Documenting 5S Guidelines in the Sales Department (Office 5S)
amariepsu
Does anyone have experience documenting 5S guidelines?
I'm being asked the 'best method' to document the 5S standards developed in the sales department. (Basically, it was an office 5S) I was given a powerpoint and a word document with notes, and I want to combine the two as an overall guideline.
Are there best practices already in place for this?
Please advise.
Marc
Another quick "Bump". Can anyone help with this one? My Thanks in advance!
H
Hodgepodge
Please advise.
Documentation of the methods and tools used in your 5S program should be done in the clearest and most usable manner. The thinking and planning behind determining the 5S methods could/should also be applied to the documentation format. Instructions should be descriptive enough to effectively remind the user how to perform a task, or where the form is (or whatever) even if it is rarely used.
For example, a poster by the copy machine showing how to use the different features would be a great idea. If the poster is difficult to decipher, and an employee has to ask another employee what something means ("What the heck does collate mean?"), or where the button is, etc. the poster is not good enough. Documentation methods may need to be determined with input from the group, using the same focus the group used to develop the 5S methodologies. One part of 5S is that instructions are used. Otherwise they are wasteful and should be removed.
Sometimes you will see a website or use a program that has help features. A “What Does This Mean?” button or description of a form field on-hover is a 5S instruction incorporated directly into the tool you are using to perform a task. These types of instruction reduce the need for a more formal documentation of a 5S program. Also, there are times when a well planned form can make an instruction obsolete.
Labels and signs can be used to help organize a work room or station. The labels, if effective, are the documentation. A sign on a cabinet that states, “Office Supplies”, won’t be effective. Signs can serve two purposes, 1) they are instructions or labels, and 2) they play a part in the fifth S, Sustain. They can be reminders or reinforcement of good 5S behaviors. Effective signage and labeling can reduce the need for a more formal document.
Why a specific tool or method is used may not always be obvious. When this is the case, be sure to include the reason in the instruction
How any group utilizes the 5S principles will be completely unique to your office, the work being performed and the tools used. The same is true for documentation of instructions. It will be difficult to determine the best method to document your methods without firsthand experience in your office. A photo of a work station with circles and arrows and a description of what each tool is may all the formal documentation you need. After all, a well planned station can make it obvious to even an outsider what and how something is done. Your group can work together to determine the best methods of documentation for your system. If you use this method, it is likely you will find areas for even more improvements. A Power Point presentation and/or Word documents can be effective. If you want to document your entire 5S program in one presentation or Word file, do so in a manner consistent with your training practices. Your 5S training program could then also be the instructions or reference material.
The bottom line is to keep it simple. Have only what your group needs. After all, that is the point of 5S.
T Documenting hazardous situations associated with user/patient population ISO 14971 - Medical Device Risk Management 3
S Documenting Design Verification Test Results (ISO 9001) Design and Development of Products and Processes 1
adir88 Documenting Risk Control Option Analysis ISO 14971 - Medical Device Risk Management 8
M Defining and Documenting Record Retention CE Marking (Conformité Européene) / CB Scheme 5
J Documenting a Calibration Interval Extension Calibration Frequency (Interval) 7
B Documenting hardware on Form 2 of AS9102 AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
bryan willemot Documenting past problem history for fasteners for AS9100 Rev D AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
Q Documenting Customer Complaints (Records) Customer Complaints 6
R Documenting Expiration Date Extension for a specific lot ISO 13485:2016 - Medical Device Quality Management Systems 12
J ISO 13485:2016 Section 6.2 - Documenting the process for establishing competence ISO 13485:2016 - Medical Device Quality Management Systems 6
