Documentation - When a procedure or document is changed (updated, obsoleted etc)
chaosweary
Is there a requirement in the ISO 9001 or TS 16949 that requires that affected personnel be contacted or communicated to, when a procedure or document is changed (updated, obsoleted etc)? Just can find the reference off the top of my head even though it is common sense.
:thanx:
ddunn
ISO 9001 4.2.3.2d "relevant versions of applicable documents are available at points of use" and 4.2.3.2g "prevent the unintended use of obsolete documents"
These paragraphs would imply that affected personnel be contacted or communicated to, when a procedure or document is changed.
There is no notification requirement. Employees need to be aware that they are responsible for insuring the currency of documents they use. 4.2.3.2(d) and (g) can both be accomplished without notification.
RoxaneB
:thanx:
Define "contacted or communicated to", please. I ask only because if this is in regards to training, while there is no requirement which clearly states "The organization shall contact or communicate changes to documentation to affected personnel", the intent is definitely in ISO 9001...albeit in a rather circular way.
6.2.2 - Folks will be competent and the organization determines what competent means (i.e., I would think that this would include being up to speed on existing documentation)
7.1 - Establishing documentation necessary to ensure product meets requirements. Logically, personnel impacted by this documentation would be trained on current document and future modifications.
7.5.1 - Availability of work instructions...and people trained on them and how to find them and understand them.
8.5.2 - Have you determined a lack of knowledge on the current documentation to be root cause? If so, you may wish to communicate future changes to affected personnel to reduce the likelihood of the problem occurring again.
chaosweary
Intent
I understand the intent. The trouble is selling it after you have written an area up and cited 4.2.3 and 8.5.2 and they want to "discuss the point". I may have to lessen it to an opportunity for improvement than a finding since I can find no instances where the absence of notification has caused a non-conformity. I was hoping :cfingers: for the manual to just jump out and state it.
Many thoughtful insights, :thanx:
RoxaneB
Without understanding the full situation, I will admit to being confused to citing 4.2.3 and 8.5.2 in conjunction with "notifying" personnel on changes. Granted, if the whole issue is notifying, there is a possible Opportunity for Improvement here. If the issue is a lack of training for affected personnel, then I don't think the properly clauses were linked into the nonconformance. Just my two cents.
The closest thing to a requirement is 4.2.3.c to ensure that changes...are identified., and the requirement for training of the users of the documents in question.
While it does not specifically require that you notify other interested parties, it implies a requirement to notify users in order to train.
Caster
An Early Cover
De ISO fy it
Ah un common sense. I have never won a battle quoting the requirements.
I suggest you fall back and start again from business world. Forget ISO.
I had just such a case. I asked the author to give me a copy of their changed document. I tore it up and threw it in the trash.
When they asked why, I said no one needs this document.
They insisted it was needed. I asked how anyone knew about the latest change.
They said cause I told them.
I said, then I'll change our procedures to state that you communicate all work methods and subsequent changes verbally. And my job is done because it meets ISO requirements. But your job is going to get really interesting, really soon.
They are like kids in a temper tantrum, they know they are being bad but the want and need someone to stop them, because they can no longer help themselves.
Good luck, let us know what happens
Scoobz
There is a requirement within ISO9001:2000 relating to Human Resources that should be considered:
"6.2.1 General
Personnel performing work affecting product quality shall be competent on the basis of appropriate education, training, skills and experience."
How then can you justify that a person is 'suitably trained' to perform a task if they are not aware of the current procedures? You can't. Therefore, if it essential that dissemination of information is transparent and complete. Procedural controls shall be provided for the use of all personnel who require them and those people shall be adequately trained in the content of the procedure to assure the quality of the product.
Quoting any reference to a Regulatory Inspector does NOT justify something but it helps as a background. You must then apply justified rationale to your actions. I find it doubtful that an Inspector/Auditor would be satisfied by being told documents are published but not provided or trained to staff. Therefore, some sort of communication must take place.
Personally, it is logical that each process (procedure) has an 'owner' and it is they who shall be notified when a document is published. It is then their responsibility to cascade that information to the relevant personnel and to assure they are competent.
