Does Disciplinary Action Reduce Operator Errors?
Mules
Is disciplinary action (i.e. progressive discipline warnings) an effective corrective action to reduce operator documantation errors and process deviations on a shop floor?
Stijloor
Welcome to The Cove Forums. :bigwave:
Disciplinary action is very ineffective because often folks get punished for issues over which they have limited control. Putting people in a flawed system and holding them accountable is counterproductive.
Stijloor.
somerqc
Progressive Discipline has its place; however, ensure that what the person is being disciplined over be resolved by actions they can take.
For example, if they are constantly absent this is something under their control (there are exceptions where discipline is not appropriate such as family medical issues; however, those should be the exception).
However, to discipline them for a production issue where the system is the root cause is counter productive and ineffective.
Unfortunately, my approach seems to be in the minority.:frust:
Mules
Thanks for your replies. I guess discipline can show the sense of importance of SOP steps, following processes, etc. but can it also lead to tunnel vision when it comes to root cause analysis? For example, it seems convenient that corrective actions become blame oriented. Things like "retrain operators", "discipline operators", "revise SOP" and the like may prevent digging deeper. Also, is it possible that this could hurt morale and lead operators to not be as forthcoming with information or "near hits"? Do regulatory agencies view "counsel operators", retrain operators, etc. as viable corrective actions?
I would also add that disciplinary actions should be limited to intentional violations. Disciplinary action for normal process variation, or a failure to error proof, would be counterproductive.
An inspector failing to catch a bad part is a far different thing than an inspector deliberatly putting failed parts in the conforming bin.
SteelMaiden
Lots of good points here. What really caught my eye were the actions "retrain" and "revise". If you are seeing actions like this, you may need to further your investigation. Lots of actions to retrain may point to the cause that you are not training people well initially. Same thing with revise SOP. That makes one wonder if the SOPs are written correctly to begin with, and if further training needs to be done on how to develope SOPs that are correct from the beginning.
I agree with the "willfully did not follow directions" for discipline, but you also need to look at people who may "miss an inspection" a little too often. That may not be readily apparent as a willfull violation, but on closer look that person may be letting things go due to laziness, lack of committal, whatever vs. "I have too many things to look at, and so I am going to miss some."
Discipline is a tough thing and can work against you instead of for you. But, it is necessary to hold people accountable for that which they are responsible.
Jen Kirley
Quality and Auditing Expert
The subject has been energetically discussed in threads like this one: Internal Audit finding leading to 'Punishment' (Disciplinary Action).
The answer is a maddingly nebulous "maybe."
  • Maybe he/she will be more careful next time.
  • Maybe he/she will take the job more seriously.
  • Maybe he/she will get lucky.
  • Maybe he/she will boot the person who really was responsible but not recognized as such.
  • Maybe he/she will in effect do every job twice, like Santa checks his list twice, taking more time but you wanted it done right, yes?
Then again, maybe not. Maybe yes for a time, but eventually not because the problem was never really fixed. For discipline to work, the issue needs to be one of intent and complete capability and readiness. In other words, intent needs to be pretty well isolated as the true cause.
I talked about this in a White Paper Following Procedures awhile back.
Sidney Vianna
Post Responsibly
That is correct. It is much easier to identify operator error as the cause of the problem, instead of asking a few more probing questions to identify the real system shortcomings that allow for operators to make so many and frequent mistakes.
Remember Deming's message Drive out fear? And the ISO 9000 principle # 3, involvement of people?
Mules
Does anyone have any experience with communicating and applying a policy of granting "amnesty" to operators following an incident. This "immunity" takes place as long as the employee(s) involved in an issue become stakeholders in fixing the problem. They would have to proactively report the issue, participate in the root cause analysis, and help to propose and reinforce solutions? The upside to this approach seems to be that it could reduce people's fears and lead to prompt reporting of incidents and possibly lead to greater involvement. On the other hand, it seems if you use discipline you wind up with a disgruntled employee and may discourage reporting? I guess this is the classic, what's better the carrot or the stick? Do you think this amnesty approach is useful and have you or your company used this?
Caster
An Early Cover
In my experience when someone does not follow procedures, it pays to look at their boss or their bosses boss.
