Does a CMM (Coordinate Measuring Machine) require Gage R & R study?
SGquality
Dear quality experts,
I am a newbie here - have seen the huge number of threads with enormous body of knowledge. Thanks all.
I have one question and would appreciate your views - we have a CMM for measuring part dimensions. Does this need Gage R & R study ?
Also a general question, which measuring equipment require the Gage R & R study and which type of measuring equipment do not.
Thanks in advance
N
NumberCruncher
Re: Does CMM require Gage R & R study ?
Hi SGquality
The answer to your first question is "Yes". If it is a fundamental part of your production process, it will probably need an MSA study.
The answer to your second question is contained in the answer to your first question.
Simply ask yourself, "Is this measurement a fundamental part of the production process?"
If the answer is yes, you will probably need to do an MSA study.
(I say 'probably' simply because I know the people who participate in this forum will almost certainly manage to find an exception!)
A few simple examples.
A CMM used to measure parts. Presumably you are not just measuring these parts for fun. If you are using the CMM for sorting good from bad, monitoring your production, as part of an approvals process, anything where you could reasonably state that "without this measurement, we would find it difficult / impossible to make / check / quality assure our products."
Balances, vernier calipers, micrometers, plug gauges (ie go-no go gauges), eyepiece graticules on microscopes, thermocouples, hardness testers, tensile testing machines, if they are used as part of your production process or QA system, will need MSA studies at some point.
The thermostat in the air conditioning unit in the offices, whilst very nice, even useful, is probably not essential to your production process and will not require an MSA study. Nor will the small plastic ruler on your desk that you use for swatting flies and making a "Boing!" noise with.
NC
Thanks in advance
I don't know what customer requirements you might have to satisfy in this regard, but from a practical standpoint you should be interested in understanding how measurement error affects your processes. MSA (GR&R in this case) isn't done on devices alone; it's done on measurement sytems including devices, operators and parts. The goal should be to verify that a given measurement system is appropriate for measurement of specific part features.
F
falconer65
The complex answer is yes and no. The yes is, as Jim pointed out, a GR&R is a measure of the interaction of the part, the measuring instrument, and the person making the measurement. So the no is from a CMM requiring a GR&R study, because a CMM would be required to be calibrated.
To the second part of your question, yes it would be nice to have GR&R studies of everything. With a CMM a GR&R is more a measure of the programmer, and an MSA Type 1 study can be more appropriate. The reality I often face is limited resources and only what the customer asks for gets MSA, of which a GR&R is a subset.
Setup (fixturing) of parts is also important in most cases, which is where potential operator error comes in.
SGquality
Re: Does CMM require Gage R & R study?
Thanks for the responses.
I forgot to mention earlier that we do annual calibration by Carl Zeiss and before we started using the CMM, we had successfully completed Measurement Uncertainty and Correlation with Customer's CMM.
Similar the the earlier responses on Yes and No for doing the GRR for CMM, would my additional information be able to decide if Gage R & R is required ?
The question, it appears, is not whether GR&R (or some form of MSA) is required. You decide what's required and what's not, in the absence of customer or regulatory obligations.
What you need to decide is whether MSA would be helpful. If you think that measurement error (regardless of the calibration status) is a significant risk, you should do your best to understand that source of variation. If, on the other hand, you determine that the risk of measurement variation is negligible, and that MSA won't add any value, you should probably not do it. The decision is yours.
F
falconer65
True, even the best program cannot make up for a bad setup.
But a decent setup with a good program will nullify operator error with iterative alignments. By "finding" the part, then "checking" to see if the part is where the cmm "thinks" it is, operator error in placing the part on the fixture is reduced to a fraction of a percent of the total variance.
Mary - QA Manager
Does anyone have an excel spreadsheet that might help me with my CMM gage R&R?
The customer has very specify requirements.
One part inspected 10 times by one worker. I have up to 15 dimensions to check.
Thanks!
Mary
Ripitup65
If you have a CMM program written, which includes a part holding fixture the answer to "Does a CMM require a GR&R" the answer is obviously "NO."
The coordinate system written into the CMM program will always establish where the part is prior to taking dimensional readings. This would eliminate the Appraiser by Part error and the Repeatability error portions of a GR&R. This leaves you with Equipment error. This can be answered by the CMM's calibration record since it will give you all axis of error, linear bias, and accuracy from a known standard.
