Documentation Required by IATF 16949 (Automotive QMS)
H
hjoul
I have been discussing the item about required documented process with several people, but consensus on the topic seems a though case.
What do you people understand in:
Shall have a documented process(es)
Shall document a/its process
Shall maintain a documented process
I counted 21 times documented process excluding documented system/policy.
Tx,
QualitySpirit
Re: IATF 16949 Required documentation
Hi, it is really a big change from documented procedure to documented process.
A process may be documented by a process identity card, flow chart, turtle diagram, with risk analysis.
elements of a process e.g. input, output, customer, supplier, with whom, with what, how, measurement, process owner, and associated risk analysis must be defined.
Peters
I'm very curious how rigorously it will be treated by the auditors.
Process flow-chart is enough or has to be the turtle elements or the process card?
Does it have to be shown on the map of the processes?
Stijloor
Sadly, the IATF standards writers have not been very consistent in their language use. "Documented" simply means that it has to be "written" (Electronically and/or hard copy) so that it can be used by those who depend on that information to perform their jobs. Don't get too wrapped up in the verbiage; do what makes sense for your Organization and its "Interested Parties."
All the best! :agree1:
Sidney Vianna
Post Responsibly
It must be defined in some form of media, such as a (textual) procedure, a flow chart, a process map, a diagram, pictorially, video, audio, or any combination thereof.
The concept behind "documenting processes" is the fact that processes that are "ill/poorly defined" and transmitted via tribal knowledge, word of mouth, verbal instructions only tend to deviate from the target. It is very difficult to deploy a process that is only defined inside the mind of a person. It is also very difficult to assess if the process is working as intended and is effective.
While overdocumenting a process is also a problem, it is much easier to apply lean practices to an inflated documentation package than to run an organization with processes that are not defined and clear to the workforce.
H
hjoul
IATF released the standard and that's it.
So many terms and definitions and no documented process, assuming the hole automotive world knows what's behind it.
Nevertheless it will be something as described in previous posts.
A turtle, adding ownership, stakeholders affected, risk and opportunities,...
dmp06
Not including the scope, policy, manual, etc.
1. Product safety (4.4.1.1.1)
2.******Calibration (7.1.5.2.1)
3.******Training (7.2.1)
4.******Internal auditor competency (7.2.3)
5.******Employee motivation and empowerment (7.3.2)
6.******Quality manual (7.5.1.1)
7.******Engineering specifications (7.5.3.2.2)
8.******Outsourced processes (8.4.2.1)
9.******Supplier monitoring (8.4.2.4)
10.**Change control (8.5.6.1)
11.**Control of rework (8.7.1.4)
12.**Repaired products (8.7.1.5)
13.**Non-conforming product (8.7.1.7)
14.**Problem solving (CA) (10.2.3)
15.**Error proofing (10.2.4)
16.**Continual improvement (10.3.1)
Q
QAMTY
First, try to define your quality Policy, after that, define objectives, such objectives must be sopported by all the processes.
E.G. if you define in your policy that your products have high quality, and you satisfy your customers, then in your objectives you will try to have in control what your policy says, additionaly define how are you to going to measure them (goals).
% of Corrective actions closures, % of audits, % of customer satisfaction, % of rejected products, % on time delivery,etc.
On the web there are plenty of information on this matter.
Regards
dmp06
First steps are to define the context, identify internal and external issues, risks and opportunities, relevant interested parties and needs and expectations, before establishing any objectives.
AthenaMZ
I must disagree.
Presumably, the OP is not starting a business. They are merely inquiring about IATF documentation requirements, a few of which are new with this revision. The organization is busy running, so hjoul can focus on documenting only what makes sense.
If you document anything and everything, hoping to get back to it later and shave the volume of documentation down to a more sensible level, that may never happen, and then you're stuck with a bloated documentation system that is draining your organization of resources and causing non-conformances. Heh, just like the documentation system of the company I was just hired on with. Less than 100 people and highly-automated, robot technology on the shop floor, but almost 600 controlled procedures, work instructions, process flows and forms, rife with duplicate information and often rendered useless by oversimplification.
These days, documentation systems should be light on the documentation and heavy on the training records. Gone are the days of documenting every last step because, "What if someone is hit by a bus?" I am presenting to my new company on Thursday, the first step in what will be a loooooong process of turning this ship around and getting these bad habits broken.
Hjoul, it is best to just not pick up the bad habits to begin with. There is an AIAG PowerPoint presentation that runs through the new version of the standard clause by clause. This should assist in your mission to define what is required. I can't link you to it because I am too new, but google "Automotive QMS Update IATF 16949:2016 September 2016 - AIAG" and that should do it.
Yes, you must document those things the standard requires you to document. But how you do that is not up to a registrar, and don't you let them tell you otherwise. Do what is most effective for YOUR organization. If your organization is small, and you keep your documentation minimal, it might make sense to ask the end users what format would be most useful to them.
