Documentation for Returned Contaminated Medical Devices
Tiffany
Heyo,
I have a friend jus audited and being throw a question by the auditor, " do you have any documented procedure for handling of returned used medical devices from hospital in the case where you need to carry out investigation on this non-conformance used medical device"?
They hav been told that this procedure shall cover the scope on handling of this non-conformance used medical device from returned from end user until the investigation have been conducted.
My friend need the experts here to advise them, is there any requirements stated in ISO 13485 and MDD?
:thanx:
Tiff.....
Jimmy the Brit
Hi Tiff,
Are you talking about the disinfection of devices returned as customer complaints? I don't believe that this is covered in 13485, MDD or any other MD standard as it is a health and safety issue.
AAMI ST58: 2005 "Chemical sterilization and high-level disinfection in health care facilities" gives excellent guidance on the use of chemical sterilants to disinfect devices, and ASTM 1518, although intended for the disinfection of endoscopes, offers a clear methodology that is easy to follow.
The key thing to remember is that returned devices must be treated as biohazardous, and although every attempt must be made to clean and sterilize them, the health of the operator must come first, and sometimes that requires that devices are autoclaved before handling, especially if the device is massively contaminated with blood or faecal matter.
I hope I have interpreted your question properly, if not let me know and I will have another go,
Jimmy
Marcelo
Well, it seems to me that, in fact, it would be a "problable non-conformance" in which you have to investigate if it really is or isn´t a NC. This would be the first step. If it´s detected that it is a NC, there should be a investigation (based on the risk management of the device) to detect and correct the NC.
Anyway, this is not strictly required in any regulatory requirement that i know, but i don´t see how it would not be done. For example, in a risk management production and post-production survaillance system (which is a defined requirement from ISO 14971) there must be a procedure of this kind - this is also true in any survaillance system.
This kind of question seems to me as always like the old auditor/auditee debate. Surely there´s no way to handle the situation without a procedure, and in this case, as it´s not something you would always do, in practice i think this would have to be documented for the case it happens. But i think the auditor was, as always, a bit pushy in asking for a documented procedure. A better question would be
"how do you handle returned used medical devices from hospitals in the case where you need to carry out investigation on this possible non-conformance used medical device"
Q
QA-Man
There's many ways to look at this but either way it sounds like the auditor is absolutely right.
Here's two ways to look at it:
If it is a matter of contamination, look at 13485 6.4 d). You want to make sure returned product that has been used doesn't contaminate product you already have.
If its a matter of identification of returned product, look at 13485 7.5.3.1. You need to be able to identify the returned product.
Tiffany
Thanks for the advise and guidance here !
It is true that this a old auditor/ auditee debate!!!
I do agree to prepare this for the case it happen in future time.
They do understand that it shall control and mentioned in the handling of non-conformance product and they do practice the identification of the non-conformance product.
This is a sterilezed disposable medical devices (IV Cathether, Urine bag, and etc.). The auditor is mentioned a scenario that what if the hospital returned this NC - used product to the organization, do you have the procedure to carry out the laboratory investigation and handling of this NC-used product?
Is there any requirements mention in any of the standards?
The auditor insist to have documented procedure to carry out investigation (lab testing) and the handling during the investigation! And what if the organization would not have the facilities to conduct the lab investigation? This will expand the scope of the certification!
:bonk:
Tiff......
jckca
Our auditor has brought this up as well for a similar type device.
MD&DI has an article which you could write a procedure from in Sept 1999 issue. I can not link the article, but you should be able to find it.
harry
Welcome jckca,
I am sorry that you are unable to post a link. This is an anti-spam feature of the software that had helped us to thwart a lot of spammers.
Instead of an active link, you can post an inactive link - example: abc (dot) com and we well edit it for you. Thank you for your contribution.
joshua_sx1
…you can also try to check your local (or national) regulatory & statutory requirements for handling & returning contaminated medical devices…
…I believe this is the first thing you should consider (if there are) before going to international standards…
somashekar
Heyo,
:thanx:
Tiff.....
Please see ISO 13485:2003 clause 7.5.3.1. Identification
The organization SHALL establish documented procedure to ensure that medical devices returned to the organization are identified and distinguished from conforming products.
Also see 6.4 d) If appropriate, special arrangements SHALL be established and documented for the ....... etc.
You need to have one clear documented procedure how you will handle such a situation. The purpose is to identify, seperate, avoid mix up, prevent contamination of good ongoing products, environment and personnel.
please have a simple and clear procedure documented and implemented (or implementable) as the case is.
Good luck.