If you are a CMM person and you do a lot of of free state dimension checks this is different. But in this case it would mostly likely be a one part check.
Hope this helps.
Ripitup65
C Does anyone know anything about the Mitutoyo MACH V CMM? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
E Blade Inspection - Does anyone use blade scaning software for a CMM or laser scanner? Design and Development of Products and Processes 3
J Controlling Temperature and Humidity in the CMM Room and does anyone use Artifacts? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 8
J CMM SPC - Does part measurement order matter? Statistical Analysis Tools, Techniques and SPC 12
K Does anyone know any CMM resellers in Taiwan? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 5
M Does any one have a table for level wise CMM activities Professional Certifications and Degrees 4
O CMM's (2 B&S and one DEA) - Tutor Software - Does anyone know how to get a license? Quality Assurance and Compliance Software Tools and Solutions 9
Marc CMM Band Width - How does band width relate to accuracy? General Measurement Device and Calibration Topics 3
B Does FDA Registration QSR need to cover non-medical devices for contract repackager? US Food and Drug Administration (FDA) 0
0 To which part of 13485 does this refer? ISO 13485:2016 - Medical Device Quality Management Systems 3
lanley liao Does the customer`s trademark belong to customer-supplied property? Oil and Gas Industry Standards and Regulations 2
H How does a gas turbine work on diesel fuel? Oil and Gas Industry Standards and Regulations 12
G What does performance specification include? US Food and Drug Administration (FDA) 1
W Where does a coatings and paint company fall in IATF? IATF 16949 - Automotive Quality Systems Standard 5
C Does an accessory need an IFU if it use is discussed in the Parent device IFU? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 5
S How long does it take to register a product with MHRA? UK Medical Device Regulations 3
M Quality Manual - Where does Revision History Section go? Document Control Systems, Procedures, Forms and Templates 8
A Brexit When does the UK responsible person need to be in place? UK Medical Device Regulations 10
N Does anyone have experience of GB/T 34986-2017? China Medical Device Regulations 1
Z Does anyone have experience with EN ISO 17664 ? IEC 62366 - Medical Device Usability Engineering 9
F Does anyone have an ESD quality/cooler talk to share? Training - Internal, External, Online and Distance Learning 4
A What does this line from MDCG 2020-3 (MDR art. 120 substantial change) mean to you? EU Medical Device Regulations 4
T What does AS9100 mean when it says you must establish a process to do X? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 24
L Does a backdate form format can be changed if wrong revision is used? Document Control Systems, Procedures, Forms and Templates 8
B General Motors and Honda Alliance - What does this mean to suppliers? IATF 16949 - Automotive Quality Systems Standard 3
C ISO 13485 :2016 - CAPA - Does every CAPA need to be checked by regulations? ISO 13485:2016 - Medical Device Quality Management Systems 9
A Does ISO 9001:2015 cover all the requirements of ISO 10012:2003? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
N FDA UDI - Label vs. Labeling - Does the insert need to include UDI? Other US Medical Device Regulations 1
A Does anyone have a checklist of API Spec 650 13th Edition? Oil and Gas Industry Standards and Regulations 0
D Does Manufacture can submit CE mark application under MDD with NB for his New product after May 2020? EU Medical Device Regulations 3
A What does this sentence "this symbol shall be used in the orientation shown" mean in ISO 780:2015? Other Medical Device Related Standards 4
L Turkish Requirements - Does the Software need to be translated? CE Marking (Conformité Européene) / CB Scheme 2
J Does Pakistan Medical Device Import License allows parallel import? Other Medical Device Regulations World-Wide 0
BeaBea Interesting Discussion Where Does Marketing/ Advertisement of Products fit in to ISO 9001? Process Maps, Process Mapping and Turtle Diagrams 39
P Does anyone have a API Q1 Documentation Package? Quality Management System (QMS) Manuals 1
N What is our product classification? (Does Unclassified classification still exists) Other US Medical Device Regulations 14
C Does a CE mark infer meeting all applicable standards? CE Marking (Conformité Européene) / CB Scheme 4
N Small Company - Internal audit process - Who does the audit? Internal Auditing 16
J Does anyone have an excel IATF 16949 Internal Audit checklist I could use? IATF 16949 - Automotive Quality Systems Standard 7
A Does AS9100 require traceability to operators performing the work? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
