Does each company department have relevant functions?
K
Ka Pilo
As always in these situations, it is best to see what the standard says - which is '... they should be established at relevant functions and levels.'
I don't read that as saying every department has to have them. I think I would ask why they are different from the rest and possibly an OFI might be appropriate.
Prompted by the above post from "Some departments don't have Quality Objectives - Non Conformity?" thread, I'd like to pose the following: Does each department have relevant functions? My own response, speaking from experience in different companies I have worked with, I'm going to make a strong statement about it, YES - all departments have relevant functions. It is nearly impossible that I'll change my mind.
So, Sir Colin, you may want to expand on and explain your quote above, Sir. The floor is yours. What is a function?
Marc
Hunkered Down for the Duration
Why would there be a department if it didn't have "relevant" functions? Every department has functions that are "relevant" to the company or it wouldn't exist.
If your question is "What is a function", you're asking for a very basic definition.
func·tion
noun /ˈfəNGkSHən/
functions, plural
An activity or purpose natural to or intended for a person or thing
- bridges perform the function of providing access across water
- Vitamin A is required for good eye function
Practical use or purpose in design
- building designs that prioritize style over function
A basic task of a computer, esp. one that corresponds to a single instruction from the user
A relationship or expression involving one or more variables
- the function (bx + c)
A variable quantity regarded in relation to one or more other variables in terms of which it may be expressed or on which its value depends
A functional group
A thing dependent on another factor or factors
- class shame is a function of social power
A large or formal social event or ceremony
- he was obliged to attend party functions
verb /ˈfəNGkSHən/
functioned, past participle; functioned, past tense; functioning, present participle; functions, 3rd person singular present
Work or operate in a proper or particular way
- her liver is functioning normally
Fulfill the purpose or task of (a specified thing)
- the museum intends to function as an educational and study center
To sum it up for purposes here:
What is your function in the company? = What do you do in the company?
You could also say: "What are your responsibilities?" In asking that you are asking what a person's function is.
Marc
As Colin says, the standard doesn't say every department *has* to have them. That's not to say it isn't a good idea. Some will be more vague than others - For example, what would "Quality" objectives be in a sales department? Sales, for example, would typically not have a direct effect on the quality of the product.
The Specialist
I think that as an issue of semantics you are absolutely correct. Everyone, every department, any action - big or small has a 'function'. However, some companies I have worked for (usually fortune 500/ bluechip companies) have stretched the imagination when it comes to creating 'functions' within the organisation!
I think there is an issue with language. The standard is stating that any particular objective has to be passed down to each relative department, level or function in relation to that objective. Now, to be sure not all departments, levels and functions are relevant to all objectives. So, Colin is correct. If I have an objective relating to supplier performance, not every function or level will deal with that objective. However, any level or function impacts (or is impacted by) that objective, the objective needs to be rolled out to that level or function.
As far as in general having functions that are not relevant, I would ask why have a function that has no relevance? Of course, they you might be putting most senior management types at risk of being booted.... :notme:
somashekar
Therefore, it's crystal that we need to establish quality objectives for each department.
Sorry brother ... No.
I have a story.
In a printing plant that runs 24x7 for heavy demand of food packaging material, the machine was rather old, and a new machine of bigger capacity was ordered that would come only after an year or so due to various internal factory matters. The top management of this plant had only one objective that he had established and was keen on its monitoring and measurement.
Minimize the number of breakdowns and improve preventive maintenance and its time by suitable spares planning and optimize the production speed.
Reason: A breakdown causes a lot of inline material to be rejected and the startup again has wastages, thereby delivery volumes and time both get effected.
Relevant functions :
Production: To optimize the running speed in consultation with maintenance depending upon the machine capability and type of material loaded, so as to avoid over running faults and breakdowns.
Maintenance: Plan spares and take up preventive maintenance during all model changes on the machine, such that the maintenance time goes hand in glove with the new load setup time, and down time is reduced.
Top management wanted to know at what rate the machine is running and how many breakdowns occured.
So you have set objectives that relevant functions are together working out and that is that.
Customer requirements were met and was consistent with the set quality policy.
Remember that objectives can be reviewed and revised and new objectives can be established.
Sardokar
Um ...
isnt the quality of the product its ability to meet customer requirements ?
How then can sales not have a direct effect on the quality of the product ?
dont they have a big role in understanding and determining the requirement of the customers ?
if the sales representatives understands customer requirement wrong we will not send a correct proposal to the customer ... the quality of the product is automatically affected
in our company sales and presales determine the customer requirements , then these requirements are reviewed by our technical department to make sure we can provide them and we buy them from the supplier (or provide installation/support )
or am i missing something ?
Marc
In some companies sales does. In some companies sales doesn't. Many companies make goods or provide services in "off the shelf" fashion (e.g.: rubber ducks for kids), while some companies make things based upon what a specific customer, or group of customers wants (the company designs and/or builds to specific customer requirements).
There is also a difference between "ideal" vs. reality.
Sales is typically an input into product/service design. Now - Whether you can assign measurables (goals/quality objectives) with regard to that input, as well as whether that input affects the "quality" of the product (as opposed to what customers want) even when design listens to them is debatable. Just because customers want something doesn't mean it is a "quality" aspect.
harry
I suspect that there maybe some misinterpretation of the word 'function' used in the context of departments as well as management practices.
Departments are usually structured along functions such as human resources, marketing, administration, and sales. Departments can also be structured along the lines of customer, product or geographical region.
Thus, function refer to 'specialty skills or occupation' such as marketing, administration, R&D. etc and not what each of these individuals do (employed to do).
