Does C=0 strictly mean 1 bad, all bad, all the time?
Mortalis
As a contract medical device component manufacturer we have been using the C=0 sampling plan matrix for determining what the AQL will be at various stages of our manufacturing. We have been using this for over 20 years. We recently implemented a variation on that theme. Our Final Inspection department is our gate keeper to the Customer and our Final inspectors are very critical, which isn't a bad thing but, with all the Nonconforming Material Reports generated due to finding 1 NC pc in a 4.0 sample was stifling our Quality Engineering department and overburdening our MRB process. To ease this burden we implemented a 'find 1 pc in sample, take another sample and check for previous found NC. If no more found, scrap the 1 sample and move on. If 1 or more found for that same NC in the second sample, write up the NC' process. This has drastically reduced our time in MRB and has not had an appreciable effect on Customer Complaints.
I do understand that the processes of Nonconforming material and Material Review is there to help implement process improvements and what I have stated above tends to speak against this but we have not eliminated the NC and MRB all together.
Is this still considered C=0? When asked by our Customers during audits we proclaim to use the C=0 sampling plan. I guess, technically, we are using that sampling plan.
Your thoughts?
somashekar
THIS thread and the attachment in one of the post can be helpful to you.
Also see the threads below in this page for similar threads....
You can't use a sampling plan to determine the AQL--you determine the AQL in advance, based on risk, and then you use the chart to determine n, the number of samples to inspect.
If your sampling is creating a burden with NC parts, there's something wrong in production that sampling isn't going to help. If you repeatedly find defective parts, the sampling plan you've selected is doing its job, and should be causing you to implement corrective action to eliminate causes.
Without knowing more about the product(s) and what's being inspected, but given your dependence on inspection, it sounds like just looking for the same defect in the second sample is looking for trouble. Do something to move away from inspection as much as possible rather than doing more of it when your sampling plan is successful.
There isn't necessarily a reason to do away with your MRB, but if you have an excessive amount of "Use as is" dispositions it almost always means that there's something wrong with the specifications.
What if you were to tell your customers what actually happens?
In addition to the foregoing comments, it appears that you might be using acceptance sampling inappropriately to begin with, but again, without more information it's hard to tell. What about SPC?
Mike S.
Happy to be Alive
Lots of good points in Jim's reply.
To directly answer your question, no you are not doing C=0 sampling when you approve lots where a defect was found. I think you know this. You are trying to have the best of both worlds -- lower sample sizes of C=0 plans and the C>0 acceptance numbers of conventional MIL-STD-105 type plans. It doesn't work that way.
Do you really think you keep finding that one defect in the lot because of bad luck? :rolleyes:
indubioush
No, you are not using that sampling plan. I agree with everything the previous posters stated, but I'll add in a little emotion. I don't know what type of component you are manufacturing or whether your customer is relying on your inspection data at all, but it is very possible that you are putting patients at risk through your actions. In addition, you are misleading your customers. If I found that one of my suppliers was doing this, it would be a very big deal!
Okay, but lets say you make only low risk components. You should be able to follow the sampling plans in ISO 2859-1 and ISO 3951-1. There are AQLs that do allow a certain amount of rejects. But you should ensure your customer is aware of this and is okay with it.
Mike S.
Happy to be Alive
Seeing as it appears that the OP was using a 4% AQL or AAQL in the example he gave I would hope he is making low-risk products, as the probability of accepting a lot with defects is relatively high with that plan even when used correctly, which they are not.
David-D
I would defjnately agree that it is not a C=0 sampling plan. Two points which may not have been discussed:
The intent of C=0 plans is that there is no evidence of nonconformances in the lot; when there is, corrective action is to remedy the nonconformances in the product (100% screen, etc) and the process. The intent is to focus on the continuous improvement and not knowingly providing the customers defects. This is what underlies MIL-STD-1916, ISO 24247, and other c=0 (Accept on Zero (AoZ)) plans. By definition your aproach is diverging from this philosophy (even if it was satisfactory to all parties from a statistical perspective).
Another point is that you are in reality converting the origional sampling plan to a double samping plan with increased customer risk. It 3os unclear of you are just checking 1 more part or re-pulling the entire sample quantity, but either way, if you construct the OC curves for the sampling plans you can see how the customer risk increases statistically (not just philosophically as above).
