Does anyone have a generic Product Specification template?
  • Thread starter Quality-Misfit - 2008
  • Start date
Q
Does anyone have a copy of a product specification template? I've been asked to come up with one and I'm not sure where to start. We're wanting to standarize our specifications so they all have the same outline.
q-m
ScottK
Not out of the crisis
Re: Example of Product specification
every company I've worked for has had a different product specification format. A spec for a wing nut can be very different from a spec for a circuit board.
It might help if you tell us what you make.
Q
Thanks,
We make support communication equipment for aircraft OEMs.
Any template would work I just trying to figure out what the outline should consist of.
Thanks again,
Quality-Misfit
ScottK
Thanks,
Thanks again,
Quality-Misfit
more questions, just trying to narrow it down...
What is the purpose of the specification?
Is it for internal use only or will it go to customers?
If internal who will be using it?
Is the goal to make it as short and sweet as possible or is to be more like a technical file with design specifics?
Q
What is the purpose of the specification? I would like to use it as a design specification for new product.
Is it for internal use only or will it go to customers? Both.
If internal who will be using it? Engineering, quality, and manufacutirng.
Is the goal to make it as short and sweet as possible or is to be more like a technical file with design specifics?[/ I wouldlike for it to be simple but I want to ensure that we hit all the high points too. :thanx:
Thanks,
quality-misfit
DsqrdDGD909
Thanks,
Thanks again,
Quality-Misfit
Here's one from a quick google search:
10.2.4 Performance Specification
The Weatherproof Handset RF Call Box shall meet the following performance and physical specifications:
Mechanical Specifications
Physical Dimensions
Material Valox® (FV649 reinforced polyester)
Shipping Weight Color Gray
Environmental
Temperature Range -20° C to +60° C
Weatherproof Rating NEMA 3R
Humidity 95% non-condensing
Audio Level to RF Module 50 – 500 mVrms
Audio Level from RF Module
Audio Distortion 1.5%
Speaker Output Level dB SPL at 1 meter (max.)
Handset Receiver Output Level
Battery
Output Voltage 12 V dc
Required Charge Voltage 13.8 V dc
Cycle rating 6 sec. transmit; 6 sec. receive; 10 sec. standby 1.3 battery
Battery life (No operation)
Battery life (2 Watt Output) cycles (over 7-day period)
Battery life (5 Watt Output) (over 7-day period)
18 Ah battery
Battery life (No operation) days
Battery life (2 Watt Output) cycles (over 30-day period)
Battery life (5 Watt Output) cycles (over 30-day period)
External DC Power Source
Voltage Output (adjustable) Regulated 13.8 V dc required for battery trickle charge
Current 2 amps
General
Push-to-talk minimum transmit time Factory set @ 4 sec. (adj. 0-31.875 @ 0.125 sec. intervals)
Push-to-talk maximum transmit time Factory set @ 20 sec. (adj. 15-60 @ 1 sec. intervals)
Stand-by time Factory set @ 10 sec. (adj. 0-255 @ 1 sec. intervals)
Frequency range VHF: 154-174 MHz
UHF: 450-470 MHz
Antenna impedance 50 Ω
Operating voltage 8-15 V dc, 13.8 V dc nominal
Encoder/decoder CTCSS tone, DCS digital
Receiver (measurement procedures made per ANSI/TIA/EIA-603)
Sensitivity (12 dB SINAD) 0.25 μV
Inter-modulation VHF @ -65dB, UHF @ -60dB
Audio output 700 mVrms with 3kHz-deviated signal
Transmitter (measurement procedures made per ANSI/TIA/EIA-603)
RF output 2 or 5 watts
Spurious and harmonic emissions < -20 dBm max.
Audio Input 300mVrms for 3kHz-deviated signal
Modulation Sensitivity 100 mVrms @ 60% peak dev.
Approvals
FCC Identifier VHF: AIERT 17-142
UHF: AIERT 17-442
FCC Compliance Part 90
IC Certification VHF: 1084A-RIT 17142
UHF: 1084A-RIT 17442
VHF Antenna
Dimensions Maximum 3.63 inches high
Mounting BNC connector
Impedance 50 Ω
UHF Antenna
Dimensions Maximum 3.75 inches high
Impedance 50 Ω
Atham
Re: Does anyone have a product specification template?
Sir,
We are trying to make a Product specifications that we going to use in purchasing products abroad...specially a wood products.
can you have any sample on wood product specs...
thanks you..
:thanx:
Ettore
Yes, but the human mind has a very creative immagination.
