Does anyone have a Change Management database?
eldercare
Does anyone have a change management data base something we can track changes in for review purposes with management team? If so could you please share we are struggling with this.
Thanks,
David:cfingers:
P
pthareja
Re: Change Management
In lighter vein,...
Change for ex..change!
it got obsolete, cause it changed!
For, nothing is permanent but Change.
Priyavrat
K
kgott
David:cfingers:
Look in the "Post Attachments List" at the top of this webpage otherwise a spreadsheet with some column headings that are important to you and rows of change details, will get you started.
Stijloor
Thanks,
David:cfingers:
David,
A search in the Post Attachments List on "Change Management" yielded this information.
A next search on "Change" yielded this list. Take a look because not all stuff may apply to what you are looking for. At least, it is a good place to start.
Stijloor.
eldercare
I am looking for an access type data base something that will be used to track changes made to the engineering system or quality system. If anyone know someone who can write in Access and is really good in the Cloumbis Ohio area please let me know.
Thanks,
David
john.b
An interesting question, especially if you know the background. Given how standard basic processes like change management and incident management are it seems it should be easy to look up database templates designed for Access, Sharepoint, or even Excel on the web. But it's not.
There are two other approaches you might try instead, but first I should also mention that for most uses you really wouldn't need any database or any template, and an Excel sheet you make up should suffice. Unless you are making several changes a day and require records to be very searchable or cross-referenced to other content the simple combination of a Word file for individual records and an Excel sheet as a log would do.
If this doesn't meet your demands you should also at least consider using a pre-designed ITSM tool (IT service management, typically based on ITIL guidance). There are open-source versions but going that route you'd be back to putting a lot of work in to get something useful and requiring IT support staff for maintenance, and if something went wrong you could be in trouble. One variation is buying customized versions of open source ITSM tools, and then you pay someone for doing a lot of that work and buy possible support, but at a guess cheaper ITSM tools from scratch may be as functional and more consistent and in the same price range.
The highest end versions by the big 4 suppliers (CA, IBM, HP, and BMC) are quite pricey but there are tons of other options for use, probably with less functionality but at a fraction of the expense. A whole separate category is on-line software or "in the cloud" variations.
It's also worth mentioning that you might ask the same question in either ITSM-type forums or database specific forums. I doubt you'd get far with either approach but you never know; a good template for an Access version could turn up. This forum (Elsmar) is great for most standard quality issues with a lot of depth in lots of directions but service management tool questions are getting out there. As you may be aware the ITSM world is crowded with consultants with different degrees of qualifications and asking simple questions that implies not paying one of them could be met with a lot of scorn.
yodon
Bugzilla (http://www.bugzilla.org/releases/4.2.1/) is a quick way to get an online implementation (I have no affiliation with bugzilla). We use it effectively and have had no problems with it. It has basic capability (life cycle, email notification, reporting). Not readily tailorable (we use it pretty much "out of the box"). I didn't install it so I can't say if that's challenging (but being open source sw, I expect it would be a pretty simple install).
