Documentation and Record Requirement - What type of pen can be used? 820.180 Records
clipps
Hello, I believe that I read a post on the use of certain types of pens a while back, but I could not find it again. The FDA requirement in 820.180 Records stipulates that "records shall be legible and shall be stored to minimize deterioration" which auditors have interpreted to mean that the writing implement ink cannot degrade over the life of the record. I have found reference to a "felt pen" and similar in FDA webpages, but no EIRs, 483's or warning letters that identify the use of other than indelible ink pens is required. Does anyone have any further insights?
jem63
Re: Documentation and Record Requirement - What type of pen can be used? 820.180 Reco
Welcome to the Cove-
As long as you are not using invisible ink you should be fine.;)
If your auditor identifies that you should be using a special ink you should request a new auditor.
Quoting the requirement "records shall be legible and shall be stored to minimize deterioration" This basically says to use comon sense when storing and maintaining your records and make sure they are ledgible. For example, storing them in a fire/water safe cabinet.
:D
Ajit Basrur
The industry practice is to use Blue / Black and a non water based ink.
clipps
I guess I will have to chase down a few birds.
Jeff
clipps
Thank you for your response. I believe that we are meeting the intent of the regulation. We have even implemented a scanning of older documents in case our file cabinets fail.
W
winchm
:lmao: Good one AL...many years ago the AF inspector at Fairchild Republic insisted all signatures had to be in blue ink so you could tell it was an original. I guess color copiers weren't available in Farmingdale, LI.:applause:
Al Rosen
:topic:Thanks Mary, I try. BTW, having also worked there for some years, I know that they are a little behind in Farmingdale.
Weiner Dog
Med Device Consultant
FDA does not care about the color of the ink, just so that it is non-erasable. FDA frowns upon the use of pencils, white-out, or erasable ink. This is because QSR records have to be legible, stored to minimize deterioration and prevent loss, and be retained for at least 2 years (because by law, FDA is required to inspect medical device manufacturers at least every 2 years). Traditionally, due to records being copied, blue or black inks are preferred due to limitations of certain copy machines. However, if your copier can make legible copies, no matter the color ink and you meet 21 CFR 820.180, pick whatever color ink you want.
However, if you are nervous about the ink, records can be scanned and microfiched. However, original records should not be discarded. This is because original records (not scanned versions) need to be examined onsite by FDA. This is so that the FDA investigator can determine whether the use of pencil or white-out was used + original records have to be maintained at least 2 years.:beerdive:
harry
Welcome back Geochaz,
You had not been around for a while and we missed you.
W Physician Documentation System vs. Electronic Medical Record 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 5
G Good ISO 9001:2000 documentation and record management software Quality Assurance and Compliance Software Tools and Solutions 8
S Need ISO 15189:2012 Documentation toolkit. Document Control Systems, Procedures, Forms and Templates 0
H MD Technical Documentation and SALES possibility EU Medical Device Regulations 0
A DMDIV-Variants : definition and technical documentation CE Marking (Conformité Européene) / CB Scheme 4
NDesouza COTS Items CoC for FAI Documentation AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 12
P MDR/IVDR Annex III - Technical documentation on PMS EU Medical Device Regulations 1
I IATF Lab Scope Testing Qualification and Competency Documentation IATF 16949 - Automotive Quality Systems Standard 3
C Documentation hold during submissions? ISO 13485:2016 - Medical Device Quality Management Systems 0
K SOUP (Software of Unknown Provenance) Anomaly Documentation IEC 62304 - Medical Device Software Life Cycle Processes 2
C Gobys for operations documentation plan Oil and Gas Industry Standards and Regulations 4
C Refreshing an old and boring topic - Job descriptions and Roles vs Process Documentation ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 38
P Does anyone have a API Q1 Documentation Package? Quality Management System (QMS) Manuals 1
J Documentation structure - Do I need Work Instructions? Document Control Systems, Procedures, Forms and Templates 23
J Where to Place Process Maps in our Documentation? Process Maps, Process Mapping and Turtle Diagrams 4
C Manufacturing overages & nonconforming material documentation ISO 13485:2016 - Medical Device Quality Management Systems 3
Robert Stanley Required Documentation Templates ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
I Maintaining Technical Documentation under MDD and MDR EU Medical Device Regulations 1
M Basic UDI and technical documentation EU Medical Device Regulations 1
M What is the average time needed for process documentation? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
was named killer CLOUD BASED QUALITY DOCUMENTATION vs. SERVER BASED Document Control Systems, Procedures, Forms and Templates 5
S How to start with ISO process in project based team - Documentation Document Control Systems, Procedures, Forms and Templates 4
K ITAR Visitor Documentation of Citizenship AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
R Design Verification Documentation ISO 13485:2016 - Medical Device Quality Management Systems 19
A Process Documentation for ISO 9001:2015 Internal Auditing 2
F Process Review - What is the ISO requirement for reviewing SOPs and quality documentation? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
J Good Documentation Practices Self Test? ISO 13485:2016 - Medical Device Quality Management Systems 6
F ISO 17025:2017 mandatory documentation requirements ISO 17025 related Discussions 1
D Virtual Documentation via Master Flow Chart? Process Maps, Process Mapping and Turtle Diagrams 4
S Defining a Quality System from scratch - Preferred system and documentation names Document Control Systems, Procedures, Forms and Templates 4
C Maintenance of Product Technical Documentation EU Medical Device Regulations 3
F PPAP Documentation Control APQP and PPAP 8
V Every good documentation practice observation is an data integrity issue US Food and Drug Administration (FDA) 7
CPhelan Labeling template on QMS - Kitting and labeling documentation Manufacturing and Related Processes 9
DuncanGibbons Documentation aerospace OEMs require with purchase of parts from manufacturers/suppliers Manufacturing and Related Processes 0
V What is the criteria to cite an good documentation practices observation as an data integrity related issue US Food and Drug Administration (FDA) 6
L AS9100 D- Handling Nonconformance Documentation for an organization that outsources most of the work. AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 11
L ISO 9001:2015 standard documentation ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
N Time source for paper-based documentation (research nurses) US Food and Drug Administration (FDA) 1
W Documentation - Use of Addendum vs Amendment Document Control Systems, Procedures, Forms and Templates 1
I What level of change in documentation requires re-training? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
C Access to Technical Documentation - MDR Chapter VI Article 61 EU Medical Device Regulations 4
D QMS Documentation Process - I want to put all the Process SOPs to a QMS system Document Control Systems, Procedures, Forms and Templates 3
T QMS - Documentation Cloud Storage EU Medical Device Regulations 0
C Updates on Documentation for outsourced OEM from ISO 13485:2003 to ISO 13485:2016 ISO 13485:2016 - Medical Device Quality Management Systems 4
N EU MDR Basic UDI-DI and Technical Documentation for Systems EU Medical Device Regulations 22
B Quality Management System documentation identification Document Control Systems, Procedures, Forms and Templates 11
J Training documentation - ISO 13485 audit and the auditor had questions General Auditing Discussions 7
