Documented Information - Periodic Review of Documents? IATF 16949:2016 / ISO 9001:2015
brandieb1230
#32
That's the kind of bureaucracy expectation that adds no value and just creates animosity towards "quality professionals". If there is any question if the document reflects the current process, just go and check for yourself.
Creating a "record" that document has been reviewed and deemed current is just MUDA.
While I agree with you, I was always under the impression that if there isn't evidence of something than it didn't happen. Other than a walk of the document to prove it is still accurate every time it is in question- how would a company quickly be able to say- "Yes, this document is 7 years old- but it is accurate".
I see 7.5.2 - c- discusses review and approval for suitability and adequacy while creating and updating a document. That doesn't have any mention of a document that doesn't need changed.
The company I work for requires annual document reviews in our document control software as a means to have the "proof" that the document was reviewed- this is all at the direction of our corporate quality office. They believe it falls under 7.5.3.2 (A)- Use of the document. Was the document actually reviewed? probably not- people just go in and click - document ok and move onto their next task of the day..
Sidney Vianna
Post Responsibly
#33
That one and it's counterpart say-what-you-do-do-what-you-say are just two examples of archaic mental paradigms that are useless in terms of modern quality management.
There is a fundamental misunderstanding here. Documentation is NOT an end in itself. Documentation is ONE of many components that define and facilitate process control. The PROCESS OWNERS should be the ones with responsibility to ensure adequacy and currentness of any supporting piece of command media that enables true process control. If a risk-based thinking approach determines that we should have an annual mandatory review of every piece of command media in the system, then do it. But to establish that mandatory periodic review as the baseline, even when we don't have palpable risks of working with outdated documents, is senseless.
Johnnymo62
Haste Makes Waste
#34
Just have a line on the Internal Audit form/report where the Process Owner can sign that the current revision of documents is adequate.
Annual or whenever your Internal Audit is performed, is sufficient for the POs to vouch for their documents.
normzone
#35
Currently wading through a sea of documentation, some of it not touched for twenty years.
Sorting it into piles:
Forget these, we don't do that any more
Of value to historians re products still in the field, but not requiring update
Requiring update for real
Fine as is
Sidney Vianna Release of ISO 10013:2021, Quality management systems – Guidance for documented information Other ISO and International Standards and European Regulations 0
C Missing routers/documented information Nonconformance and Corrective Action 5
K AS9100D Clause 7.5.2.a) - What is considered to be "documented information"? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
Q AS9120 7.5.3.2 Control of Documented Information - Audit Nonconformance AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 20
L VDA 1 Documented Information and Retention (new revision 4, August 2018) VDA Standards - Germany's Automotive Standards 0
P Retained Documented Information for Management Reviews ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 11
A How to Handle Documented Information in an online database for ISO 9001:2015 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
E IATF 16949 Cl. 7.1.5.1 - Documented information as evidence of fitness for purpose IATF 16949 - Automotive Quality Systems Standard 3
K Documented Information Turtle Diagram IATF 16949 - Automotive Quality Systems Standard 2
T Controlled Forms or documented requirements for records? ISO 13485:2016 - Medical Device Quality Management Systems 2
qualprod Documented actions and changes in the QMS by COVID 19 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
M Quality System Processes without Documented Procedures Document Control Systems, Procedures, Forms and Templates 39
C Significant Organizational Changes - Documented Responsibilities Document Control Systems, Procedures, Forms and Templates 4
B Documented process for type and extent of control IATF 16949 - Automotive Quality Systems Standard 6
K Documented problem solving and documented error-proofing - IATF 16949 10.2.3 & 10.2.4 Internal Auditing 7
Q Stage 1 audit observations - documented report? General Auditing Discussions 5
H Documented processes required by IATF 16949 section 4.4.1 IATF 16949 - Automotive Quality Systems Standard 1
H New IATF 16949 required Documented Processes IATF 16949 - Automotive Quality Systems Standard 5
S ISO 13485 Cl. 5.4.2 - Is Documented Quality Planning required? ISO 13485:2016 - Medical Device Quality Management Systems 2
B IATF 16949 Cl. 7.3.2 - Documented Process (Effectiveness & Efficiency) IATF 16949 - Automotive Quality Systems Standard 7
R IATF requirement of Documented QMM incorporation of CSR's into the processes? IATF 16949 - Automotive Quality Systems Standard 2
Q Risk Based Thinking - Is a Documented Procedure required? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 15
S ISO9001:2015 Cl. 4.4.1 - What Processes Do I Need Documented ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
S ISO 9001:2015 - Required Processes and required Documented Processes ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
M [Student] Documented Process vs Documented Procedure IATF 16949 - Automotive Quality Systems Standard 5
A Documented Processes as per IATF16949 - Requirements for Turtle Diagrams IATF 16949 - Automotive Quality Systems Standard 3
R How to Control Videos as part of the QMS Documented Procedures and Instructions Document Control Systems, Procedures, Forms and Templates 2
A ISO 9001:2015 Clause 9.3.2 - Management Review Inputs must be Documented? Management Review Meetings and related Processes 15
N Must Bioburden Sampling Procedures be Documented? Other Medical Device Related Standards 5
W Documented Problem-Solving for Automotive IATF 16949 - Automotive Quality Systems Standard 4
Ninja What is the most useless {real} documented procedure you've seen? Coffee Break and Water Cooler Discussions 4
Q "Documented Procedure" Health Canada Canada Medical Device Regulations 8
T Notification of affected parties of Updated Documented Procedures ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
T AS9100C Processes which need to be documented AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 7
C AS9100 Requirement Definition - Defined vs. Documented AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 14
J Can the mandatory procedures of ISO 9001-2008 be documented within one procedure? Document Control Systems, Procedures, Forms and Templates 5
J Recycling Procedure (ISO9001) - Do I need a documented process ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
C ISO 13485 - Documented Requirements for Risk Management ISO 13485:2016 - Medical Device Quality Management Systems 6
M HACCP vs. ISO 22000 Documented Procedure requirements Food Safety - ISO 22000, HACCP (21 CFR 120) 1
somashekar What are the ISO 13485 documented requirements for Risk Management? ISO 13485:2016 - Medical Device Quality Management Systems 13
somashekar What documented procedure in this case ... ISO 13485:2016 - Medical Device Quality Management Systems 5
P What should be documented for Qualitative Test results for the FDA? US Food and Drug Administration (FDA) 3
L Documented procedures requirements for AS9100C requirement 7.5.1 a) AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
A Should the FSMS have a Documented Generic Procedure for Verification and Validation Food Safety - ISO 22000, HACCP (21 CFR 120) 2
S Are Records Forms which should be Documented? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 13
T Requirement for a Documented Process for the Review and Release of Product For Sale ISO 13485:2016 - Medical Device Quality Management Systems 6
Q Core Process without a Documented Procedure ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
JoCam NADCAP AC7120 Rev A to B Documented Procedures Requirements Changes AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
