Documenting Machine Shop In-Process Checks
DWPOZE
Registered Visitor
We are a machine shop. Our inspection plan ask our operators to check 2pcs/hour on some characteristics. Is it required by TS16949 to record there results of there hourly checks. Thanks for your help!!!:truce:
Gert Sorensen
Moderator
Re: Documenting In-Process Checks
If you don't record your tests, how are you going to assure yourself and the company purchasing the parts that they have been checked and conform to specifications?
You will have to show that you are implementing the product measurements required by the control plan etc. More than that, you have to have data (so check marks won't do) to be able to detect any trends. So, variables data (or attributes, through the gauging system) are the preferred method. A control chart would be the most appropriate, but not absolutely necessary.
Your people should also be very careful about assigning a check on the basis of 'two per hour'. What is the validity of performing these checks in controlling product/process? If you make only 2 items in an hour it's a 100% check, if you make 10,000, the sample becomes less 'statistically significant' (you do the math, it's too early.........:notme:)
:2cents:
Bill Ryan - 2007
Gert and Andy bring up good, "common sensical", points, and there are any number of others - customer specific requirements notwithstanding. However, to anwer your specific question - No, TS16949 does explicitly demand that you record the results of the hourly checks.
rdd007
I know this is an old post, but ... where exactly does TS16949 'explicitly demand' that we record the results? We have a machine shop as well, and it could take longer to write down all of the measurements than to actually make the parts ... What is really needed for our business and to satisfy the audit requirement?
Stijloor
The results could be pass or fail, or evidence that the operator actually inspected the parts. Actual measurements may be required at PPAP submission.
Stijloor.
I'm not speaking for Bill Ryan, but his post reads as though he meant to say, "...does not explicitly demand..."
bobdoering
Stop X-bar/R Madness!!
I hate to bring this up, but recording results because TS16949 says so or not is really the worst rational. Other rationals to consider is if there is a problem, the data was relatively cheap insurance to determine when the problem started, and what lead up to it. Not collecting data "because it takes time" can cost you in the long term, with unnecessary sorts, recalls and weak corrective actions. There should be solid reasons to collect data, if one seriously considers the consequences of not having the data.
Of course, part of the problem is collecting incorrect data, and having that frustration drive you to not collect any data at all. I have seen that in machining operations. Some of that is discussed in Statistical process control for precision machining :cool:
rdd007
Bob:
yes ... i know that doing it only to meet the audit is a poor rationale; I'm just trying to understand what auditors expect/'demand' so that I can make the decisions of how to implement/improve our system between where we are now and what we will have for the audit.
btw, i like your book/approach very much ... we're going to be implementing that as well. SPC was always difficult any other way.
Bob:
I'm at a loss to understand why you need to be comfortable with what auditors demand or expect. They are there to audit what your system defines are your process controls (in this respect). Taken to extreme, you'd do something different each and every time another auditor turns up, since they all have their own biases.
Stop worrying about what auditors want to see - run your processes effectively, by your numbers! They can't argue with the numbers! (Well, if they do, find a new one!)
