Documenting a Calibration Interval Extension
We are in the process of extending the calibration interval of a class of IMTE (small Micrometers) based on a statistical analysis per NCSLI RP1. My question pertains to the instrument labeling and certificates required for documentation. We would like to do the next calibration at the extended time period, to skip the eliminated cycle, but the instruments are currently stickered and certified at the shorter interval. Is there any experienced guidance on options for documenting the new interval, short of recalibrating every IMTE to the new interval? For example, re-stickering them would address the individual gauge identification concern, but would we also need to have all new certificates printed (they are externally calibrated)? Could we prepare a "Blanket" document stating the Serial #s that have new dates vs. those on the current certificates and record that? Of course, simply re-calibrating them to the new interval is an obvious answer, but I'd like to know if this is the only option. Any experience or accepted practices would be appreciated.
dgriffith
Unless you have your own database and track intervals, recalls, and print your own labels (like we have), getting them recalibrated sounds expensive just for this. I would think an approved letter on file listing the tools would do, and present it to the auditor when needed. You could also slap a label with inspector's stamp on the tool or its storage box that has the new due date. Doesn't have to be pretty until next calibration.
I don't think you need new certs, either. They demonstarte as-found/left data, with other prescribed information, except the due date. That's your business, usually. Extending the interval doesn't change the cal cert validity (since it's only valid at time of calibration anyway).
dwperron
The problem I see is that if you do not change the calibration labels on the tools you could get a finding for having the incorrect due date on the tool. Yes, you have the calibration records updated, but they can get you for having the tool incorrectly labeled.
Most of the time I see the interval being changed for each unit the next time it comes in for calibration.
GunLake
Definitely change the stickers, (You can buy cheap labels online that you can hand write on, So no printer required if you don't have a label printer.) But don't worry about re printing the certificates, I would put in the notes of each micrometer in your calibration software that you extended the time period, From xx/xx/xxxx to xx/xx/xxxx. or however you'd like.
dwperron
Another question.
Have you created an internal policy regarding calibration intervals?
You will need to produce the procedure for determining the interval changes, even if it is just somebody reviewing calibration histories and determining the cycle should be longer. You will also need to document how you will change the intervals, how you will revise certificates, etc.
Thanks everyone. There is a lot of good advice here. We do have a calibration procedure that allows for the interval extension, based on a data review, and we also require verification of the cal date on each instrument at time of use, so new stickers are unavailable.
dgriffith
Remember labels do not have to be on instruments, especially in the case where the instruments are too small for a label to fit. The label can be on the next higher assembly or storage box or in a file as long as it’s accessible to show an auditor and reflects the current status of the MTE, which includes the new due date.
T Documenting hazardous situations associated with user/patient population ISO 14971 - Medical Device Risk Management 3
S Documenting Design Verification Test Results (ISO 9001) Design and Development of Products and Processes 1
adir88 Documenting Risk Control Option Analysis ISO 14971 - Medical Device Risk Management 8
M Defining and Documenting Record Retention CE Marking (Conformité Européene) / CB Scheme 5
B Documenting hardware on Form 2 of AS9102 AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
bryan willemot Documenting past problem history for fasteners for AS9100 Rev D AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
Q Documenting Customer Complaints (Records) Customer Complaints 6
R Documenting Expiration Date Extension for a specific lot ISO 13485:2016 - Medical Device Quality Management Systems 12
J ISO 13485:2016 Section 6.2 - Documenting the process for establishing competence ISO 13485:2016 - Medical Device Quality Management Systems 6
S Does IEC 62304 require documenting unresolved anomalies for all safety classes? IEC 62304 - Medical Device Software Life Cycle Processes 4