We have many hundred of costumers and everyone have a different format for write down specifications
M Does anyone have a copy of a generic Safety Manual? Various Other Specifications, Standards, and related Requirements 21
N Does anyone have experience of GB/T 34986-2017? China Medical Device Regulations 1
Z Does anyone have experience with EN ISO 17664 ? IEC 62366 - Medical Device Usability Engineering 9
F Does anyone have an ESD quality/cooler talk to share? Training - Internal, External, Online and Distance Learning 4
A Does anyone have a checklist of API Spec 650 13th Edition? Oil and Gas Industry Standards and Regulations 0
P Does anyone have a API Q1 Documentation Package? Quality Management System (QMS) Manuals 1
J Does anyone have an excel IATF 16949 Internal Audit checklist I could use? IATF 16949 - Automotive Quality Systems Standard 7
MDD_QNA QR Code Standard ISO/IEC 15417:2007 - Does anyone use it? Other Medical Device Related Standards 3
W Does anyone have an API Q2 checklist for internal auditing? Oil and Gas Industry Standards and Regulations 1
GreatNate Metrotom - Does anyone have any exposure to the Zeiss Metrotom 800 or 1500? Manufacturing and Related Processes 0
M Honda Audits - Does anyone have any experience with the QAV audit? General Auditing Discussions 3
Q Does anyone have experience implementing a QMS without ISO certification? Quality Manager and Management Related Issues 2
J Does anyone here use ISOXpress/IMSXpress QMS software? Software Quality Assurance 11
K Does anyone have a copy of a GM 5 Phase Problem solving form Problem Solving, Root Cause Fault and Failure Analysis 1
M Does anyone has a good verification and validation plan template? ISO 13485:2016 - Medical Device Quality Management Systems 3
B Does anyone charge for annual layouts? APQP and PPAP 8
N Does anyone know a registrar that offers both ISO 9001 and ISO 17020? Registrars and Notified Bodies 6
W Does anyone have any experience with the Easy Metric System? General Measurement Device and Calibration Topics 2
J Does anyone have a good APQP template that meets IATF requirements? APQP and PPAP 3
D IATF 16949 - 8.5.2.1 Traceability Plan - Does anyone have an example? IATF 16949 - Automotive Quality Systems Standard 4
C Does anyone have an AS9100:2015 audit schedule template? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
R Does anyone have example test report of defibrillator IEC 60601 - Medical Electrical Equipment Safety Standards Series 0
G Definition Parallel Loop - Does anyone know what the term Parallel loop means? Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 2
B Does Anyone utilize MS Outlook Read Receipts ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
L Does anyone know what is going on in DQS? Registrars and Notified Bodies 1
P Scope Document - Does anyone happen to have an Example Scope Document (4.3)? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
A Does anyone have a comparison between ISO 9001:2015 and ISO 13485:2016? ISO 13485:2016 - Medical Device Quality Management Systems 2
D Does anyone have a list of the IATF "Shalls" they would be willing to share? IATF 16949 - Automotive Quality Systems Standard 4
S Plant within a Plant - Does anyone currently manage their facility this way? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
E Does anyone have experience implementing a Tiered QMS? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
J Does anyone have an example Authority Listing SOP example? Misc. Quality Assurance and Business Systems Related Topics 3
S Does anyone know what a healthcare GDSN data pool actually looks like? Hospitals, Clinics & other Health Care Providers 2
R Does anyone have any experience on change control? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
ScottK Does anyone have experience with how MDD unanounced audits of suppliers are going? EU Medical Device Regulations 21
A Does anyone have experience providing a summary of Pre-IDE discussions in the 510k US Food and Drug Administration (FDA) 1
S Does anyone use the Boeing STP0565 and STP0637 specs? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
M Does anyone have a breakup of Establishments based on Device Classes ? Other US Medical Device Regulations 1
R Legal Register - Does anyone have an example of a legal register? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
A MDS software - Does anyone have experience with iPoint? RoHS, REACH, ELV, IMDS and Restricted Substances 8
P Does anyone have a DFMEA process Interface Matrix .xls template FMEA and Control Plans 7
S Does anyone know about FIAT Normation N.9.91320/02 ? Customer and Company Specific Requirements 2
M Does anyone here have experience implementing PCI DSS (Data Security Standard) IEC 27001 - Information Security Management Systems (ISMS) 10
R Does anyone know why the TC 176 website has been hijacked by CSA? ASQ, ANAB, UKAS, IAF, IRCA, Exemplar Global and Related Organizations 1
S Does anyone have procedure on "Regulatory Compliance"? US Food and Drug Administration (FDA) 18
K Q1-Ford - Does anyone have any Q1 templates? Document Control Systems, Procedures, Forms and Templates 2
G Does anyone have a ISO 13485 Gap Analysis form they'd be willing to share? Quality Manager and Management Related Issues 3
C List of QMS Documents - Does anyone have a template? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
A Does anyone go Mushroom Hunting Coffee Break and Water Cooler Discussions 18
