Does a Tooling Build or Design Benefit From TS16949
Z
Zoomerange
The company I work for. The owner decided to go to TS-16949 to attract more customers. We are currently iso 9001. We have 4 plants total 2 of the plants are design and tooling builders. The other 2 are moving into low volume production work, currently they so prototype work and I do see a need there for TS 16949 but the other 2 doing only tooling builds and design makes no sense to me. Am I looking at this wrong?
Duke Okes
Re: Does a Tooling / Design Benfit From TS16949
Whether or not you get TS registered is a business decision. However, many of the requirements of TS would definitely add value, so much so that there used to be a tooling & equipment supplement to either QS-9000, the precursor to TS. However, you could implement those processes without getting registered. And I don't know for sure whether a non-part manufacturing company can even get registered any more. I think they may have limited it to parts manufacturers for TS.
Whether you get TS registered is not so much a business decision as a matter of application of the requirements to your product. Don't forget, ISO/TS is for production parts (not after market, for example) for road vehicles. If your products are not for that market, you can't be TS registered.
It's true that some of the requirements of TS can apply to tooling but you can't be registered for that scope. There is no equivalent to the 'old TE 9000' specification.
This is pretty close to what I was going to say. There are parts of TS that can be helpful for any business. And those parts could be added without expanding the scope. Just roll those parts into your ISO 9001 QMS.
howste
Thaumaturge
The two sites without production processes can only be included on a TS 16949 certificate as support sites for the manufacturing sites. They can't have a stand-alone certificate.
TS Rules 3rd edition said:
Only manufacturing sites where production and/or service parts are manufactured and supplied to customers subscribing to ISO/TS 16949 are eligible for certification. ISO/TS 16949, section 3.1.6, defines manufacturing as the process of making or fabricating production materials, production or service parts, assemblies, or heat treating, welding, painting, or other finishing services and section 3.1 defines site as a location at which value-added manufacturing processes occur. Sites producing automotive-related products and/or service parts manufactured and supplied to customers not subscribing to ISO/TS 16949 are eligible for certification at the discretion of the client.
Supporting functions, whether located at the manufacturing site or remote from a manufacturing site, are not eligible for independent ISO/TS 16949 certification but shall be included in the scope of certification.
All manufacturing in the scope of certification shall meet the applicability of ISO/TS 16949 for product supplied to customers subscribing to ISO/TS 16949.
Z
Zoomerange
Thank You for the information. I guess the 2 non production sites will stick to thier ISO-9001.
I have not work on any iso base systems since 1999 in the QS9000 days so I am trying to learn all I can and appreciate the help here.
howste
Thaumaturge
As mentioned in the quote above, they will be required to be included in the scope of the certificate (and audited) if they are providing support to the manufacturing sites.
bazzle - 2012
Are you supplying to Automotive as 1st tier or otherwise?
Some of TS is tied up in the particular requirements for that customer anyway.
If not stick with ISO9001 and implement other improvement practices like Lean, 5S etc etc.
BAzzle
There is going to be quite a lot to learn, since the fundamental principles have changed in that time - not so much the tools, but the approach.
