Does ISO 9001:2015 call for a Policy or a Statement
G
glenn0004
We have been reviewing some of our corporate policies and have identified that they are of a poor standard if considered against a document hierarchy, the don’t define the organisations intent regarding the subject matter; instead they start to defined the relative process to a Level 4 detail.
In response I’ve developed a clear template for all future policies but at the same time noticed that our own 9001 quality policy (and also the same for many other organisations) is not written from an intent perspective – what we will do to meet the requirements but instead is a statement of how we have met the requirements… If I’m not mistaken the standard (9001:2015) calls for a policy not a statement. Have we been getting this wrong?
dsanabria
Can you paste the Quality Policy so we could see what you are making reference to?
G
glenn0004
Thanks for your response, below is a generic 9001:2008 policy (not our policy) that is available as a template to be considered as acceptable and is a sample of the type of supplier policies that are submitted as part of supplier approval. However the tense is that the organisation has done XYZ instead of shall or will; which is what I would expect of a policy.
"{Insert company name} was established in {2000} to provide {facility management services} to the
{building} industry. We are based in {Croydon} and employ {25} people.
Quality is important to our business because we value our customers. We strive to provide our
customers with products and services which meet and even exceed their expectations. We are
committed to continuous improvement and have established a Quality Management System
which provides a framework for measuring and improving our performance.
We have the following systems and procedures in place to support us in our aim of total customer
satisfaction and continuous improvement throughout our business:-
1. regular gathering and monitoring of customer feedback
2. a customer complaints procedure
3. selection and performance monitoring of suppliers against set criteria
4. training and development for our employees
5. regular audit of our internal processes
6. measurable quality objectives which reflect our business aims
7. management reviews of audit results, customer feedback and complaints
Our internal procedures are reviewed regularly and are held in a Quality Manual which is made
available to all employees.
This policy is posted on the Company Notice Board and can also be found in the staff handbook.
Though the Managing Director has ultimate responsibility for Quality all employees have a
responsibility within their own areas of work so helping to ensure that Quality is embedded within
the whole of the company."
dsanabria
Nice job but I tough you wanted comments on your policy not a genetic one. Please post your actual policy.
Hard to make statement on a genetic template...
G
glenn0004
Thanks again for your reply, however I’m not particularly looking for feedback of our current 9001:2008 policy or our draft 9001:2015 policy. What I am looking for is clarification weather the use of current tense is acceptable when drafting a “quality policy”.
If using current or past tense, what is drafted becomes a statement of what has been completed, however as a policy is “A formal declaration of the guiding principles and procedures by which a company will operate typically established by its board of directors or a senior management policy committee” the tense should be in the future.
Given what I see of many of our supplier’s policies, they all use current or past tense (or even both); this for me interprets their policy as statement and not a policy as per the requirements.
So back to my original point, should a quality policy be based on “shall” and “will” as opposed to “have”
bigqman
9000:2015 definition....
3.5.8
policy
<organization> intentions and direction of an organization (3.2.1) as formally expressed by its top management (3.1.1)
"future forward"
-AND-
3.5.9
quality policy
policy (3.5.8) related to quality (3.6.2)
Note 1 to entry: Generally the quality policy is consistent with the overall policy of the organization (3.2.1), can be aligned with the organization’s vision (3.5.10) and mission (3.5.11) and provides a framework for the setting of quality objectives (3.7.2).
Randy
OK, Newsflash! It doesn't matter what you call it or how it's formatted, all that matters is whether or not the minimum requirments are documented and you can show planning and fulfillment of them.
Now with that whatever it is you provided, I'll lay odds that the least paid, least important person in your company would lack "competent awareness" of the policy (meaning every bit of it), could not explain it and many of your leadership would fail the test as well.
You gave a business plan, not a policy, and every single word of it is now auditable and your feet are now cast in very fast setting cement.
My :2cents:
dsanabria
My :2cents:
Excellent and properly said....
Furthermore...
what was provided sound like a business plan and not a Quality Policy.
Furthermore, the issue of present and past tense is not what auditors are looking for - they are not grammar professor.
Bottom line - if you want to use what ever tense you want to - fine.
Just make sure that people have a clue on how they contribute, understand it and meets requirement
G
glenn0004
Thanks Randy..100% true regarding the least paid and leadership. However I cant get away from the notion that a policy should be intent (covering the minimum stated requirements) and not a statement about what you have done. Unfortunately, in supplier evaluation I see a lot of the latter which leads me to think that the notion of a policy has been lost by organisations thinking that it's a mission or vision statement and somewhere down the line these have been audited as acceptable....
