Documents for Manufacturing Environment
Al Rosen
#11
9001:2015 said:
7.5.3 Control of documented information
7.5.3.1 Documented information required by the quality management system and by this International
Standard shall be controlled to ensure:
a) it is available and suitable for use, where and when it is needed;
b) it is adequately protected (e.g. from loss of confidentiality, improper use, or loss of integrity).
#12
Part of this endless debate about what needs to be controlled is the understanding of what "control" actually means. Far too many organizations go overboard on "control" and do things which are actually a) not a control and b) are ineffective as a control.
If you have useful cards which the people like to use as a means to control process/product, what is it about a control that would prevent the cards from being "controlled"... (Ask your "ISO trainer" if they know the answer!)
John Broomfield
#13
I have teams in a manufacturing environment who want to create instruction cards to hang on the machines; do those cards have to be controlled documents?
ISO_Man,
Are your machine operators competent to operate their machines? If they are why do they need an instruction card on each machine?
Perhaps they are seeking to become competent, in which case they should be closely supervised if only for their safety.
Or they may just be trying to keep a traditional “ISO person” happy.
Please let us know.
Thanks.
John
RoxaneB
#14
It is more or less as you describe, but having worked in all the major areas where the documents are applied, I do have the knowledge to judge that a document is needed and/or correct.
Having worked in those areas is great. Always a plus to have a solid foundation in the business beyond just quality. But are there current process owners? If so, I'll be honest, I'd rather see their approval than the QM's.
Mike S.
Happy to be Alive
#15
Andy,
An ISO guidance doc defines control as such: Control - verb - direct, restrain or regulate
noun - power to direct, restrain or regulate; means of restraining or regulating
So what's the answer to your riddle, and how does it help the OP?
#16
Many organizations have taken "control" to mean some bizarre things, done in the name of "ISO", including giving documents a 14 digit numbering scheme. It's not a riddle, it's a perfectly legitimate question! What is understood - in their organization - by "control"?
Which one? If it's NOT the ISO 9000 normative reference, then the definition doesn't count...
Mike S.
Happy to be Alive
#17
ISO/TC176/SC1 N 400
ISO/TC176/SC1/WG1 N 318
ISO 9000 Introduction and support package:
Guidance on some of the frequently used words found in the ISO 9000 family of standards
2012 version
Jen Kirley
Quality and Auditing Expert
#20
The term procedure was changed to documented information in order to clarify that we can also have our instructions on flip charts, cards, videos, posters, signs, TV monitors etc. The point, as always, is that the information's user has ready access to clear, current, approved instructions. Control requirements in 7.5 apply, but not every document needs the same number or organizational-level approvals and obsolescence controls will also vary based on the media. I imagine these cards would function on the level of work instructions, which are also to be controlled but don't necessarily require the same methods as higher-level procedures. The organization decides the control methods.
An organization is also empowered to identify those with authority to approve the various kinds of documents. A past employer used a matrix approach for listing such approvers.