C Documenting Cleaning Production Lines in Medical Device Pkg facility ISO 13485:2016 - Medical Device Quality Management Systems 1
C Documenting Cleaning Production Lines in Medical Device Pkg facility 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 0
C Documenting Cleaning Production Lines in Medical Device Pkg facility 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 1
L Problems while documenting the SOUPs used for the software we are developing IEC 62304 - Medical Device Software Life Cycle Processes 4
R Documenting Self-Training and Effectiveness - ISO 13485:2016 Training - Internal, External, Online and Distance Learning 4
C Documenting Software Safety Classifications IEC 62304 - Medical Device Software Life Cycle Processes 4
B Approaches to Documenting an ISO 22000 FSMA Food Safety - ISO 22000, HACCP (21 CFR 120) 3
G Process for Product Safety - Ideas for Documenting Process for 4.4.1.2 IATF 16949 - Automotive Quality Systems Standard 3
dubrizo Are you documenting Internal Audit findings as NCRs? Internal Auditing 18
M What is the value of documenting in-process rework for easily-detectable issues? Quality Manager and Management Related Issues 4
R What is the typical industry standard for documenting Usability Risk? Human Factors and Ergonomics in Engineering 16
C Importance of Documenting NCP's and CA/PA's ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 23
D Documenting Meetings through Meeting Minutes or a Form ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
Colin Objectives Form - Format for Documenting Information Security Objectives IEC 27001 - Information Security Management Systems (ISMS) 2
O Documenting Processes requiring Customer Notification Misc. Quality Assurance and Business Systems Related Topics 2
M Documenting Vendor (Supplier) Issues Document Control Systems, Procedures, Forms and Templates 4
V Documenting Exceptions and use of Deviation Request Form APQP and PPAP 2
K AS9100 Clause 7.2.2 - Documenting "Special Requirements" and risks AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
K Competence, Training and Awareness - Documenting Training and Confidentiality Aspects ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 12
Q Documenting the Review of Adverse Effects from Rework ISO 13485:2016 - Medical Device Quality Management Systems 4
A Formal Way for Documenting Design Input Requirements 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 1
A Documenting 5S Guidelines in the Sales Department (Office 5S) Quality Tools, Improvement and Analysis 4
C Training Planning - Using Summary Sheet for Documenting Training Activities Training - Internal, External, Online and Distance Learning 3
J Requirements for Documenting Lifetime of a Medical Device ISO 13485:2016 - Medical Device Quality Management Systems 5
A Best Practice for Documenting Design Reviews 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 13
F Documenting Historical Preventive Action at a Daycare Preventive Action and Continuous Improvement 20
N Documenting Medical Device Complaints 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 6
R Documenting Quality Inspections - Material Released prior to Lot Acceptance Quality Manager and Management Related Issues 10
V Documenting the Root Causes for Internal Audit Non-Conformance Findings Problem Solving, Root Cause Fault and Failure Analysis 5
V Approach towards defining/documenting Requirements COTS vs. New-Product Software Quality Assurance 1
Crusader New Documenting Methods for Manufacturing Process Audits? Process Audits and Layered Process Audits 9
M Documenting an outsourced process - Distribution company with some manufacturing ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
P Process Map vs. User Guide - Documenting business procedures Process Maps, Process Mapping and Turtle Diagrams 3
T Documenting Effectiveness of Corrective/Preventive Action Nonconformance and Corrective Action 8
M Customer Format - Documenting Customer Software Requirement Specification and DDD Software Quality Assurance 10
D Documenting Machine Shop In-Process Checks Records and Data - Quality, Legal and Other Evidence 9
Crusader Continuous Improvements - How are you documenting them? Preventive Action and Continuous Improvement 66
R Documenting Processes such as Receiving Inspection, and Auditing to Turtle Diagrams Process Maps, Process Mapping and Turtle Diagrams 20
G Requirement for specified agendas and meeting minutes when documenting projects? Document Control Systems, Procedures, Forms and Templates 2
A Submit a 510(k) to an existing device vs. Just Documenting a Change ISO 13485:2016 - Medical Device Quality Management Systems 2
