DOE (Design of Experiment) with Several Output Variables
sabrinalim
I'm recently tasked to do a Design of Experiment to optimise several press parameters. I have a few questions
1. We have identified several input variables to test. However the tricky part is we also have several (about 3-4) output variables (all measureable variables) that we need to optimise simultaneously. Is it possible to conduct one single set of DOE with where several output variables are tested simultaneously against our input variables? If yes , what if the optimum setting for one output variable may not be the same as the optimum setting for another output variable.
2. Or do I need to do some preliminary analysis to see if the output variables are related? If so what tools should we use? Multivariate analysis? Can a multi vari chart do the trick?
3. One prerequisite of DOE is to ensure the process is stable before attempting DOE. This is a fairly new process and we do not have enough data to run Xbar R charts. Will it suffice to plot individual chart (vs time) to see if there is any time related trends on the output parameters instead?
Thanks in advance
S Lim
David DeLong
Re: DOE with several output variables
I will assume that you are going to use a Taguch Array with 2 levels. If so the L4 can take 3 factors, L8 7 factors and and L16 15 factors. The factors may be either variable or attribute in nature.
All are tested simultaneously in a balanced manner.
Simultaneous optimization of multiple input factors will require Response Surface Methodology.
Do not start this process thinking that you can optimize your process after a single designed experiment. It typically will take a screening experiment to isolate significant factors and interactions. This may or may not take a follow-up experiment to isolate confounded/aliased factors/interactions. Once these are isolated, another experiment with multiple levels is required to determine whether curvature exists and how to best optimize. Finally a confirmation experiment must be run to validate the final model.
Tim Folkerts
I agree with Miner - you will probably need more that a single experiment to achieve your goals.
Let me address what I consider to be the main question. Assuming you have selected important input variables (perhaps from a screening experiment) and that you have run the appropriate trials for a response surface experiment, it is possible to use that information to optimize several output variables.
  • If all the output variables are optimized with the same values of the input variables, then when you have analyzed the experiments, you are basically done.
  • If the output variables are optimized with different values of the input variables, then you typically create a composite variable and optimize that single variable. As a simple example, if you want to maximize all the variables, you could create a new variable by adding together all the outputs. Then you would optimize this new variable.
Deciding how to combine the variables would take a bit of judgment. Minitab has this process of creating a composite variable built in.
You might want to consider EVOP (Evolutionary Operation) as an alternative to standard response surface designs. EVOP is more of a continuous improvement approach - making minor changes to an existing process.
Classic experimental design and Taguchi methods are revolutionary methodologies which help us to establish an optimum combination of the design factors and their proper levels for the manufacturing process. They are very powerful tools; but they cost money, time, manpower and require special training to conduct the experiments. In most cases, they interrupt production. Experimental design should be used in the design stage and trouble shooting to solve specific quality problem. It cannot be a routine operation. EVOP is a tool in which a continuous investigative routine becomes the basic mode of operation for the plant and replaces normal static operation.
This is from http://thequalityportal.com/articles/evop.htm Another link that looks promising is at http://www.visteon.com/utils/whitepapers/20_ccwdq.pdf (I have no connection to either of them - they came up in Google searches and looked pretty good first glance).