Most often I hear "they " told me to do it. The "they" who told them often takes great care to cover their tracks and will deny it when confronted.
So what would happen if the progressive discipline was focused on the boss, instead of the worker?
Tremendous pressure to circumvent the system is brought to bear when there is a perceived urgency or crisis. It takes strong leadership to stay the course.
B Does FDA Registration QSR need to cover non-medical devices for contract repackager? US Food and Drug Administration (FDA) 0
0 To which part of 13485 does this refer? ISO 13485:2016 - Medical Device Quality Management Systems 3
lanley liao Does the customer`s trademark belong to customer-supplied property? Oil and Gas Industry Standards and Regulations 2
H How does a gas turbine work on diesel fuel? Oil and Gas Industry Standards and Regulations 12
G What does performance specification include? US Food and Drug Administration (FDA) 1
W Where does a coatings and paint company fall in IATF? IATF 16949 - Automotive Quality Systems Standard 5
C Does an accessory need an IFU if it use is discussed in the Parent device IFU? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 5
S How long does it take to register a product with MHRA? UK Medical Device Regulations 3
M Quality Manual - Where does Revision History Section go? Document Control Systems, Procedures, Forms and Templates 8
A Brexit When does the UK responsible person need to be in place? UK Medical Device Regulations 10
N Does anyone have experience of GB/T 34986-2017? China Medical Device Regulations 1
Z Does anyone have experience with EN ISO 17664 ? IEC 62366 - Medical Device Usability Engineering 9
F Does anyone have an ESD quality/cooler talk to share? Training - Internal, External, Online and Distance Learning 4
A What does this line from MDCG 2020-3 (MDR art. 120 substantial change) mean to you? EU Medical Device Regulations 4
T What does AS9100 mean when it says you must establish a process to do X? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 24
L Does a backdate form format can be changed if wrong revision is used? Document Control Systems, Procedures, Forms and Templates 8
B General Motors and Honda Alliance - What does this mean to suppliers? IATF 16949 - Automotive Quality Systems Standard 3
C ISO 13485 :2016 - CAPA - Does every CAPA need to be checked by regulations? ISO 13485:2016 - Medical Device Quality Management Systems 9
A Does ISO 9001:2015 cover all the requirements of ISO 10012:2003? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
N FDA UDI - Label vs. Labeling - Does the insert need to include UDI? Other US Medical Device Regulations 1
A Does anyone have a checklist of API Spec 650 13th Edition? Oil and Gas Industry Standards and Regulations 0
D Does Manufacture can submit CE mark application under MDD with NB for his New product after May 2020? EU Medical Device Regulations 3
A What does this sentence "this symbol shall be used in the orientation shown" mean in ISO 780:2015? Other Medical Device Related Standards 4
L Turkish Requirements - Does the Software need to be translated? CE Marking (Conformité Européene) / CB Scheme 2
J Does Pakistan Medical Device Import License allows parallel import? Other Medical Device Regulations World-Wide 0
BeaBea Interesting Discussion Where Does Marketing/ Advertisement of Products fit in to ISO 9001? Process Maps, Process Mapping and Turtle Diagrams 39
P Does anyone have a API Q1 Documentation Package? Quality Management System (QMS) Manuals 1
N What is our product classification? (Does Unclassified classification still exists) Other US Medical Device Regulations 14
C Does a CE mark infer meeting all applicable standards? CE Marking (Conformité Européene) / CB Scheme 4
N Small Company - Internal audit process - Who does the audit? Internal Auditing 16
J Does anyone have an excel IATF 16949 Internal Audit checklist I could use? IATF 16949 - Automotive Quality Systems Standard 7
A Does AS9100 require traceability to operators performing the work? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
I Does anybody use Detection in medical device Design FMEA? ISO 14971 - Medical Device Risk Management 18
A EN ISO 14971:2019 does not include the Annex Zs ISO 14971 - Medical Device Risk Management 4
Watchcat Does "Similar Device" = "Predicate"? EU Medical Device Regulations 7
Y Does Solidworks (2D/3D drafting modules) need validation? Other Medical Device and Orthopedic Related Topics 5
M Definition Open Audit - What does an Open Audit mean? Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 3
I Does training have to be written? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 14
P What does UPH/m² mean? Quality Tools, Improvement and Analysis 3