S "Contract Manufacturing" - How to review the existing ISO14001 documents ISO 14001:2015 Specific Discussions 1
M Manufacturing Software + Controlled Documents Document Control Systems, Procedures, Forms and Templates 10
M SOPs - Reference Documents Section Document Control Systems, Procedures, Forms and Templates 3
Dazza 9001, 14001 and 45001 mandatory documents and records cross reference matrix Process Maps, Process Mapping and Turtle Diagrams 2
M Documents to be included in 1.3 Material check in PPA report APQP and PPAP 4
J Requirement for Retention of Records of Withdrawn Documents of External Origin Document Control Systems, Procedures, Forms and Templates 3
T Sharing SharePoint Documents Document Control Systems, Procedures, Forms and Templates 4
M Retention period of documents and records ISO 13485:2016 - Medical Device Quality Management Systems 1
D Offsite storage of QMS documents ISO 13485:2016 - Medical Device Quality Management Systems 9
K Joint approval between OEM and Manufacturer on Design Documents ISO 13485:2016 - Medical Device Quality Management Systems 4
was named killer AS 9100D - Calibration Instructions - Controlled documents? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 6
N Audit non-compliance API Q1 - Use of External Documents 4.4.4 in Product Realization Oil and Gas Industry Standards and Regulations 8
C Corrective action for failure in documents control ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
A QMS Overhaul - Reorganizing and Renaming Documents - Internal References Document Control Systems, Procedures, Forms and Templates 24
J Controlled information versus defined documents / records ISO 13485:2016 - Medical Device Quality Management Systems 3
D DQ documents of new equipment - Function specification Qualification and Validation (including 21 CFR Part 11) 0
B Using Unreleased Documents & Process Maps for Internal Audit purposes ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 12
N Device Labeling - Medtronic Ventilator Files (Risk Management documents) Coffee Break and Water Cooler Discussions 2
qualprod To set frequency to review documents in ISO 9001 7.5? Document Control Systems, Procedures, Forms and Templates 13
S Mandatory documents vs shall "something" but without mandatory documents ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 17
I Reissuing documents due to missing version / issue numbers Document Control Systems, Procedures, Forms and Templates 3
I Dating controlled documents after changes - Revision History Document Control Systems, Procedures, Forms and Templates 13
M Advertising medical devices in the U.S - Advertising regulations or guidance documents Other US Medical Device Regulations 3
R Process control documents - Context of API Spec Q1, Clause 5.7.1.3 Other ISO and International Standards and European Regulations 0
C Identifying and Controlling External Documents Document Control Systems, Procedures, Forms and Templates 3
E Part 11 Compliance, Excel living documents (i.e. document master list, equipment list, approved supplier list) Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 3
M EU MDR - Annex II 3b - What documents fall under this requirement? EU Medical Device Regulations 3
H New 510K VS Documents about design change. Other US Medical Device Regulations 2
M Informational EU – Manufacturer incident report (MIR) for serious incident- template 2020 (Directives and new regulations) version 7.2 and related documents Medical Device and FDA Regulations and Standards News 2
M Informational EU – Some documents related to Call for expression of interest for expert panels on medical devices and in vitro diagnostic medical devices Medical Device and FDA Regulations and Standards News 0
R Implementing Design History Documents/ Technical Documents in the QMS ISO 13485:2016 - Medical Device Quality Management Systems 3
R Approvals on QMS Documents - ISO 13485 Requirements Document Control Systems, Procedures, Forms and Templates 2
K Mandatory Documents for EU authorized Representative under MDR CE Marking (Conformité Européene) / CB Scheme 8
Sidney Vianna Interesting Discussion Hello IAF. Are you listening? Please explain the inconsistency in your IAF Mandatory Documents (2019) ASQ, ANAB, UKAS, IAF, IRCA, Exemplar Global and Related Organizations 6
I QMS documents required at each stage of Software development IEC 62304 - Medical Device Software Life Cycle Processes 5
qualprod Controlling documents in two different Applications ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
R Do we need to treat local law as external origin documents? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 15
I Sales Documents in scope for ISO-9001:2015? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
shimonv Informational New guidance documents about EUDAMED - April 2019 EU Medical Device Regulations 1
M Which documents must be updated upon product validation? Document Control Systems, Procedures, Forms and Templates 1
L Digitalization of documents - FDA and ISO 13485 Other Medical Device Related Standards 1
G Correction fluid found on documents that are reviewed Qualification and Validation (including 21 CFR Part 11) 11
M Informational IMDRF – Proposed update to Clinical Evaluation documents Medical Device and FDA Regulations and Standards News 0
I R&D prototype documents need to be controlled? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
L OpEx (Operational Excellence) Documents in QMS? Document Control Systems, Procedures, Forms and Templates 0
N IATF 16949 - Mandatory Corporate Documents IATF 16949 - Automotive Quality Systems Standard 10
I Document levels and approval requirements for lower level documents like work instructions, forms etc. Document Control Systems, Procedures, Forms and Templates 18
N How to deal with catalog parts suppliers who refuse to submit PPAP documents? APQP and PPAP 0