A Does ISO 9001:2015 cover all the requirements of ISO 10012:2003? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
BeaBea Interesting Discussion Where Does Marketing/ Advertisement of Products fit in to ISO 9001? Process Maps, Process Mapping and Turtle Diagrams 39
G Is ISO 9001:2015 certification worth it for a company that does only contract manufacturing? Quality Management System (QMS) Manuals 14
C Does ISO 9001-2015 have a requirement for manufacturing equipment to be numbered? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 11
Q Does our material suppliers’ supplier have to be at least ISO 9001 certified? IATF 16949 - Automotive Quality Systems Standard 3
M Does ISO 9001 mandates cooking procedure for restaurants ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
Tagin Does ISO 9001:2015 require a full internal audit annually? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 21
N Does anyone know a registrar that offers both ISO 9001 and ISO 17020? Registrars and Notified Bodies 6
Q Does ISO 9001 require CARs for all customer complaints? Customer Complaints 2
qualprod ISO 9001 Cl. 4.1 and 4.2 - What does monitoring and review mean? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 13
Sidney Vianna ASQ apparently doesn't know ISO does not issue ISO 9001 certificates? ASQ, ANAB, UKAS, IAF, IRCA, Exemplar Global and Related Organizations 4
C Optic Patchcord Cables - Does 8.3 (Design) Apply Here? ISO 9001:2015 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
A Does anyone have a comparison between ISO 9001:2015 and ISO 13485:2016? ISO 13485:2016 - Medical Device Quality Management Systems 2
Q Does ISO 9001 Requirement for Document Approval (a service organization) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
J Does the word "claim" in ISO 9001 Clause 8.2.2 mean "requirement"? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
T Does your Quality Dept Control Procedures Outside the Scope of ISO 9001? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
S ISO 9001:2008 Certification Scope does not mention "manufacturing" ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
Q Where does 5S technique fit into ISO 9001? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
L What does "conformance matrix" means in terms of ISO 9001:2008? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
G Does AS9100 Certificate include ISO 9001 Certification? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 9
P Does the term ISO 9001:2008 imply we are all five years out of date? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
Marc Does ISO 9001 *require* that Internal Audits be Process Audits? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
L What exactly does Configuration Management in ISO 9001, Clause 7.5.3 means? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
T If a company becomes TS 16949 certified does it still need ISO 9001 certification? IATF 16949 - Automotive Quality Systems Standard 12
G Customer Property Cl. 7.5.4 - Where does ISO 9001 stop and ISO 27001 start? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 33
F Paperless Procedures - Does ISO 9001 Require Paper Documents? Quality Manager and Management Related Issues 37
K Does ISO 9001 require Supplier Pre-Qualification? Supplier Quality Assurance and other Supplier Issues 27
L Does ISO 9001 require that hard copies of documents be archived? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 13
T Does the Layout Design of a PCB fall under clause 7.3 in ISO 9001 Design and Development of Products and Processes 7
T Employee Satisfaction - Does ISO 9001 Require Monitoring of Employee Satisfaction? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 14
M Does ISO/IEC 17025:2005 require the Laboratory to have separate ISO 9001 Procedures ISO 17025 related Discussions 4
N How does a company determine what ISO standard (9000 or 9001) to register to? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
S How does ISO 9001:2008 apply to a logistics Company? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
C How long does it take to get the ISO 9001 certificate after passing the audit? Registrars and Notified Bodies 21
S Does ISO 9001 Clause 7.3 Design and Development apply? Design and Development of Products and Processes 18
J Customer Property ISO 9001:2008 Clause 7.5.4 - Does this include E-mails? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
H Does ISO 9001 have nothing to do with profitability? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 18
T ISO 9001 Clause 7.3.2 (a) Functional & performance requirement - what does it mean? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
G Does BSI do ISO 9001/TS 16949 Lead Auditor training? Training - Internal, External, Online and Distance Learning 5
J Does plant personnel need to be re-trained to the new ISO 9001:2008 revision?? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 15
V ISO 9001:2008 - How does an organization demonstrate "sustain success"? General Auditing Discussions 14
H QMS - How does ISO 9001 apply to Service Providers (utility or facility management) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
A What is ISO 9001 Certification and how does it relate to Product Quality? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 38
J What does the revised standard ISO 9001:2008 mean to Jim "Q" public ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 44
J Change Management System - Does ISO 9001 specify you need a process flow? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 11
B Does that Q-Policy fulfill ISO 9001 requirements? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
G Does ISO 9001 require a procedure for every part of the business? Document Control Systems, Procedures, Forms and Templates 8
N Poor control of testing chemicals ? which ISO 13485/9001 clause does it contravene? ISO 13485:2016 - Medical Device Quality Management Systems 8
I Does ISO 9001 requires the Control of All Records generated? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
