Documenting Self-Training and Effectiveness - ISO 13485:2016
rm3chris
I'm a part of an organization that is moving to ISO 13485:2016. We currently do NOT have an lms which is troublesome. How do we track self-training using paper training forms, then be able to justify training was effective? I have years of experience with lms', but in this company we are relying on spreadsheets and paper.
Any insight would be gratefully appreciated.
yodon
Bear in mind that little note at the end of section 6.2:
The methodology used to check effectiveness is proportionate to the risk associated with the work for which the training or other action is being provided.
If (ineffectiveness of) the training could lead to risk, you probably want to assess one way; e.g., some kind of immediate assessment; whereas if it would not lead to risk, you could take a more relaxed approach; e.g., annual employee performance review (did your work comply with the training - if so, check, effective).
RoxaneB
I'm presuming the training form you mention is simply something that has the person's name and position, along with the training material/subject and date. If this presumption of mine is true, then what you have is simply a (self) declaration of qualification; it has very little to do with the effectiveness of the training.
Most processes have metrics or ways of measuring their results.
Let's say you were training people on an improvement to the process of making widgets - say a new piece of equipment that is faster and more accurate. By measuring and monitoring items such as utilization, defective product, machine uptime, etc., you can assess training effectiveness. If, for example, the % of defective products remained unchanged (or worsened), perhaps the people were not effectively trained on how to properly use the new machine.
This type of assessment on the effectiveness of training could take some time.
If you're looking for a more immediate evaluation of training effectiveness, you could implement tests at the end of training on priority processes. I'm not a huge fan of this approach as I find it's more about evaluating short-term memory than actual application of the training.
rm3chris
So I believe there is quite a bit of risk from the perspective of the training team not receiving training records back from employees who self-train (we wouldn't know training happened) and that we have a gap in checking for effectiveness being paper based. An lms would be ideal to train, track, assess, etc. This is a part of my gap analysis.
yodon
Whoops... I think I may have misled you. The risk is not the risk of failing to have records. The risk in the note is talking about the risk to the patient / user if the training is ineffective. So if the training is on something that could, if not done correctly, cause harm to a patient, your method of checking effectiveness needs to be elevated above that for training on things that wouldn't harm a patient / user if not done correctly.
For example, if you're training a person to do final testing on a device that delivers x-rays and the test is ensuring the emitter output is in the specified range, your effectiveness check on that will be different (more urgent, higher level of assessment) than that of training, say, to detect cosmetic defects in a device's plastic casing.
T Documenting hazardous situations associated with user/patient population ISO 14971 - Medical Device Risk Management 3
S Documenting Design Verification Test Results (ISO 9001) Design and Development of Products and Processes 1
adir88 Documenting Risk Control Option Analysis ISO 14971 - Medical Device Risk Management 8
M Defining and Documenting Record Retention CE Marking (Conformité Européene) / CB Scheme 5
J Documenting a Calibration Interval Extension Calibration Frequency (Interval) 7
B Documenting hardware on Form 2 of AS9102 AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
bryan willemot Documenting past problem history for fasteners for AS9100 Rev D AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
Q Documenting Customer Complaints (Records) Customer Complaints 6
R Documenting Expiration Date Extension for a specific lot ISO 13485:2016 - Medical Device Quality Management Systems 12
J ISO 13485:2016 Section 6.2 - Documenting the process for establishing competence ISO 13485:2016 - Medical Device Quality Management Systems 6
S Does IEC 62304 require documenting unresolved anomalies for all safety classes? IEC 62304 - Medical Device Software Life Cycle Processes 4
C Documenting Cleaning Production Lines in Medical Device Pkg facility ISO 13485:2016 - Medical Device Quality Management Systems 1
C Documenting Cleaning Production Lines in Medical Device Pkg facility 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 0
C Documenting Cleaning Production Lines in Medical Device Pkg facility 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 1
L Problems while documenting the SOUPs used for the software we are developing IEC 62304 - Medical Device Software Life Cycle Processes 4
C Documenting Software Safety Classifications IEC 62304 - Medical Device Software Life Cycle Processes 4
B Approaches to Documenting an ISO 22000 FSMA Food Safety - ISO 22000, HACCP (21 CFR 120) 3
G Process for Product Safety - Ideas for Documenting Process for 4.4.1.2 IATF 16949 - Automotive Quality Systems Standard 3
dubrizo Are you documenting Internal Audit findings as NCRs? Internal Auditing 18
M What is the value of documenting in-process rework for easily-detectable issues? Quality Manager and Management Related Issues 4
R What is the typical industry standard for documenting Usability Risk? Human Factors and Ergonomics in Engineering 16
C Importance of Documenting NCP's and CA/PA's ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 23
D Documenting Meetings through Meeting Minutes or a Form ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
Colin Objectives Form - Format for Documenting Information Security Objectives IEC 27001 - Information Security Management Systems (ISMS) 2
O Documenting Processes requiring Customer Notification Misc. Quality Assurance and Business Systems Related Topics 2
M Documenting Vendor (Supplier) Issues Document Control Systems, Procedures, Forms and Templates 4
V Documenting Exceptions and use of Deviation Request Form APQP and PPAP 2
K AS9100 Clause 7.2.2 - Documenting "Special Requirements" and risks AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
K Competence, Training and Awareness - Documenting Training and Confidentiality Aspects ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 12
Q Documenting the Review of Adverse Effects from Rework ISO 13485:2016 - Medical Device Quality Management Systems 4
A Formal Way for Documenting Design Input Requirements 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 1
A Documenting 5S Guidelines in the Sales Department (Office 5S) Quality Tools, Improvement and Analysis 4
C Training Planning - Using Summary Sheet for Documenting Training Activities Training - Internal, External, Online and Distance Learning 3
J Requirements for Documenting Lifetime of a Medical Device ISO 13485:2016 - Medical Device Quality Management Systems 5
A Best Practice for Documenting Design Reviews 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 13
F Documenting Historical Preventive Action at a Daycare Preventive Action and Continuous Improvement 20
N Documenting Medical Device Complaints 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 6
R Documenting Quality Inspections - Material Released prior to Lot Acceptance Quality Manager and Management Related Issues 10
V Documenting the Root Causes for Internal Audit Non-Conformance Findings Problem Solving, Root Cause Fault and Failure Analysis 5
V Approach towards defining/documenting Requirements COTS vs. New-Product Software Quality Assurance 1
Crusader New Documenting Methods for Manufacturing Process Audits? Process Audits and Layered Process Audits 9
M Documenting an outsourced process - Distribution company with some manufacturing ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
P Process Map vs. User Guide - Documenting business procedures Process Maps, Process Mapping and Turtle Diagrams 3
T Documenting Effectiveness of Corrective/Preventive Action Nonconformance and Corrective Action 8
M Customer Format - Documenting Customer Software Requirement Specification and DDD Software Quality Assurance 10
D Documenting Machine Shop In-Process Checks Records and Data - Quality, Legal and Other Evidence 9
Crusader Continuous Improvements - How are you documenting them? Preventive Action and Continuous Improvement 66
R Documenting Processes such as Receiving Inspection, and Auditing to Turtle Diagrams Process Maps, Process Mapping and Turtle Diagrams 20
G Requirement for specified agendas and meeting minutes when documenting projects? Document Control Systems, Procedures, Forms and Templates 2
A Submit a 510(k) to an existing device vs. Just Documenting a Change ISO 13485:2016 - Medical Device Quality Management Systems 2
