Does 21 CFR Part 11 apply to Scanned Documents?
My original record is paper approved by wet signatures on the paper.
2. The paper is then scanned and stored in PDF format.
3. The PDF file is then placed into a computer system for users to access (print out).
4. Users can view or print out the scanned PDF and use it in GxP activities.
I know I will have to validate the system but does Part 11 apply?
yodon
If (control of) the record falls under predicate rule, then yes. The first part of Part 11 is "Electronic Records" and you are clearly managing a record via electronic means. You will need to ensure adequate protection, adequate management (printing out copies becomes a challenge to track who has what and ensure they have the right version!), and adequate retention. There may be others but these jump to mind.
MIREGMGR
I agree as above. If the original record was GxP significant, then your means of storing and accessing that record is subject to Part 11.
v9991
Since you are relying on electronic copies to carry out GxP operations, it's required to comply with part-11, because...
* uploading current/correct version of document, its equivalent/extension of approval and release for usage;
* taking printouts is equivalent to issuance;
at each of the phases, traceability - trail becomes a need.
Adrian22
I agree you need document version description and traceability matrix, forget about tools unfortunately everyone does it manually to get a good overview in excel for example.
v9991
Does anyone know about any good digital signature software?
I am not quite sure about it; but,
Most of these applications which manage processes (SCM - ERP - DMS etc.,) come bundled along either with custom-built ones or have subscription to the common/commercial tools. The point is quite often than not, you have to go along with the preferred option recommended by the software manufacturer. (unless you are too specific about your requirements OR lenient about budget)
in normal pharma operations, more often than not, the other definitions(equivalents) of e-signatures are adopted. A combination of "id+password" which is simple to administer.
Since there are multiple techniques of handling e-signatures; under what circumstances are you opting for digital signatures?
Here's an example document which discusses digital signatures at some length (of course its own intended scope/requirements, but i guess, the insights/approach can be extended to our own areas as well.)
http://www.azdot.gov/TPD/ATRC/publications/project_reports/PDF/AZ534.pdf
Adrian22
Many thanks for the answer.
under what circumstances are you opting for digital signatures? Part 11 "Electronic Records"
I have the same experience. We do not want to be dependent on a system or a continuous cost. For me e-siganture is PKI signature that can be checked without an service.
Adrian22
Quick Summary:
Great document very extensive with surveys and cost indication of VeriSign and Silanis total 3 year cost is $558,405 compared with In-House Development around 1M$ theoretical cost according to the link.
These solutions cost to much for our needs. Furthermore the survey does not include some of the well known tools such as docusign and ecosign and other free solutions such as PGP, easy signature and ejbca.
We need a simple tool with reasonable cost with required technical elements of a compliant system (CFR Part 11) if we setup correct procedures internally etc.
v9991
in normal pharma operations, more often, adopt other definitions(equivalents) of e-signatures are adopted. A combination of "id+password" which is simple to administer.
Further, Precise answer for your query, I believe can be given by a s/w developer only.
Can somebody help this query; OR we do we need to move this post/link to s/w forum to get more-specific responses from s/w ppl.
M Does the Scope of 21 CFR Part 820.72 (Equipment) apply to Design? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 4
S Does FDA expect suppliers to be independently assessed to 21 CFR Part 820 ? US Food and Drug Administration (FDA) 4
A Does any one have FDA 21 CFR Part 820 QSR training material? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 13
C Does ISO 13485 certification require a company to follow 21 CFR Part 820? ISO 13485:2016 - Medical Device Quality Management Systems 13
J GMP CFR 21 Part 210 or 211 - Where does GMP address Document Control Document Control Systems, Procedures, Forms and Templates 6
M Does a process map satisfy 21 CFR 820.20(d) (Quality Plan)? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 4
M FDA 21 CFR 820.250 - Does "valid statistical" always mean math? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 6
M Does 21 CFR 820.80 (b) require a Supplier to have Receiving Inspection? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 13
I Does being a subsidiary fully absolve company B from complying with 21 CFR 820? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 4
Q Does 21 CFR 820 really revise every year? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 4
A What does the FDA think about 13485? Will the FDA upgrade 21 CFR 820? ISO 13485:2016 - Medical Device Quality Management Systems 3
0 To which part of 13485 does this refer? ISO 13485:2016 - Medical Device Quality Management Systems 3
lanley liao Does the customer`s trademark belong to customer-supplied property? Oil and Gas Industry Standards and Regulations 2
H How does a gas turbine work on diesel fuel? Oil and Gas Industry Standards and Regulations 12
G What does performance specification include? US Food and Drug Administration (FDA) 1
W Where does a coatings and paint company fall in IATF? IATF 16949 - Automotive Quality Systems Standard 5
C Does an accessory need an IFU if it use is discussed in the Parent device IFU? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 5
S How long does it take to register a product with MHRA? UK Medical Device Regulations 3
M Quality Manual - Where does Revision History Section go? Document Control Systems, Procedures, Forms and Templates 8
A Brexit When does the UK responsible person need to be in place? UK Medical Device Regulations 10
N Does anyone have experience of GB/T 34986-2017? China Medical Device Regulations 1
Z Does anyone have experience with EN ISO 17664 ? IEC 62366 - Medical Device Usability Engineering 9
F Does anyone have an ESD quality/cooler talk to share? Training - Internal, External, Online and Distance Learning 4
A What does this line from MDCG 2020-3 (MDR art. 120 substantial change) mean to you? EU Medical Device Regulations 4
T What does AS9100 mean when it says you must establish a process to do X? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 24
L Does a backdate form format can be changed if wrong revision is used? Document Control Systems, Procedures, Forms and Templates 8
B General Motors and Honda Alliance - What does this mean to suppliers? IATF 16949 - Automotive Quality Systems Standard 3
C ISO 13485 :2016 - CAPA - Does every CAPA need to be checked by regulations? ISO 13485:2016 - Medical Device Quality Management Systems 9
A Does ISO 9001:2015 cover all the requirements of ISO 10012:2003? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
N FDA UDI - Label vs. Labeling - Does the insert need to include UDI? Other US Medical Device Regulations 1
A Does anyone have a checklist of API Spec 650 13th Edition? Oil and Gas Industry Standards and Regulations 0
D Does Manufacture can submit CE mark application under MDD with NB for his New product after May 2020? EU Medical Device Regulations 3
A What does this sentence "this symbol shall be used in the orientation shown" mean in ISO 780:2015? Other Medical Device Related Standards 4
L Turkish Requirements - Does the Software need to be translated? CE Marking (Conformité Européene) / CB Scheme 2
J Does Pakistan Medical Device Import License allows parallel import? Other Medical Device Regulations World-Wide 0
BeaBea Interesting Discussion Where Does Marketing/ Advertisement of Products fit in to ISO 9001? Process Maps, Process Mapping and Turtle Diagrams 39
P Does anyone have a API Q1 Documentation Package? Quality Management System (QMS) Manuals 1
N What is our product classification? (Does Unclassified classification still exists) Other US Medical Device Regulations 14
C Does a CE mark infer meeting all applicable standards? CE Marking (Conformité Européene) / CB Scheme 4
N Small Company - Internal audit process - Who does the audit? Internal Auditing 16