To reemphasize another's point, if you are regularly failing a 4.0 AQL plan, then you would seem to have processes which are regularly creating nonconformances. The recomended focus should be on improving the process rather than making the sampling plan less sensitive.
Best regards,
David
L What does "C" in C=0 mean? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 5
C C=O puzzle - What protection does C=0 provide a supplier? Statistical Analysis Tools, Techniques and SPC 15
Ajit Basrur Does "Refurbishment" fall under "Service"? ISO 13485:2016 - Medical Device Quality Management Systems 0
T Does marketing company require CE mark if manufacturer has CE mark on product? EU Medical Device Regulations 3
Watchcat REGULATORY WATCHCAT De Novo Post-Mortem 6 – How Does This Even Happen? Other US Medical Device Regulations 0
T What does VW mean by annual requalification? Customer and Company Specific Requirements 3
I Does BSI require suppliers to be ISO 9001 Certified? EU Medical Device Regulations 12
Watchcat Does Regulatory Affairs put the "no" in innovation? Other US Medical Device Regulations 14
Q Does anyone know what this call out means? Manufacturing and Related Processes 3
K COPLANARITY: Composite profile tolerance on multiple surfaces- what does" lower dimensional reference frame tolerance" control? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 11
P Does FDA require certification for quality system internal audit for auditor? Qualification and Validation (including 21 CFR Part 11) 1
H Does anyone has feedback on a notified body for small companies? EU Medical Device Regulations 3
M Does 4.5 - Alternative RISK CONTROL apply to the Particular Standards? IEC 60601 - Medical Electrical Equipment Safety Standards Series 3
E Does IVD need to integrate with hospital IT infrastructure? Medical Information Technology, Medical Software and Health Informatics 2
D What does a level 1 (PSW) PPAP actually promise? APQP and PPAP 16
R GS1 DataMatrix code does not meet GS1 Specification EU Medical Device Regulations 0
M Does the scope of ISO 9001:2015 applies to tenders, pricing and sales department of a medical devices distributor? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
K Why does load cell supplier requires force verification General Measurement Device and Calibration Topics 3
C Does a medical device active (zinc oxide) needs BPR registration in EU? Other ISO and International Standards and European Regulations 5
D Does Risk Management apply to re-labeler (MDR) EU Medical Device Regulations 1
Ed Panek Does this FDA Requirement Apply to international (not USA) distributors for USA based manufacturing companies? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 0
S Does anyone have a checklist to prepare for ISO 13485, Stage I audit? ISO 13485:2016 - Medical Device Quality Management Systems 3
S Does a refurbished product required a new UDI? US Food and Drug Administration (FDA) 3
D Change to labelling - does it require a new 510(k)? US Food and Drug Administration (FDA) 5
M What does "constantly" mean ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 13
N Does anyone use SGS for ISO 13485 / CE certification Registrars and Notified Bodies 0
G Does FDA allows remote approvals of quality documentation. Is there any specific guidance on signing any quality records remotely? Document Control Systems, Procedures, Forms and Templates 1
B Does FDA Registration QSR need to cover non-medical devices for contract repackager? US Food and Drug Administration (FDA) 1
0 To which part of 13485 does this refer? ISO 13485:2016 - Medical Device Quality Management Systems 3
lanley liao Does the customer`s trademark belong to customer-supplied property? Oil and Gas Industry Standards and Regulations 2
H How does a gas turbine work on diesel fuel? Oil and Gas Industry Standards and Regulations 12
G What does performance specification include? US Food and Drug Administration (FDA) 1
W Where does a coatings and paint company fall in IATF? IATF 16949 - Automotive Quality Systems Standard 5
C Does an accessory need an IFU if it use is discussed in the Parent device IFU? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 5
S How long does it take to register a product with MHRA? UK Medical Device Regulations 14
M Quality Manual - Where does Revision History Section go? Document Control Systems, Procedures, Forms and Templates 8
A Brexit When does the UK responsible person need to be in place? UK Medical Device Regulations 10
N Does anyone have experience of GB/T 34986-2017? China Medical Device Regulations 1
Z Does anyone have experience with EN ISO 17664 ? IEC 62366 - Medical Device Usability Engineering 9
F Does anyone have an ESD quality/cooler talk to share? Training - Internal, External, Online and Distance Learning 4
A What does this line from MDCG 2020-3 (MDR art. 120 substantial change) mean to you? EU Medical Device Regulations 4