Tim Folkerts
B Design of Experiment (DOE) for Heat Treatment Process Statistical Analysis Tools, Techniques and SPC 4
M Design of Experiment (DOE) Help Needed Quality Tools, Improvement and Analysis 8
J Selecting factors for screening DoE design Statistical Analysis Tools, Techniques and SPC 8
J DoE (Design of Experiments) - Multiple responses with different factors Using Minitab Software 4
K Power point training slides on DOE (Design of Experiments) Wanted Training - Internal, External, Online and Distance Learning 2
N DOE (design of experiments) in Minitab 16 Using Minitab Software 6
D Minitab - Design combinations (DOE) Using Minitab Software 4
P When can we apply DOE (Design of Experiments)? Six Sigma 8
P Cyclic Effect Factoring in DOE (Design of Experiments) Quality Tools, Improvement and Analysis 1
J How to Estimate the Number of Replicates on a DOE (Design of Experiments) Six Sigma 5
K Minitab Lack-of-Fit Test in DOE (Design of Experiments) Using Minitab Software 4
M Taguchi L4 Orthogonal Array Design of Experiments (DOE) in an Excel spreadsheet Excel .xls Spreadsheet Templates and Tools 3
V Linking the FMEA Causes & Action Plan with DOE Experiments or Experimentation Design FMEA and Control Plans 1
P Help Setting Up and Analyzing 3 Factor 2 Level Full Factorial Design for DOE Using Minitab Software 3
B Taguchi DOE (Design of Experiments) example using Minitab Using Minitab Software 3
C 3 Factor DOE (Design of Experiments) Template Document Control Systems, Procedures, Forms and Templates 0
B Analyze 'Factorial Design' or 'Variability' - Difference when used for DOE Analysis? Using Minitab Software 1
L DOE (Design of Experiments) suggestions Using Minitab Software 7
L DOE (Design of Experiments) - Analyse Variation with Minitab Using Minitab Software 5
E 5^2 DOE (Design of Experiments) with 3 Replications, 5 Levels 2 Factors Statistical Analysis Tools, Techniques and SPC 6
R To Find Out Second Order Model from First Order Factorial Design (DOE) Using Minitab Software 9
M DOE (Design of Experiments) for 3 Variables, Many Levels Quality Tools, Improvement and Analysis 2
J DOE (Design of Experiments) Dependent Factors Using Minitab Software 1
C DOE (Design of Experiments) with 'Uncontrollable' Factors Using Minitab Software 5
Q DOE (Design of Experiments) for Accounting - New to Minitab need help Using Minitab Software 5
B Validation of DoE (Design of Experiements) Model - Minitab 15 Using Minitab Software 3
M DOE (Design of Experiments) - CQE Primer question Professional Certifications and Degrees 4
C Training courses for DOE (Design of Experiments) Training - Internal, External, Online and Distance Learning 3
P Taguchi method using Minitab - DOE (Design of Experiments) Help Quality Tools, Improvement and Analysis 7
S Sample Size Attribute DOE (Design of Experiments) Six Sigma 9
M Excel files for DOE (Design of Experiments) Excel .xls Spreadsheet Templates and Tools 6
T Minitab - Mixture DOE (Design of Experiments) - Sandability of a Gelcoat Using Minitab Software 5
C DoE and ANOVA - 4 factor and 3 levels Taguchi design with 2 replicates Using Minitab Software 14
R Custom DOE (Design of Experiments) Analysis in JMP Quality Tools, Improvement and Analysis 11
P Need help on DOE (Design of Experiments) - EPS molding process Quality Assurance and Compliance Software Tools and Solutions 2
A Good books on DOE (Design of Experiments) - Recommendations wanted Book, Video, Blog and Web Site Reviews and Recommendations 3
T Design of Experiments - DOE with Centre Point Using Minitab Software 7
Q Design of Experiments Using Subgroup Data - Conducting a 2^3 factorial DoE Quality Tools, Improvement and Analysis 6
T Screening DOE (Design of Experiments) with qualitative response Quality Tools, Improvement and Analysis 23
A The basics of DOE (Design of Experiments) & Validation Statistical Analysis Tools, Techniques and SPC 4
M Design of Experiments (DOE) - Help with homework problem Quality Tools, Improvement and Analysis 5
M DOE (Design of Experiments) with 3 factors with levels of 3,3 and 5 Quality Tools, Improvement and Analysis 3
S Multilevel Design in Minitab to conduct a DOE - 4 factors and each has 5 levels Design and Development of Products and Processes 4
P What if DOE (Design of Experiments) is not possible? Six Sigma 16
J DOE (Design of Experiments) for ultrasonically welding plastic lids Quality Tools, Improvement and Analysis 15
C Shainin and DOE (Design of Experiments) Information Misc. Quality Assurance and Business Systems Related Topics 2
Tim Folkerts DOE: Choosing a Design - Factors that affect the choice of design The Reading Room 0
A DOE - Design of Experiments? What does that mean? Quality Tools, Improvement and Analysis 5
P DOE (Design of Experiments) or Hypothesis test? Applicability and use of each? Six Sigma 7
T DOE (Design of Experiments) for Powder Coating Thickness Six Sigma 9