S Documenting Design Verification Test Results (ISO 9001) Design and Development of Products and Processes 1
adir88 Documenting Risk Control Option Analysis ISO 14971 - Medical Device Risk Management 4
M Defining and Documenting Record Retention CE Marking (Conformité Européene) / CB Scheme 4
J Documenting a Calibration Interval Extension Calibration Frequency (Interval) 7
B Documenting hardware on Form 2 of AS9102 AS9100, IAQG 9100, Nadcap and related Aerospace Standards and Requirements 5
bryan willemot Documenting past problem history for fasteners for AS9100 Rev D AS9100, IAQG 9100, Nadcap and related Aerospace Standards and Requirements 2
Q Documenting Customer Complaints (Records) Customer Complaints 6
R Documenting Expiration Date Extension for a specific lot ISO 13485:2016 - Medical Device Quality Management Systems 12
J ISO 13485:2016 Section 6.2 - Documenting the process for establishing competence ISO 13485:2016 - Medical Device Quality Management Systems 6
S Does IEC 62304 require documenting unresolved anomalies for all safety classes? IEC 62304 - Medical Device Software Life Cycle Processes 4
C Documenting Cleaning Production Lines in Medical Device Pkg facility ISO 13485:2016 - Medical Device Quality Management Systems 1
C Documenting Cleaning Production Lines in Medical Device Pkg facility 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 0
C Documenting Cleaning Production Lines in Medical Device Pkg facility 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 1
L Problems while documenting the SOUPs used for the software we are developing IEC 62304 - Medical Device Software Life Cycle Processes 4
R Documenting Self-Training and Effectiveness - ISO 13485:2016 Training - Internal, External, Online and Distance Learning 4
C Documenting Software Safety Classifications IEC 62304 - Medical Device Software Life Cycle Processes 4
B Approaches to Documenting an ISO 22000 FSMA Food Safety - ISO 22000, HACCP (21 CFR 120) 3
G Process for Product Safety - Ideas for Documenting Process for 4.4.1.2 IATF 16949 - Automotive Quality Systems Standard 3
dubrizo Are you documenting Internal Audit findings as NCRs? Internal Auditing 18
M What is the value of documenting in-process rework for easily-detectable issues? Quality Manager and Management Related Issues 4
R What is the typical industry standard for documenting Usability Risk? Human Factors and Ergonomics in Engineering 16
C Importance of Documenting NCP's and CA/PA's ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 23
D Documenting Meetings through Meeting Minutes or a Form ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
Colin Objectives Form - Format for Documenting Information Security Objectives IEC 27001 - Information Security Management Systems (ISMS) 2
O Documenting Processes requiring Customer Notification Misc. Quality Assurance and Business Systems Related Topics 2
M Documenting Vendor (Supplier) Issues Document Control Systems, Procedures, Forms and Templates 4
V Documenting Exceptions and use of Deviation Request Form APQP and PPAP 2
K AS9100 Clause 7.2.2 - Documenting "Special Requirements" and risks AS9100, IAQG 9100, Nadcap and related Aerospace Standards and Requirements 1
K Competence, Training and Awareness - Documenting Training and Confidentiality Aspects ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 12
Q Documenting the Review of Adverse Effects from Rework ISO 13485:2016 - Medical Device Quality Management Systems 4
A Formal Way for Documenting Design Input Requirements 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 1
A Documenting 5S Guidelines in the Sales Department (Office 5S) Quality Tools, Improvement and Analysis 4
C Training Planning - Using Summary Sheet for Documenting Training Activities Training - Internal, External, Online and Distance Learning 3
J Requirements for Documenting Lifetime of a Medical Device ISO 13485:2016 - Medical Device Quality Management Systems 5
A Best Practice for Documenting Design Reviews 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 13
F Documenting Historical Preventive Action at a Daycare Preventive Action and Continuous Improvement 20
N Documenting Medical Device Complaints 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 6
R Documenting Quality Inspections - Material Released prior to Lot Acceptance Quality Manager and Management Related Issues 10
V Documenting the Root Causes for Internal Audit Non-Conformance Findings Problem Solving, Root Cause Fault and Failure Analysis 5
V Approach towards defining/documenting Requirements COTS vs. New-Product Software Quality Assurance 1
Crusader New Documenting Methods for Manufacturing Process Audits? Process Audits and Layered Process Audits 9
M Documenting an outsourced process - Distribution company with some manufacturing ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
P Process Map vs. User Guide - Documenting business procedures Process Maps, Process Mapping and Turtle Diagrams 3
T Documenting Effectiveness of Corrective/Preventive Action Nonconformance and Corrective Action 8
M Customer Format - Documenting Customer Software Requirement Specification and DDD Software Quality Assurance 10
Crusader Continuous Improvements - How are you documenting them? Preventive Action and Continuous Improvement 66
R Documenting Processes such as Receiving Inspection, and Auditing to Turtle Diagrams Process Maps, Process Mapping and Turtle Diagrams 20
Gert Sorensen Requirement for specified agendas and meeting minutes when documenting projects? Document Control Systems, Procedures, Forms and Templates 2
A Submit a 510(k) to an existing device vs. Just Documenting a Change ISO 13485:2016 - Medical Device Quality Management Systems 2
D Documenting Revision History - Single ?Revision Record? Document Document Control Systems, Procedures, Forms and Templates 4