From the free dictionary
1. The action for which a person or thing is particularly fitted or employed.
2.a. Assigned duty or activity.
2.b. A specific occupation or role: in my function as chief editor.
Marc Quality Policy - What does the Quality Policy mean to each person in the company ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 30
A Does an attribute study (Go/NoGo pin gage) need two studies (1 for each pin) Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
S How does each element of OHSAS contribute to management of work place safety & health Occupational Health & Safety Management Standards 7
B Management Tool - Does each of them have their STRENGTH and WEAKNESSES? Misc. Quality Assurance and Business Systems Related Topics 10
B Does each shot peening timer require calibration - AS9100 requirements AS9100, IAQG 9100, Nadcap and related Aerospace Standards and Requirements 5
S Correct Document Control - Does each Document need its own Unique Numbering? Document Control Systems, Procedures, Forms and Templates 13
J What does the QS and TS in each standard's name mean? Other ISO and International Standards and European Regulations 4
M Internal Quality Auditor vs. QMS Lead Auditor - How much $ does each make? Career and Occupation Discussions 6
BeaBea Interesting Discussion Where Does Marketing/ Advertisement of Products fit in to ISO 9001? Process Maps, Process Mapping and Turtle Diagrams 35
P Does anyone have a API Q1 Documentation Package? Quality Management System (QMS) Manuals 1
N What is our product classification? (Does Unclassified classification still exists) Other US Medical Device Regulations 14
C Does a CE mark infer meeting all applicable standards? CE Marking (Conformité Européene) / CB Scheme 4
N Small Company - Internal audit process - Who does the audit? Internal Auditing 16
J Does anyone have an excel IATF 16949 Internal Audit checklist I could use? IATF 16949 - Automotive Quality Systems Standard 7
A Does AS9100 require traceability to operators performing the work? AS9100, IAQG 9100, Nadcap and related Aerospace Standards and Requirements 4
I Does anybody use Detection in medical device Design FMEA? ISO 14971 - Medical Device Risk Management 18
A EN ISO 14971:2019 does not include the Annex Zs ISO 14971 - Medical Device Risk Management 4
Watchcat Does "Similar Device" = "Predicate"? EU Medical Device Regulations 7
C Document Control Stamps - Does anyone still stamp their documents? Document Control Systems, Procedures, Forms and Templates 21
Y Does Solidworks (2D/3D drafting modules) need validation? Other Medical Device and Orthopedic Related Topics 5
M Definition Open Audit - What does an Open Audit mean? Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 3
I Does training have to be written? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
P What does UPH/m² mean? Quality Tools, Improvement and Analysis 3
L "IATF-Compliant" IATF 16949:2016 certification? What does this mean? IATF 16949 - Automotive Quality Systems Standard 13
D Why does Official Journal list superseded standards? EU Medical Device Regulations 6
B Record Management - Does the QMS need to control templates of records? Records and Data - Quality, Legal and Other Evidence 17
MDD_QNA QR Code Standard ISO/IEC 15417:2007 - Does anyone use it? Other Medical Device Related Standards 3
R Does any here use an internal auditing tool that works on different platforms? Internal Auditing 3
Sidney Vianna IAQG SCMH explains "positive risk"..........but does it? AS9100, IAQG 9100, Nadcap and related Aerospace Standards and Requirements 3
D Where does "as far as possible" stop? FMEA - EN 14971 ISO 14971 - Medical Device Risk Management 24
W Does anyone have an API Q2 checklist for internal auditing? Oil and Gas Industry Standards and Regulations 1
L External power supplies: How close does the safety report have to match the end-use application? IEC 60601 - Medical Electrical Equipment Safety Standards Series 4
Watchcat Does 820.30 include the manufacturing process? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 2
Watchcat Does ISO 13485 7.3 include the manufacturing process? ISO 13485:2016 - Medical Device Quality Management Systems 14
R When does the FDA consider a component a medical device? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 17
B Does EN ISO 15223-1:2016 include the graphic symbols to be added to software and IFU? Other Medical Device Related Standards 9
DitchDigger Boston Fire Code: Who Does What? (CAL TB 117-2013; CAL TB 133) Occupational Health & Safety Management Standards 2
GreatNate Metrotom - Does anyone have any exposure to the Zeiss Metrotom 800 or 1500? Manufacturing and Related Processes 0
G Is ISO 9001:2015 certification worth it for a company that does only contract manufacturing? Quality Management System (QMS) Manuals 14
K EU MDR Rule 11 - Does the 'Risk logic' used in Rule 11 conflict with that used in the other rules? EU Medical Device Regulations 2
C Does ISO 9001-2015 have a requirement for manufacturing equipment to be numbered? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 11
W How Often Does FDA State Consultant Recommended in a Pharma WL? US Food and Drug Administration (FDA) 1
C Does ITAR apply to Exporters only? Other ISO and International Standards and European Regulations 6
D Does every piece of equipment used in a laboratory need to have an IQ protocol written and executed? ISO 13485:2016 - Medical Device Quality Management Systems 1
A What if Contract Manufacturers does not have an ISO 13485 certificate? Where will the NB audit take place, at legal mfg. site or contract mfg. site? Other Medical Device Regulations World-Wide 3
A Does Class 1 Medical Device need to be certified to MDSAP? Canada Medical Device Regulations 5
K Does company who manufacture but does not design or carry out clinical trials is responsible for CE marking for single use medical devices? ISO 13485:2016 - Medical Device Quality Management Systems 3
R Does an RMA = a Customer Complaint Customer Complaints 4
M Does cFDA accepts FDA approval or CE marking? China Medical Device Regulations 1