A Does anyone know what a SRVA is? Chrysler is asking for this for tooling Customer and Company Specific Requirements 7
C Auditing a Tooling Shop - Does that area need to be audited to TS 16949 IATF 16949 - Automotive Quality Systems Standard 2
D Does the DoC require a technical documentation version? ISO 13485:2016 - Medical Device Quality Management Systems 1
S Local (country) registration of medical devices - Who does it in best case? Other Medical Device Regulations World-Wide 2
G When does containment event not require 100% sort? Nonconformance and Corrective Action 5
H Does this clause mean i must be in compliance with AS9100 or is 9001 enough? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
H Does ISO state in anyway that we MUST keep physical first piece parts? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
XRAY_3121 Class II heating pad - does the power supply have to have IEC 60601-1 testing?? US Medical Device Regulations 5
F Change in address for critical supplier - does NB need to be informed? CE Marking (Conformité Européene) / CB Scheme 20
S Brexit ISO 13485:2016 + Corrigendum - What does a UKCA DoC require? EU Medical Device Regulations 2
G Does anyone know about tobacco-free nicotine pouches? US Food and Drug Administration (FDA) 0
cgaro62 Does FDA apply to a non-medical 13485 certified custom manufacturing company? ISO 13485:2016 - Medical Device Quality Management Systems 11
R Does anyone use iQMS for their ISO based document control? Manufacturing and Related Processes 1
V How many hrs does it take to create a Technical File (TD)? EU Medical Device Regulations 4
M How does FDA determine OAI and VAI after inspection? ISO 13485:2016 - Medical Device Quality Management Systems 0
G Does TPI agencies comes under outsourced process as per Q1 Oil and Gas Industry Standards and Regulations 11
N FPY requested for an industry that does not have rework IATF 16949 - Automotive Quality Systems Standard 4
William55401 21 CFR 11 Password Aging - What does "periodically" revised mean in your org? Qualification and Validation (including 21 CFR Part 11) 3
I CQI-15 Welding System Assessment 2nd edition - Does not require Ultrasonic Welding anymore? Customer and Company Specific Requirements 0
Ajit Basrur Does "Refurbishment" fall under "Service"? ISO 13485:2016 - Medical Device Quality Management Systems 13
T Does marketing company require CE mark if manufacturer has CE mark on product? EU Medical Device Regulations 5
Watchcat REGULATORY WATCHCAT De Novo Post-Mortem 6 – How Does This Even Happen? Other US Medical Device Regulations 0
T What does VW mean by annual requalification? Customer and Company Specific Requirements 4
I Does BSI require suppliers to be ISO 9001 Certified? EU Medical Device Regulations 12
Watchcat Does Regulatory Affairs put the "no" in innovation? Other US Medical Device Regulations 14
Q Does anyone know what this call out means? Manufacturing and Related Processes 3
K COPLANARITY: Composite profile tolerance on multiple surfaces- what does" lower dimensional reference frame tolerance" control? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 11
P Does FDA require certification for quality system internal audit for auditor? Qualification and Validation (including 21 CFR Part 11) 1
H Does anyone has feedback on a notified body for small companies? EU Medical Device Regulations 3
M Does 4.5 - Alternative RISK CONTROL apply to the Particular Standards? IEC 60601 - Medical Electrical Equipment Safety Standards Series 3
E Does IVD need to integrate with hospital IT infrastructure? Medical Information Technology, Medical Software and Health Informatics 2
D What does a level 1 (PSW) PPAP actually promise? APQP and PPAP 19
R GS1 DataMatrix code does not meet GS1 Specification EU Medical Device Regulations 0
M Does the scope of ISO 9001:2015 applies to tenders, pricing and sales department of a medical devices distributor? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
K Why does load cell supplier requires force verification General Measurement Device and Calibration Topics 3
M Does C=0 strictly mean 1 bad, all bad, all the time? ISO 13485:2016 - Medical Device Quality Management Systems 6
C Does a medical device active (zinc oxide) needs BPR registration in EU? Other ISO and International Standards and European Regulations 6
D Does Risk Management apply to re-labeler (MDR) EU Medical Device Regulations 1
Ed Panek Does this FDA Requirement Apply to international (not USA) distributors for USA based manufacturing companies? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 0
S Does anyone have a checklist to prepare for ISO 13485, Stage I audit? ISO 13485:2016 - Medical Device Quality Management Systems 3
S Does a refurbished product required a new UDI? US Food and Drug Administration (FDA) 3
D Change to labelling - does it require a new 510(k)? US Food and Drug Administration (FDA) 5
M What does "constantly" mean ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 13
N Does anyone use SGS for ISO 13485 / CE certification Registrars and Notified Bodies 0
G Does FDA allows remote approvals of quality documentation. Is there any specific guidance on signing any quality records remotely? Document Control Systems, Procedures, Forms and Templates 1
B Does FDA Registration QSR need to cover non-medical devices for contract repackager? US Food and Drug Administration (FDA) 1
0 To which part of 13485 does this refer? ISO 13485:2016 - Medical Device Quality Management Systems 3