K Documentation System Requirements and Document Format procedure - 3.0 Reference Document Control Systems, Procedures, Forms and Templates 7
K IT Software Documentation Procedure IT (Information Technology) Service Management 3
I ISO 9001:2008 4.2 Documentation - Where to put a Procedure Quality Manager and Management Related Issues 7
M Documentation of Who Approves a Level 2 Procedure Document Control Systems, Procedures, Forms and Templates 3
A Procedure for Translating User Documentation to comply with MEDDEV 2.5/5 Other Medical Device Regulations World-Wide 14
S Compliance Procedure - Compliance Documentation (SOX) Document Control Systems, Procedures, Forms and Templates 5
A Internal Audit Procedure Change from documentation to implementation...Help! ISO 13485:2016 - Medical Device Quality Management Systems 1
D Supplier Evaluation Procedure - What documentation should we request from suppliers? Document Control Systems, Procedures, Forms and Templates 4
F Help writing a first documentation procedure Document Control Systems, Procedures, Forms and Templates 4
S Need ISO 15189:2012 Documentation toolkit. Document Control Systems, Procedures, Forms and Templates 0
H MD Technical Documentation and SALES possibility EU Medical Device Regulations 0
A DMDIV-Variants : definition and technical documentation CE Marking (Conformité Européene) / CB Scheme 4
NDesouza COTS Items CoC for FAI Documentation AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 12
P MDR/IVDR Annex III - Technical documentation on PMS EU Medical Device Regulations 1
I IATF Lab Scope Testing Qualification and Competency Documentation IATF 16949 - Automotive Quality Systems Standard 3
C Documentation hold during submissions? ISO 13485:2016 - Medical Device Quality Management Systems 0
K SOUP (Software of Unknown Provenance) Anomaly Documentation IEC 62304 - Medical Device Software Life Cycle Processes 2
C Gobys for operations documentation plan Oil and Gas Industry Standards and Regulations 4
C Refreshing an old and boring topic - Job descriptions and Roles vs Process Documentation ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 38
P Does anyone have a API Q1 Documentation Package? Quality Management System (QMS) Manuals 1
J Documentation structure - Do I need Work Instructions? Document Control Systems, Procedures, Forms and Templates 23
J Where to Place Process Maps in our Documentation? Process Maps, Process Mapping and Turtle Diagrams 4
C Manufacturing overages & nonconforming material documentation ISO 13485:2016 - Medical Device Quality Management Systems 3
Robert Stanley Required Documentation Templates ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
I Maintaining Technical Documentation under MDD and MDR EU Medical Device Regulations 1
M Basic UDI and technical documentation EU Medical Device Regulations 1
M What is the average time needed for process documentation? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
was named killer CLOUD BASED QUALITY DOCUMENTATION vs. SERVER BASED Document Control Systems, Procedures, Forms and Templates 5
S How to start with ISO process in project based team - Documentation Document Control Systems, Procedures, Forms and Templates 4
K ITAR Visitor Documentation of Citizenship AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
R Design Verification Documentation ISO 13485:2016 - Medical Device Quality Management Systems 19
A Process Documentation for ISO 9001:2015 Internal Auditing 2
F Process Review - What is the ISO requirement for reviewing SOPs and quality documentation? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
J Good Documentation Practices Self Test? ISO 13485:2016 - Medical Device Quality Management Systems 6
F ISO 17025:2017 mandatory documentation requirements ISO 17025 related Discussions 1
D Virtual Documentation via Master Flow Chart? Process Maps, Process Mapping and Turtle Diagrams 4
S Defining a Quality System from scratch - Preferred system and documentation names Document Control Systems, Procedures, Forms and Templates 4
C Maintenance of Product Technical Documentation EU Medical Device Regulations 3
F PPAP Documentation Control APQP and PPAP 8
V Every good documentation practice observation is an data integrity issue US Food and Drug Administration (FDA) 7
CPhelan Labeling template on QMS - Kitting and labeling documentation Manufacturing and Related Processes 9
DuncanGibbons Documentation aerospace OEMs require with purchase of parts from manufacturers/suppliers Manufacturing and Related Processes 0
V What is the criteria to cite an good documentation practices observation as an data integrity related issue US Food and Drug Administration (FDA) 6
L AS9100 D- Handling Nonconformance Documentation for an organization that outsources most of the work. AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 11
L ISO 9001:2015 standard documentation ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
N Time source for paper-based documentation (research nurses) US Food and Drug Administration (FDA) 1
W Documentation - Use of Addendum vs Amendment Document Control Systems, Procedures, Forms and Templates 1
I What level of change in documentation requires re-training? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