S Does IEC 62304 require documenting unresolved anomalies for all safety classes? IEC 62304 - Medical Device Software Life Cycle Processes 4
C Documenting Cleaning Production Lines in Medical Device Pkg facility ISO 13485:2016 - Medical Device Quality Management Systems 1
C Documenting Cleaning Production Lines in Medical Device Pkg facility 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 0
C Documenting Cleaning Production Lines in Medical Device Pkg facility 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 1
L Problems while documenting the SOUPs used for the software we are developing IEC 62304 - Medical Device Software Life Cycle Processes 4
R Documenting Self-Training and Effectiveness - ISO 13485:2016 Training - Internal, External, Online and Distance Learning 4
C Documenting Software Safety Classifications IEC 62304 - Medical Device Software Life Cycle Processes 4
B Approaches to Documenting an ISO 22000 FSMA Food Safety - ISO 22000, HACCP (21 CFR 120) 3
G Process for Product Safety - Ideas for Documenting Process for 4.4.1.2 IATF 16949 - Automotive Quality Systems Standard 3
dubrizo Are you documenting Internal Audit findings as NCRs? Internal Auditing 18
M What is the value of documenting in-process rework for easily-detectable issues? Quality Manager and Management Related Issues 4
R What is the typical industry standard for documenting Usability Risk? Human Factors and Ergonomics in Engineering 16
C Importance of Documenting NCP's and CA/PA's ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 23
D Documenting Meetings through Meeting Minutes or a Form ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
Colin Objectives Form - Format for Documenting Information Security Objectives IEC 27001 - Information Security Management Systems (ISMS) 2
O Documenting Processes requiring Customer Notification Misc. Quality Assurance and Business Systems Related Topics 2
M Documenting Vendor (Supplier) Issues Document Control Systems, Procedures, Forms and Templates 4
V Documenting Exceptions and use of Deviation Request Form APQP and PPAP 2
K AS9100 Clause 7.2.2 - Documenting "Special Requirements" and risks AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
K Competence, Training and Awareness - Documenting Training and Confidentiality Aspects ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 12
Q Documenting the Review of Adverse Effects from Rework ISO 13485:2016 - Medical Device Quality Management Systems 4
A Formal Way for Documenting Design Input Requirements 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 1
C Training Planning - Using Summary Sheet for Documenting Training Activities Training - Internal, External, Online and Distance Learning 3
J Requirements for Documenting Lifetime of a Medical Device ISO 13485:2016 - Medical Device Quality Management Systems 5
A Best Practice for Documenting Design Reviews 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 13
F Documenting Historical Preventive Action at a Daycare Preventive Action and Continuous Improvement 20
N Documenting Medical Device Complaints 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 6
R Documenting Quality Inspections - Material Released prior to Lot Acceptance Quality Manager and Management Related Issues 10
V Documenting the Root Causes for Internal Audit Non-Conformance Findings Problem Solving, Root Cause Fault and Failure Analysis 5
V Approach towards defining/documenting Requirements COTS vs. New-Product Software Quality Assurance 1
Crusader New Documenting Methods for Manufacturing Process Audits? Process Audits and Layered Process Audits 9
M Documenting an outsourced process - Distribution company with some manufacturing ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
P Process Map vs. User Guide - Documenting business procedures Process Maps, Process Mapping and Turtle Diagrams 3
T Documenting Effectiveness of Corrective/Preventive Action Nonconformance and Corrective Action 8
M Customer Format - Documenting Customer Software Requirement Specification and DDD Software Quality Assurance 10
D Documenting Machine Shop In-Process Checks Records and Data - Quality, Legal and Other Evidence 9
Crusader Continuous Improvements - How are you documenting them? Preventive Action and Continuous Improvement 66
R Documenting Processes such as Receiving Inspection, and Auditing to Turtle Diagrams Process Maps, Process Mapping and Turtle Diagrams 20
G Requirement for specified agendas and meeting minutes when documenting projects? Document Control Systems, Procedures, Forms and Templates 2
A Submit a 510(k) to an existing device vs. Just Documenting a Change ISO 13485:2016 - Medical Device Quality Management Systems 2
