DOE Multi level Taguchi - I am doing a Capstone Project
tmf8985
Hi I am doing a Capstone Project at a company, we will just call it company X.
I have to find the best location to find the worst possible solution in a tank with acidic solution. I take samples and titrate them to find the acidity level and if solutions acidity drops, I can add more acid to strengthen the acidity to the required level. The goal is again to find the best location and volume to fins the worst sample. This will perform as an early detection system to keep the acidity to required strength.
The factors I have decided for this DOE are listed with their respective levels
1. Water type ( to rinse sample cup) water and RO water 2 levels
2. Time 6am when machine starts and 10 am 4hrs after the machine has started and the solution has been kept agitated 2 levels
3. Location front of tank and back of tank 2 levels
4. Size or volume 10ml 55ml and 100ml 3 levels
5. Depth of sample surface, 18 inches and bottom of tank 3 levels
By the hand work i figured the following for degrees of freedom for truth table
3 factors at 2 level = 3 * (2-1)= 3
2 factors at 3 level = 2 * (3-1)= 4
miu = 1
error = 1
DOF = 9
The problem with L9 table is that it does not incorporate level 3 settings
So i use Minitab to form a multi level taguchi design with 5 factors and L36 with 2**3 and 3**2 settings, i get a 36 experiment table, 12 of which are repeats so i am left with 24 experiments, the problem is when i perform the analysis the S/N ratio is wrong and way off compared to hand calculations. What am I doing wrong? Can some one please help. i can provide the data and the Minitab file. Thanks
Tina
EDIT: I have attached the files. the files were done in version 15 of minitab. also for analysis i was using larger the better option.
When you add files using the Edit option, it does not show up as a new post in the "Post Last 24 Hours" or "Since Last Visit" searches. We did not realize that you had added the files.
Which response are you using, conductivity or pH? Why did you choose to use S/N ratio rather than analyze the response directly?
tmf8985
I am using Conductivity as the main response. Analyzing directly how would I do that?
wang1568
Your design is only a simple factorial design and designed by taguchi orthogonal array, not a taguchi design - need noise factors
The correct method to analyze experimental data is GLM in ANOVA
tmf8985
Using GLM that doesn't tell me which settings for factor to use to get worst sample and if i use the Taguchi analysis Larger the better option I get wrong values for S/N ratio, compared to if I do this by hand.
Wang1568, when you mentioned noise factor, what can they be in this case? any ideas?
Tina
Attached is an analysis of the conductivity using a General Factorial DOE. Two factors were significant, depth and size of sampling container. Deeper depths increased conductivity, which makes physical sense as you would expect contaminants to settle. The sampling container size did not make physical sense because the medium size container had the lowest conductivity.
wang1568
Miner had work out the analysis of DOE data.
I was wondering about the two factors water type and size of sampling cotainer.
The water type and size of sampling were used to titrate them and calculate the acidity level, not the cause of acidity, and may be as noise factors.
there was another wondering, why the reponse was conductivity, not ph value?
S Asterisk in DOE minitab software Using Minitab Software 23
J Selecting factors for screening DoE design Statistical Analysis Tools, Techniques and SPC 8
J Including Repeats in DoE using Minitab Using Minitab Software 5
J DoE - Number of runs in Plackett-Burman (Minitab) Using Minitab Software 2
J DoE (Design of Experiments) - Multiple responses with different factors Using Minitab Software 2
K Power point training slides on DOE (Design of Experiments) Wanted Training - Internal, External, Online and Distance Learning 2
I DOE: High variance and small effects in Minitab Using Minitab Software 1
M I have 3 different factors - DOE help Statistical Analysis Tools, Techniques and SPC 3
N Do I need to approach galvanized steel sheet flatness issue with DOE? Problem Solving, Root Cause Fault and Failure Analysis 9
V Screening DOE with 7 Input factors and 4 responses - Significant factors Using Minitab Software 1
H Taguchi mixed model DoE [L16 (4^3 2^6): factors interaction and ANOVA calculation Using Minitab Software 3
R Is there any Excel .xls Spreadsheet available for DOE with 3 factors? Six Sigma 1
N DOE (design of experiments) in Minitab 16 Using Minitab Software 6
D Interpretation of DOE interaction plot Using Minitab Software 8
D Minitab - Design combinations (DOE) Using Minitab Software 4
C DOE - How to determine optimal settings and transposing data Statistical Analysis Tools, Techniques and SPC 2
N 3 factor - 3 level experiment with DoE and Minitab Using Minitab Software 10
M DOE: Significant factor or not Using Minitab Software 2
P When can we apply DOE (Design of Experiments)? Six Sigma 8
S DOE Analysis - Experiments with 5 Factors Statistical Analysis Tools, Techniques and SPC 11
R [Minitab] DOE Output vs. Actual Data Using Minitab Software 6
S Blocking In a DOE Six Sigma 1
P Screening DOE: A coming up headache story Quality Tools, Improvement and Analysis 4
Y Please help me solve a DOE problem - New Minitab User Using Minitab Software 36
P Cyclic Effect Factoring in DOE (Design of Experiments) Quality Tools, Improvement and Analysis 1
V Analysing Results after DOE Using Minitab Software 1
V Analysis of DOE Results and Model Finalization Using Minitab Software 4
J How to Estimate the Number of Replicates on a DOE (Design of Experiments) Six Sigma 5
R 4 Factors 3 Level DOE to determine which factors are significant Using Minitab Software 2
K Minitab Lack-of-Fit Test in DOE (Design of Experiments) Using Minitab Software 4
M Injection Moulding Minitab DOE - All P Values are 0 Using Minitab Software 7
G Setting up a 3 Factor, 2 Level,2 response DOE in Minitab Using Minitab Software 7
Z A DOE in Minitab - 3 factors and 3 levels for each factor Using Minitab Software 12
M Taguchi L4 Orthogonal Array Design of Experiments (DOE) in an Excel spreadsheet Excel .xls Spreadsheet Templates and Tools 3
V Linking the FMEA Causes & Action Plan with DOE Experiments or Experimentation Design FMEA and Control Plans 1
B DOE Question: 3 factors with 2 levels and 1 factor with 3 levels Six Sigma 2
Z Help with running 3 factor DOE factor optimization Using Minitab Software 2
H Minitab DOE Analysis of Data and Transforming Using Minitab Software 4
P Help Setting Up and Analyzing 3 Factor 2 Level Full Factorial Design for DOE Using Minitab Software 3
B Taguchi DOE (Design of Experiments) example using Minitab Using Minitab Software 3
C 3 Factor DOE (Design of Experiments) Template Document Control Systems, Procedures, Forms and Templates 0
P How to analyze DOE: 2 Factor, 4 Level Experiment Six Sigma 7
J DOE Analysis Experiment, 5 factors, 4 factors having 3 levels, and 1 factor having 5 Using Minitab Software 38
B Analyze 'Factorial Design' or 'Variability' - Difference when used for DOE Analysis? Using Minitab Software 1
L DOE (Design of Experiments) suggestions Using Minitab Software 7
L DOE (Design of Experiments) - Analyse Variation with Minitab Using Minitab Software 5
E 5^2 DOE (Design of Experiments) with 3 Replications, 5 Levels 2 Factors Statistical Analysis Tools, Techniques and SPC 6
R To Find Out Second Order Model from First Order Factorial Design (DOE) Using Minitab Software 9
B Which type of DOE was likely used for this transfer function? Six Sigma 4
T Taguchi DOE Analysis - What S/N ratio (Nominal is best or smaller is better) to use? Quality Tools, Improvement and Analysis 5
