DOE (Design of Experiments) or Hypothesis test? Applicability and use of each?
patkim
Registered Visitor
During Analyze Phase of Six Sigma Improvements, there are different tools and techniques. Some of them are DOE (design of Experiment) and Hypothesis Testing.
I wish to know how do the two differ with respect to applicability and use?
Thanks,
CalRich
DOE vs. Hypothesis testing
DOE is a statistical tool to examine the input factors and any response variables and their relative importance in affecting the process.
http://www.isixsigma.com/tt/doe/
Once you have acted on the process (i.e. made some change to hopefully improve), a hypothesis test is used to determine if what you believed would happen actually did happen. This compares samples to population parameters.
http://www.isixsigma.com/dictionary/Hypothesis_Testing-255.htm
DOEs are typically used to evaluate the effects of multiple factors and their potential interactions.
Hypothesis tests are more typically used to evaluate the effect of either changing a single factor or the effect of a single change of multiple factors.
Of the two, DOE is much more effective in modeling how the process responds to changes in the input factors.
Tim Folkerts
Let me second what has been said and add a few comments.
First of all, at its most basic level, "DOE" simply means a designed experiment. (As opposed to what - a random experiment???) Any experiment that has been planned to accomplish a specific purpose is a DOE
Traditionally, "DOE" has become synonymous with the use of a particular set of standard designs - 2 level factorials, central composite, Box-Behnken, Taguchi, ... These designs were created by experts so that they can efficiently accomplish specific purposes. When used properly, these designs are quite effective.
At some level, the standard designs are just sets of hypothesis tests performed simultaneously. For example, a 1 factor, 2 level factorial experiment tests 1 hypothesis: does changing Factor A make a difference? A 2 factor, 2 level full factorial tests 3 hypotheses: does changing Factor A make a difference, does changing Factor B make a difference, does changing both factors at the same time make a difference? As you add more factors and more levels, you have more hypothesis tests. When you do a frctional factorial, you remove some of the hypothesis tests.
I suppose you coud say that choosing the proper design allows testing of all the hypotheses you are interested in without too much extra work.
Tim F
Statistical Steven
Statistician
I agree with the comments made by Tim, and would add a few additional comments and observations.
1. Hypothesis testing is a subset of DOE. All DOEs are setup based on a hypothesis (Is level 1 different than level 2 for a given factor, does Factor 1 and Factor 2 interact,etc.).
2. It is ironic how when asked to explain statistical concepts, the links quoted are from isixsigma.com. There are far better resources available to understand statistics.
3. When you get your green belt or black belt are these concepts reviewed?
4. I assume the tools you would use are DOE and statistical tests of significance (comapring means, variances, etc.).
J DoE (Design of Experiments) - Multiple responses with different factors Using Minitab Software 2
K Power point training slides on DOE (Design of Experiments) Wanted Training - Internal, External, Online and Distance Learning 2
N DOE (design of experiments) in Minitab 16 Using Minitab Software 6
P When can we apply DOE (Design of Experiments)? Six Sigma 8
P Cyclic Effect Factoring in DOE (Design of Experiments) Quality Tools, Improvement and Analysis 1
J How to Estimate the Number of Replicates on a DOE (Design of Experiments) Six Sigma 5
K Minitab Lack-of-Fit Test in DOE (Design of Experiments) Using Minitab Software 4
M Taguchi L4 Orthogonal Array Design of Experiments (DOE) in an Excel spreadsheet Excel .xls Spreadsheet Templates and Tools 3
V Linking the FMEA Causes & Action Plan with DOE Experiments or Experimentation Design FMEA and Control Plans 1