S Need ISO 15189:2012 Documentation toolkit. Document Control Systems, Procedures, Forms and Templates 0
H MD Technical Documentation and SALES possibility EU Medical Device Regulations 0
A DMDIV-Variants : definition and technical documentation CE Marking (Conformité Européene) / CB Scheme 4
NDesouza COTS Items CoC for FAI Documentation AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 12
P MDR/IVDR Annex III - Technical documentation on PMS EU Medical Device Regulations 1
I IATF Lab Scope Testing Qualification and Competency Documentation IATF 16949 - Automotive Quality Systems Standard 3
C Documentation hold during submissions? ISO 13485:2016 - Medical Device Quality Management Systems 0
K SOUP (Software of Unknown Provenance) Anomaly Documentation IEC 62304 - Medical Device Software Life Cycle Processes 2
C Gobys for operations documentation plan Oil and Gas Industry Standards and Regulations 4
C Refreshing an old and boring topic - Job descriptions and Roles vs Process Documentation ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 38
P Does anyone have a API Q1 Documentation Package? Quality Management System (QMS) Manuals 1
J Documentation structure - Do I need Work Instructions? Document Control Systems, Procedures, Forms and Templates 23
J Where to Place Process Maps in our Documentation? Process Maps, Process Mapping and Turtle Diagrams 4
C Manufacturing overages & nonconforming material documentation ISO 13485:2016 - Medical Device Quality Management Systems 3
Robert Stanley Required Documentation Templates ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
I Maintaining Technical Documentation under MDD and MDR EU Medical Device Regulations 1
M Basic UDI and technical documentation EU Medical Device Regulations 1
M What is the average time needed for process documentation? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
was named killer CLOUD BASED QUALITY DOCUMENTATION vs. SERVER BASED Document Control Systems, Procedures, Forms and Templates 5
S How to start with ISO process in project based team - Documentation Document Control Systems, Procedures, Forms and Templates 4
K ITAR Visitor Documentation of Citizenship AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
R Design Verification Documentation ISO 13485:2016 - Medical Device Quality Management Systems 19
A Process Documentation for ISO 9001:2015 Internal Auditing 2
F Process Review - What is the ISO requirement for reviewing SOPs and quality documentation? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
J Good Documentation Practices Self Test? ISO 13485:2016 - Medical Device Quality Management Systems 6
F ISO 17025:2017 mandatory documentation requirements ISO 17025 related Discussions 1
D Virtual Documentation via Master Flow Chart? Process Maps, Process Mapping and Turtle Diagrams 4
S Defining a Quality System from scratch - Preferred system and documentation names Document Control Systems, Procedures, Forms and Templates 4
C Maintenance of Product Technical Documentation EU Medical Device Regulations 3
F PPAP Documentation Control APQP and PPAP 8
V Every good documentation practice observation is an data integrity issue US Food and Drug Administration (FDA) 7
CPhelan Labeling template on QMS - Kitting and labeling documentation Manufacturing and Related Processes 9
DuncanGibbons Documentation aerospace OEMs require with purchase of parts from manufacturers/suppliers Manufacturing and Related Processes 0
V What is the criteria to cite an good documentation practices observation as an data integrity related issue US Food and Drug Administration (FDA) 6
L AS9100 D- Handling Nonconformance Documentation for an organization that outsources most of the work. AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 11
L ISO 9001:2015 standard documentation ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
N Time source for paper-based documentation (research nurses) US Food and Drug Administration (FDA) 1
W Documentation - Use of Addendum vs Amendment Document Control Systems, Procedures, Forms and Templates 1
I What level of change in documentation requires re-training? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
C Access to Technical Documentation - MDR Chapter VI Article 61 EU Medical Device Regulations 4
D QMS Documentation Process - I want to put all the Process SOPs to a QMS system Document Control Systems, Procedures, Forms and Templates 3
T QMS - Documentation Cloud Storage EU Medical Device Regulations 0
C Updates on Documentation for outsourced OEM from ISO 13485:2003 to ISO 13485:2016 ISO 13485:2016 - Medical Device Quality Management Systems 4
N EU MDR Basic UDI-DI and Technical Documentation for Systems EU Medical Device Regulations 22
B Quality Management System documentation identification Document Control Systems, Procedures, Forms and Templates 11
J Training documentation - ISO 13485 audit and the auditor had questions General Auditing Discussions 7
D Documentation requirements for the new Medical Device Regulations (2019) CE Marking (Conformité Européene) / CB Scheme 5
Ashok sunder ISO 45001:2018 Documentation template Occupational Health & Safety Management Standards 4