Good luck!
P AS9100D clause 8.6 - Documentation required to show evidence of conformity AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
Robert Stanley Required Documentation Templates ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
S Is Software code documentation required for FDA premarket submissions? IEC 62304 - Medical Device Software Life Cycle Processes 2
V PPAP documentation - Submission required in English APQP and PPAP 3
M Level 3 Documentation - Required or Fluff? Document Control Systems, Procedures, Forms and Templates 6
R ISO 22000:2005 Clause 7.10.4 Withdrawal - Applicability and documentation required? Food Safety - ISO 22000, HACCP (21 CFR 120) 3
A ISO 50001 Implementation Documentation Required Sustainability, Green Initiatives and Ecology 6
A Class IIa Annex II CE Marking - Required Tests and Documentation CE Marking (Conformité Européene) / CB Scheme 3
Q What documentation is required for Design Feasibility trial? ISO 13485:2016 - Medical Device Quality Management Systems 5
K ISO 9001 - Standard Documentation Template required? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
P What Documentation is required for CMMI? Examples wanted Software Quality Assurance 3
sagai Required Documentation for 820.25(b) - What does "Training shall be documented" mean 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 15
U What Legal Documentation is required for Receiving Inspection of Parts Federal Aviation Administration (FAA) Standards and Requirements 1
L Validation and documentation activities required for a custom-made software Qualification and Validation (including 21 CFR Part 11) 2
T Level of Documentation and Records required for ISO 9001 in a Small Business ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
D Tips/Documentation samples required for X-ray Film Processor Installation needed. ISO 13485:2016 - Medical Device Quality Management Systems 1
I ISO 9001:2000 - is Spanish translation of documentation required? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 24
M What is the Minimum Documentation Required for Medical Device Industry? ISO 13485:2016 - Medical Device Quality Management Systems 3
C Documentation required when doing a PPAP for a "Product Family" APQP and PPAP 7
T How much actual documentation is required on Shop Traveler and Documentation ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
A Documentation required for launch of a non-sterile exempt class 1 medical device ISO 13485:2016 - Medical Device Quality Management Systems 7
C Documentation required for AS9003 registration - More than for ISO 9001? Various Other Specifications, Standards, and related Requirements 3
M How much documentation history is required? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
L How Much Process Documentation is Required? We have 200+ products! ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
A Special Purpose Machines - What type of documentation and records are required? Records and Data - Quality, Legal and Other Evidence 1
Randy ISO 14001 - Clause 4.4.4 - Required EMS Documentation Miscellaneous Environmental Standards and EMS Related Discussions 13
K Is Level 2 Documentation required or necessary? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
M MDSW release documentation EU Medical Device Regulations 1
T Good Documentation Practices (GDocP) - Where are these described in the regulations? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 7
P Bankruptcy Provisions for availability of Technical Documentation EU Medical Device Regulations 5
Q Minimal Documentation Method & 4.2 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
B Technical Documentation EU Medical Device Regulations 4
D Swiss Documentation Requirements for Class 1 Medical Device Other Medical Device Related Standards 0
M Should DoC be updated every time Technical Documentation is revised? EU Medical Device Regulations 2
P Controls over Systems Documentation in 21 CFR Part 11 Qualification and Validation (including 21 CFR Part 11) 1
D Does the DoC require a technical documentation version? ISO 13485:2016 - Medical Device Quality Management Systems 1
Y EU MDR Technical Documentation - Defined Review EU Medical Device Regulations 3
E Discussion: How do you split up your Technical Documentation? EU Medical Device Regulations 4
B Technical Documentation for a medical device accessory Medical Device and FDA Regulations and Standards News 6
I Request for information regarding remote medical monitoring software (its technical documentation and the IUD system) IEC 62304 - Medical Device Software Life Cycle Processes 2
G Technical documentation for UKCA UK Medical Device Regulations 4
xfngrs Multi-lingual documentation IATF 16949 - Automotive Quality Systems Standard 6
R Configuration Management - Identifying Documentation IEC 62304 - Medical Device Software Life Cycle Processes 3
A Technical Documentation => Responsibilities when signing documents ISO 13485:2016 - Medical Device Quality Management Systems 7
A Update of Technical Documentation EU Medical Device Regulations 3
C FDA 510k documentation requirements US Food and Drug Administration (FDA) 1
M Documentation accompanying an aerospace part AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 6
G Seeking reference guides/ documentation /tips on verification best practices Other Medical Device Related Standards 6
P MDR documentation submissions EU Medical Device Regulations 4
dubrizo Good Documentation Practice (GDP) as it Applies to External Contractors or Vendors Document Control Systems, Procedures, Forms and Templates 4