B Taguchi DOE (Design of Experiments) example using Minitab Using Minitab Software 3
C 3 Factor DOE (Design of Experiments) Template Document Control Systems, Procedures, Forms and Templates 0
L DOE (Design of Experiments) suggestions Using Minitab Software 7
L DOE (Design of Experiments) - Analyse Variation with Minitab Using Minitab Software 5
E 5^2 DOE (Design of Experiments) with 3 Replications, 5 Levels 2 Factors Statistical Analysis Tools, Techniques and SPC 6
M DOE (Design of Experiments) for 3 Variables, Many Levels Quality Tools, Improvement and Analysis 2
J DOE (Design of Experiments) Dependent Factors Using Minitab Software 1
C DOE (Design of Experiments) with 'Uncontrollable' Factors Using Minitab Software 5
Q DOE (Design of Experiments) for Accounting - New to Minitab need help Using Minitab Software 5
M DOE (Design of Experiments) - CQE Primer question Professional Certifications and Degrees 4
C Training courses for DOE (Design of Experiments) Training - Internal, External, Online and Distance Learning 3
P Taguchi method using Minitab - DOE (Design of Experiments) Help Quality Tools, Improvement and Analysis 7
S Sample Size Attribute DOE (Design of Experiments) Six Sigma 9
M Excel files for DOE (Design of Experiments) Excel .xls Spreadsheet Templates and Tools 6
T Minitab - Mixture DOE (Design of Experiments) - Sandability of a Gelcoat Using Minitab Software 5
R Custom DOE (Design of Experiments) Analysis in JMP Quality Tools, Improvement and Analysis 11
P Need help on DOE (Design of Experiments) - EPS molding process Quality Assurance and Compliance Software Tools and Solutions 2
A Good books on DOE (Design of Experiments) - Recommendations wanted Book, Video, Blog and Web Site Reviews and Recommendations 3
T Design of Experiments - DOE with Centre Point Using Minitab Software 7
Q Design of Experiments Using Subgroup Data - Conducting a 2^3 factorial DoE Quality Tools, Improvement and Analysis 6
T Screening DOE (Design of Experiments) with qualitative response Quality Tools, Improvement and Analysis 23
A The basics of DOE (Design of Experiments) & Validation Statistical Analysis Tools, Techniques and SPC 4
M Design of Experiments (DOE) - Help with homework problem Quality Tools, Improvement and Analysis 5
M DOE (Design of Experiments) with 3 factors with levels of 3,3 and 5 Quality Tools, Improvement and Analysis 3
P What if DOE (Design of Experiments) is not possible? Six Sigma 16
J DOE (Design of Experiments) for ultrasonically welding plastic lids Quality Tools, Improvement and Analysis 15
C Shainin and DOE (Design of Experiments) Information Misc. Quality Assurance and Business Systems Related Topics 2
A DOE - Design of Experiments? What does that mean? Quality Tools, Improvement and Analysis 5
T DOE (Design of Experiments) for Powder Coating Thickness Six Sigma 9
Tim Folkerts Do you DOE? Use of "Design of Experiments" Quality Tools, Improvement and Analysis 35
F DOE (Design of Experiments) Help: Montgomery's Industrial Engineering book Statistical Analysis Tools, Techniques and SPC 10
A Shainin vs. Fisher vs. Taguchi DOE (Design of Experiments) Statistical Analysis Quality Tools, Improvement and Analysis 10
A DOE - Design of Experiments - Shainin Design and Development of Products and Processes 7
C Seeking Help: Design of Experiments - DOE Statistical Analysis Tools, Techniques and SPC 4
J Selecting factors for screening DoE design Statistical Analysis Tools, Techniques and SPC 8
D Minitab - Design combinations (DOE) Using Minitab Software 4
P Help Setting Up and Analyzing 3 Factor 2 Level Full Factorial Design for DOE Using Minitab Software 3
B Analyze 'Factorial Design' or 'Variability' - Difference when used for DOE Analysis? Using Minitab Software 1
R To Find Out Second Order Model from First Order Factorial Design (DOE) Using Minitab Software 9
B Validation of DoE (Design of Experiements) Model - Minitab 15 Using Minitab Software 3
C DoE and ANOVA - 4 factor and 3 levels Taguchi design with 2 replicates Using Minitab Software 14
