earlier post. In the type of place I work now all that is not necessary. We are about 65 people total, our management team is 7 people. We don't do a lot of document revisions and when we do, I distribute the rough draft to only a handful of people. I clearly identify it as "Rough Draft" and the logo is black/white (because I do the "original if green" in the header). Once revisions have been approved, then I change the revision level - I just use the date, no letters or other numbers.
Mike S.
Happy to be Alive
#17
Randy said:
Po-tay-to
Po-tah-to
Machts Nichts
Why do you say that, Randy? Seems there is some agreement that version and revision can mean slightly different things, a bit more than pronunciation. I have one customer where it matters bunches.
CarolX
#18
Randy said:
Po-tay-to
Po-tah-to
Machts Nichts
Randy,
I couldn't agree more. Do what works best for you, unless your customer requires something different.
I recall one customer almost demanding that I change my revision levels from numeric to alpha, because that was the way he was accustomed to doing things.
JMHO, as always
CarolX
Mike S.
Happy to be Alive
#19
Do what works best for you or your company is always excellent advice, no argument there.
But still, there IS a difference, IMO, between revision and version as used in most QMS', which I think was the crux of the original question. I have never seen only version designations used (though it could be if you wanted), but I have seen only revision designations (seems to be most popular in my experience) and I have seen both used together and they mean something different as earlier posts describe. I have one customer, a major electronics company, who uses both, so we have to be cognizent of that. There is a big difference between document ABC123 Version 2 Revision 1 and ABC123 Version 2 Revision 2.
W Redundant Documents - A version of the document that was in pre-revision status Document Control Systems, Procedures, Forms and Templates 5
L Document Control - Document Version or Document Revision? Document Control Systems, Procedures, Forms and Templates 12
L Document Version or Document Revision? Document Control Document Control Systems, Procedures, Forms and Templates 18
L Medical Device Software Document released version (article 5.8.4) IEC 62304 - Medical Device Software Life Cycle Processes 7
J How to document discontinuation or end of life for a software version ? IEC 62304 - Medical Device Software Life Cycle Processes 3
A Document Version for Website Help/Training 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 3
N Using ISO document number, version number in Software based solution. ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
S Cool Minitab Document 'Sample' - Help with FULL Version location/access? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
L Do Memos have to be under Version (Document or Record) Control? Document Control Systems, Procedures, Forms and Templates 17
N ISO 9001:2000 version to ISO 9001:2008 - Necessary Document Revisions ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
T Document Numbers vs. SW (software) version Document Control Systems, Procedures, Forms and Templates 5
U Document Management, Version Control & Document Storage Software Quality Assurance and Compliance Software Tools and Solutions 11
S Question regarding document control - Control EVERY version of the same graphic? Document Control Systems, Procedures, Forms and Templates 5
Marc Document Management and Version Control Document Control Systems, Procedures, Forms and Templates 0
J How to determine which is the 'master' "controlled" version of document Document Control Systems, Procedures, Forms and Templates 9
V Document Version Numbering Document Control Systems, Procedures, Forms and Templates 3
A Document Review and Document Approval --- 2 Signatures needed acc. §820.40? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 3
K 25-year lifetime of medical device - document storage period EU Medical Device Regulations 1
J UDI - Where to document it? EU Medical Device Regulations 8
S Changing revision status of a reviewed document Manufacturing and Related Processes 4
shimonv Document Control Procedure Header Content Document Control Systems, Procedures, Forms and Templates 3
Q Document ownerships Document Control Systems, Procedures, Forms and Templates 14
E Document Change Request forms (or no forms)? ISO 13485:2016 - Medical Device Quality Management Systems 9
O Any info on release date of FDA “Computer Software Assurance for Manufacturing and Quality System Software” document? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 0
B Document Approval Matrix Benchmarking Document Control Systems, Procedures, Forms and Templates 3
J Document Approval Signature Order Document Control Systems, Procedures, Forms and Templates 10
M What is the proper way to document measurements Measurement Uncertainty (MU) 1
P Equipment 21 CFR 820.70(g) - User Requirements Document for Off the shelf equipment 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 7
B Do IFU designs have to be document controlled under ISO 13485? Document Control Systems, Procedures, Forms and Templates 2
C Certificate of Conformance Form - COC for each customer a controlled document? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
A Document "Correspondence IATF 16949 vs ISO13485" available? IATF 16949 - Automotive Quality Systems Standard 0
R Document Retention - Discard hard-copies after scanning? ISO 13485:2016 - Medical Device Quality Management Systems 2
P Mylar plot suppliers in accordance with D6-51991 document AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
A Document Change Notice vs complete System re-write Manufacturing and Related Processes 4
Q Document approval through SharePoint (without signature) Records and Data - Quality, Legal and Other Evidence 4
S What is considered a "core algorithm"? (From an FDA guidance document) Medical Information Technology, Medical Software and Health Informatics 4
U Document Approval - Software company ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
O Please, help with document on ISO/ TS 17758 and (IDF 87: 1979). Thank you. Manufacturing and Related Processes 1
I Nitpicking on document released dates ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
I Document Control on Log Files ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
Q Refusal to Document Complaints Customer Complaints 39
Q Tracking Procedure Revisions (Document Control) Document Control Systems, Procedures, Forms and Templates 9
