Does 21CFR11 only apply to records that are completed electronically?
jpal2
Currently our controlled document system is entirely paper-based. A master copy is made for all controlled procedures and controlled copies are distributed to various locations around the plant. Now, some senior members of staff have asked me to look into putting all procedures onto our computer network, which would remove all paper copies onsite.
We are a small manufacturer with limited resources so a software package is out of the question. This has been looked into in the past and was deemed to be too costly and timeconsuming in the past. We are looking at converting documents to pdf files and taking all precautions to secure the documents. Procedures and records would then be printed off by staff as needed. The printed copies of procedures would be destroyed when staff are finished using them and the records would be completed manually, i.e. records cannot be filled in electronically.
My question is: Does 21CFR11 only apply to records that are completed electronically or does it also apply to electronic procedures?
Statistical Steven
Statistician
As we await the final ruling, the spirit of Part 11 is the audit trail. Procedural control has the highest risk and is usually frown on by the FDA (The printed copies of procedures would be destroyed when staff are finished using them). If record retrieval is made electronically, you must have a Part 11 complient system and audit trail. I think your management has to decide if it is less costly to get 483's for lack of document control or a software system like QUMAS. Here is a link to many different software solutions (http://www.21cfrpart11.com/pages/sol_prov/edms.htm).
jfount
Thank you so much for the link, that will help greatly.
Have you had any exposure to Qumas as a system?
alex.Kennedy
Yes it only applies to predicate data that is stored elecetronically.
regards
Alex Kennedy
Mark75
Our company uses Qumas for document and record control purposes. Not sure about the costs involved, but I'm sure it's expensive. The system is configurable and I believe they help customize everything depending on your needs. The system houses all of our SOPs, forms, attachments, and drawings. We have an SOP w/ an attachment that provides details about who approves what for the various types of documents and the system is set up so that you can only select these individuals when routing things for approval. It also links w/ our email system, which notifies you if you have a document pending review/approval. It evens provides a link in the email that automatically takes you to the log in screen and then to the specific change control page for that particular document. There are view and compare capabilities so you can easily see exactly what changed and compare to the change/reason portion of the change control package. If you add your name to the notification page for any specific document you will receive an email if a new revision becomes approved. There is also a read and understand function, but that isn't really used, at least w/in our dept. We still use the hard copy training record route for training files. When we print out any documents you have the choice to print a "controlled copy" or a copy that expires w/in two days. The header at the top of each printout automatically provides the document name, title and revision.
We just upgraded the system to use it for our CAPA and concession reporting activities, which linked all of our plants together into the same system.
Overall, I think the package is very nice. The new CAPA and concession reporting process isn't very popular at the moment but hopefully the issues will be worked out and tweaked.
Mark
jfount
Thanks for the response Mark,
It sounds like it may be worth looking into.
We are looking for a full blown QMS. Qumas sounds as though it fits.
:yes:
D Change to labelling - does it require a new 510(k)? US Food and Drug Administration (FDA) 3
M What does "constantly" mean ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 12
N Does anyone use SGS for ISO 13485 / CE certification Registrars and Notified Bodies 0
G Does FDA allows remote approvals of quality documentation. Is there any specific guidance on signing any quality records remotely? Document Control Systems, Procedures, Forms and Templates 1
B Does FDA Registration QSR need to cover non-medical devices for contract repackager? US Food and Drug Administration (FDA) 1
0 To which part of 13485 does this refer? ISO 13485:2016 - Medical Device Quality Management Systems 3
lanley liao Does the customer`s trademark belong to customer-supplied property? Oil and Gas Industry Standards and Regulations 2
H How does a gas turbine work on diesel fuel? Oil and Gas Industry Standards and Regulations 12
G What does performance specification include? US Food and Drug Administration (FDA) 1
W Where does a coatings and paint company fall in IATF? IATF 16949 - Automotive Quality Systems Standard 5
C Does an accessory need an IFU if it use is discussed in the Parent device IFU? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 5
S How long does it take to register a product with MHRA? UK Medical Device Regulations 4
M Quality Manual - Where does Revision History Section go? Document Control Systems, Procedures, Forms and Templates 8
A Brexit When does the UK responsible person need to be in place? UK Medical Device Regulations 10
N Does anyone have experience of GB/T 34986-2017? China Medical Device Regulations 1
Z Does anyone have experience with EN ISO 17664 ? IEC 62366 - Medical Device Usability Engineering 9
F Does anyone have an ESD quality/cooler talk to share? Training - Internal, External, Online and Distance Learning 4
A What does this line from MDCG 2020-3 (MDR art. 120 substantial change) mean to you? EU Medical Device Regulations 4
T What does AS9100 mean when it says you must establish a process to do X? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 24
L Does a backdate form format can be changed if wrong revision is used? Document Control Systems, Procedures, Forms and Templates 8
B General Motors and Honda Alliance - What does this mean to suppliers? IATF 16949 - Automotive Quality Systems Standard 3
C ISO 13485 :2016 - CAPA - Does every CAPA need to be checked by regulations? ISO 13485:2016 - Medical Device Quality Management Systems 9
A Does ISO 9001:2015 cover all the requirements of ISO 10012:2003? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
N FDA UDI - Label vs. Labeling - Does the insert need to include UDI? Other US Medical Device Regulations 1
A Does anyone have a checklist of API Spec 650 13th Edition? Oil and Gas Industry Standards and Regulations 0
D Does Manufacture can submit CE mark application under MDD with NB for his New product after May 2020? EU Medical Device Regulations 3
A What does this sentence "this symbol shall be used in the orientation shown" mean in ISO 780:2015? Other Medical Device Related Standards 4
L Turkish Requirements - Does the Software need to be translated? CE Marking (Conformité Européene) / CB Scheme 2
J Does Pakistan Medical Device Import License allows parallel import? Other Medical Device Regulations World-Wide 0
BeaBea Interesting Discussion Where Does Marketing/ Advertisement of Products fit in to ISO 9001? Process Maps, Process Mapping and Turtle Diagrams 39
P Does anyone have a API Q1 Documentation Package? Quality Management System (QMS) Manuals 1
N What is our product classification? (Does Unclassified classification still exists) Other US Medical Device Regulations 14
C Does a CE mark infer meeting all applicable standards? CE Marking (Conformité Européene) / CB Scheme 4
N Small Company - Internal audit process - Who does the audit? Internal Auditing 16
J Does anyone have an excel IATF 16949 Internal Audit checklist I could use? IATF 16949 - Automotive Quality Systems Standard 7
A Does AS9100 require traceability to operators performing the work? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
I Does anybody use Detection in medical device Design FMEA? ISO 14971 - Medical Device Risk Management 18
A EN ISO 14971:2019 does not include the Annex Zs ISO 14971 - Medical Device Risk Management 4
Watchcat Does "Similar Device" = "Predicate"? EU Medical Device Regulations 7