R Does anyone have any experience on change control? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
A Does anyone have a presentation on how to go about communicating change? Coffee Break and Water Cooler Discussions 3
Q Does anyone know what this call out means? Manufacturing and Related Processes 2
H Does anyone has feedback on a notified body for small companies? EU Medical Device Regulations 2
S Does anyone have a checklist to prepare for ISO 13485, Stage I audit? ISO 13485:2016 - Medical Device Quality Management Systems 3
N Does anyone use SGS for ISO 13485 / CE certification Registrars and Notified Bodies 0
N Does anyone have experience of GB/T 34986-2017? China Medical Device Regulations 1
Z Does anyone have experience with EN ISO 17664 ? IEC 62366 - Medical Device Usability Engineering 9
F Does anyone have an ESD quality/cooler talk to share? Training - Internal, External, Online and Distance Learning 4
A Does anyone have a checklist of API Spec 650 13th Edition? Oil and Gas Industry Standards and Regulations 0
P Does anyone have a API Q1 Documentation Package? Quality Management System (QMS) Manuals 1
J Does anyone have an excel IATF 16949 Internal Audit checklist I could use? IATF 16949 - Automotive Quality Systems Standard 7
MDD_QNA QR Code Standard ISO/IEC 15417:2007 - Does anyone use it? Other Medical Device Related Standards 3
W Does anyone have an API Q2 checklist for internal auditing? Oil and Gas Industry Standards and Regulations 1
GreatNate Metrotom - Does anyone have any exposure to the Zeiss Metrotom 800 or 1500? Manufacturing and Related Processes 0
M Honda Audits - Does anyone have any experience with the QAV audit? General Auditing Discussions 3
Q Does anyone have experience implementing a QMS without ISO certification? Quality Manager and Management Related Issues 2
J Does anyone here use ISOXpress/IMSXpress QMS software? Software Quality Assurance 11
K Does anyone have a copy of a GM 5 Phase Problem solving form Problem Solving, Root Cause Fault and Failure Analysis 1
M Does anyone has a good verification and validation plan template? ISO 13485:2016 - Medical Device Quality Management Systems 3
B Does anyone charge for annual layouts? APQP and PPAP 8
N Does anyone know a registrar that offers both ISO 9001 and ISO 17020? Registrars and Notified Bodies 6
W Does anyone have any experience with the Easy Metric System? General Measurement Device and Calibration Topics 2
J Does anyone have a good APQP template that meets IATF requirements? APQP and PPAP 3
D IATF 16949 - 8.5.2.1 Traceability Plan - Does anyone have an example? IATF 16949 - Automotive Quality Systems Standard 4
C Does anyone have an AS9100:2015 audit schedule template? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
R Does anyone have example test report of defibrillator IEC 60601 - Medical Electrical Equipment Safety Standards Series 0
G Definition Parallel Loop - Does anyone know what the term Parallel loop means? Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 2
B Does Anyone utilize MS Outlook Read Receipts ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
L Does anyone know what is going on in DQS? Registrars and Notified Bodies 1
P Scope Document - Does anyone happen to have an Example Scope Document (4.3)? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
A Does anyone have a comparison between ISO 9001:2015 and ISO 13485:2016? ISO 13485:2016 - Medical Device Quality Management Systems 2
D Does anyone have a list of the IATF "Shalls" they would be willing to share? IATF 16949 - Automotive Quality Systems Standard 4
S Plant within a Plant - Does anyone currently manage their facility this way? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
E Does anyone have experience implementing a Tiered QMS? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
J Does anyone have an example Authority Listing SOP example? Misc. Quality Assurance and Business Systems Related Topics 3
S Does anyone know what a healthcare GDSN data pool actually looks like? Hospitals, Clinics & other Health Care Providers 2
ScottK Does anyone have experience with how MDD unanounced audits of suppliers are going? EU Medical Device Regulations 21
A Does anyone have experience providing a summary of Pre-IDE discussions in the 510k US Food and Drug Administration (FDA) 1
S Does anyone use the Boeing STP0565 and STP0637 specs? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
M Does anyone have a breakup of Establishments based on Device Classes ? Other US Medical Device Regulations 1
R Legal Register - Does anyone have an example of a legal register? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
A MDS software - Does anyone have experience with iPoint? RoHS, REACH, ELV, IMDS and Restricted Substances 8
P Does anyone have a DFMEA process Interface Matrix .xls template FMEA and Control Plans 7
S Does anyone know about FIAT Normation N.9.91320/02 ? Customer and Company Specific Requirements 2
M Does anyone here have experience implementing PCI DSS (Data Security Standard) IEC 27001 - Information Security Management Systems (ISMS) 10
R Does anyone know why the TC 176 website has been hijacked by CSA? ASQ, ANAB, UKAS, IAF, IRCA, Exemplar Global and Related Organizations 1
S Does anyone have procedure on "Regulatory Compliance"? US Food and Drug Administration (FDA) 18
