Does every company or employee owned gage have to be calibrated?
David Davis
Our company is in the process of registering to the ISO standard. We are approaching our pre-assessment audit. My question concerns the calibration of "all" gages. Does every gage company or employee owned have to be calibrated. We are leaning towards "no", due to time and MONEY. Are there any companies out there currently not calibrating "all" gages and using a "reference only", "process validation", or "transfer gage" procedure for some of your gages and how is it working for you? Has it ever been an issue during an audit? Thank you for your time and consideration. - Dave Davis
Sankaran Mahadevan
The Standard whether ISO / QS 9000 is very clear in this matter. Any gauge / instrument or for that matter even fixtures used in production has to be either calibrated or verified before use or at a specified periodic intervals. You have to calibrate all the instruments or gauges that you use for production. In other words you have to calibrate all measuring equipments as they might affect the quality of the final products.
You can decide upon the frequencies of calibration depending upon the usage of that particular equipment. But you have to calibrate them. No other go.
Sorry.
Sankaran Mahadevan
G
Graeme
Any gage (tool, measuring instrument) that is used to determine acceptance of a quality characteristic of the product must be calibrated. The calibration must be traceable to national measurement standards, or to another accepted standard.
A test I use is this (adapted from P. G. Stein) --
Does it matter if the measurement is wrong?
If yes, then calibrate the instrument.
If no, then why are you making the measurement?
Axiom: it is always lower cost to determine acceptance of a characteristic at the earliest possible stage of a process. Final inspection is always the second most expensive place to find a problem. (The most expensive place to find a problem is at the customer's place after delivery.)
If you only have calibrated tools at the final inspection point you are, in my opinion, setting yourself up for a lot of rework.
In some companies and industries it is historical practice to use tools that are marked "For Reference Only". (I work in one of those companies.) I disagree with this for several reasons.
  • Putting calibrated and "reference only" tools in the same work area creates a monster control problem. There must be absolutely zero possibility of a "reference only" tool ever being used where a calibrated tool is required. Getting caught once is at least a minor nonconformance. Having it happen several times is a major nonconformance because the system does not work. The consequences could be worse if people's lives are put at risk.
  • A rationale used for this practice is that the "reference only" tool is "only used for" troubleshooting, or maintenance, or alignment of the system, or only by Facilities and not by Production, or (and so on). Sorry, but I don't agree. I have done all of those types of work and in every one of them I have wanted some assurance that the meter is correct. This can also cause a lot of rework. For instance, if you align a system with a "reference only" meter but it does not pass the system checkout with calibrated instruments, then you have to align it and check it again.
  • There are cases where a calibrated tool may not be "required" but is an important safety factor. An electrician, for example, probably wants to be very sure there really is no voltage on a wire before she grabs it!
Notice that the key factor is how the tool is used, not who owns it. There is no intrinsic problem with employee-owned calibratable tools, provided they are in the calibration system.
Yes, calibration can be expensive. It's a business decision. But as part of the decision you should factor in the potential cost of not doing it, especially if a failure of your product or service can put people's lives at risk.
[This message has been edited by Graeme (edited 23 August 2001).]
C ISO 13485 :2016 - CAPA - Does every CAPA need to be checked by regulations? ISO 13485:2016 - Medical Device Quality Management Systems 9
D Does every piece of equipment used in a laboratory need to have an IQ protocol written and executed? ISO 13485:2016 - Medical Device Quality Management Systems 1
E Does every metallic part have to be protectively earthed (class I ME)? IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
L Does every document on a project require a document number? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
C Does every procedure need to be included within a policy? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
J Does Every Staff need to read the ISO9001 Quality Manual from Cover to Cover? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 17
Q Does 21 CFR 820 really revise every year? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 4
Q Does every Process Control listed in FMEA have to be listed in the Control Plan FMEA and Control Plans 4
L 8.2.4.2 First Article Inspection - Does every new part that is run require a FAIR AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 13
C Does every PMA part have to have an 8130 form? Or compliance with part 21.303? Federal Aviation Administration (FAA) Standards and Requirements 4
C Does all gauges mean every gage? Manufacturing Engineering (Paragraph 7.6.2) IATF 16949 - Automotive Quality Systems Standard 10
G Does ISO 9001 require a procedure for every part of the business? Document Control Systems, Procedures, Forms and Templates 8
G Does ISO9001 require every nonconformance to have a root cause analysis? Problem Solving, Root Cause Fault and Failure Analysis 21
S TS 16949 Compliant Control Plans - Does every item need a record? FMEA and Control Plans 5
D Certified shipment does it mean every part has to be checked 100%? Nonconformance and Corrective Action 12
K Does every Nonconformance Require a Corrective Action? Nonconformance and Corrective Action 8
D Following AS9102 for FAI Requirements - Does EVERY Component Need Its Own FAI? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 40
A Issuing Countermeasure Report - Does every nonconformance identified require an NCR? Nonconformance and Corrective Action 2
W Does every nonconformance require a corrective action? Nonconformance and Corrective Action 6
0 To which part of 13485 does this refer? ISO 13485:2016 - Medical Device Quality Management Systems 3
lanley liao Does the customer`s trademark belong to customer-supplied property? Oil and Gas Industry Standards and Regulations 2
H How does a gas turbine work on diesel fuel? Oil and Gas Industry Standards and Regulations 12
G What does performance specification include? US Food and Drug Administration (FDA) 1
W Where does a coatings and paint company fall in IATF? IATF 16949 - Automotive Quality Systems Standard 5
C Does an accessory need an IFU if it use is discussed in the Parent device IFU? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 5
S How long does it take to register a product with MHRA? UK Medical Device Regulations 3
M Quality Manual - Where does Revision History Section go? Document Control Systems, Procedures, Forms and Templates 8
A Brexit When does the UK responsible person need to be in place? UK Medical Device Regulations 10
N Does anyone have experience of GB/T 34986-2017? China Medical Device Regulations 1
Z Does anyone have experience with EN ISO 17664 ? IEC 62366 - Medical Device Usability Engineering 9
F Does anyone have an ESD quality/cooler talk to share? Training - Internal, External, Online and Distance Learning 4
A What does this line from MDCG 2020-3 (MDR art. 120 substantial change) mean to you? EU Medical Device Regulations 4
T What does AS9100 mean when it says you must establish a process to do X? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 24
L Does a backdate form format can be changed if wrong revision is used? Document Control Systems, Procedures, Forms and Templates 8
B General Motors and Honda Alliance - What does this mean to suppliers? IATF 16949 - Automotive Quality Systems Standard 3
A Does ISO 9001:2015 cover all the requirements of ISO 10012:2003? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
N FDA UDI - Label vs. Labeling - Does the insert need to include UDI? Other US Medical Device Regulations 1
A Does anyone have a checklist of API Spec 650 13th Edition? Oil and Gas Industry Standards and Regulations 0
D Does Manufacture can submit CE mark application under MDD with NB for his New product after May 2020? EU Medical Device Regulations 3
A What does this sentence "this symbol shall be used in the orientation shown" mean in ISO 780:2015? Other Medical Device Related Standards 4
L Turkish Requirements - Does the Software need to be translated? CE Marking (Conformité Européene) / CB Scheme 2
