Marcus CLF
It's seem like companies only care about the quality of product but just don't pay much attention to the safety of working environment. Can this issue be covered under ISO 9001:2000 clause 6.4?
Agreed. But if you want to address other requirements (like health & safety) you need to use other models / standards.ISO 9K does not require you to meet 'other standards' ...
That does not mean they are documented in your QMS - and even if they are documented they are not subject to "Quality" audit....but the management responsibility does cover meeting statutory requrements. These requirements are met because they are for your own good.
ISO 9001.2000 said:This International Standard specifies requirements for a quality management system where an organization
a) needs to demonstrate its ability to consistently provide product that meets customer and applicable regulatory
requirements, and
b) aims to enhance customer satisfaction through the effective application of the system, including processes for
continual improvement of the system and the assurance of conformity to customer and applicable regulatory
requirements.
The auditor should evaluate the maintenance programme and assess to see if it is appropriate for ensuring the boiler can continue to do its work to produce product - nothing more.You have a boiler in your factory, the auditor is not going to check whether it can stand the pressure. He will certainly ask whether the boiler inspector has checked and certified it. You can bet your maintenance QMS shall specify it because you want it there.
Same as for the example above. It has no impact on product quality - it doesn't appear in the report!Same with welding glasses, gloves, masks, .. wherever required. Your QMS will specify it and the auditor will look into it becase the QMS specifies it.
I would expect proper control over the handling and storage processes .... to ensure the product conforms.If you make dynamite, you are going to handle it and pack it with utmost care. you will do it for your own good, because you have agreed to do so with your customer. It will be specified again in your QMS. The auditor will look into it.
Now there is a clear requirement for product to conform with:You make foodstuff, want to continue in the business, your QMS will specify disinfected workplaces.
If you are a producer of foodstuffs your auditor should be a specialist in relevant controls that ensure product meets these statutory requirements and they would audit to see that these controls are operated throughout your plant.ISO 9001.2000 Clause 7.2.1 said:c) statutory and regulatory requirements related to the product,
As a responsible member of your own organisation you have a responsibility for safety. You can use integration of H & S matters into a QMS to help but don't expect your auditor to use ISO 9001 to police compliance. They may not be competent to do so.These things are done for your requirements. To combine your business requirements under a common simple system. The standard only provides a scope for it.
requirements, and
requirements.
Looking at the scope of the standard:
So all regulatory requirements are those that apply to the product - not to occupational health & safety.
)I also wouldn't want my CB to be drawn into the bad publicity when they had an accident.
You can read point b as well as I can - it is about customer satisfaction - nothing about health and safety.I understand in point a) ISO talks about the product and in point b), not about the product.
Look, you used the example of the boiler and I responded. I don't expect an auditor to be an expert on boilers.You expect the auditor to be an expert on boilers? I have always been more comfortable when the auditor belives more in the boiler inspector rather than claiming to be an expert himself.
No.See what I mean?
I have never said the top management is not responsible for health and safety. They are.The management responsibility is ignored here. Who do you think ends up behind the bars if there is an accident and loss of life? The CB or the management?
Rubbish.Anything defined as the organisation as their QMS is subject to compliance audit once it is declard as adequate. How deep the auditor wants to dwell into it is to be decided by the auditor.
For quality, yes. Although some people want to make ISO 9001 a completley elastic management system to cover finance, health and safety etc. IMHO not appropriate.Secondly, all of us have agreed upteen (four hundred?) times so far that the QMS is meant for the organisation to improve their performance.
Not sure of your point here. By "extending" ISO 9001 you want to give them a bigger stick?It is not a baton handed over to the auditor so that the auditor can periodically give them a nice beating and keep them in line.
You have assumed s / he has to be an expert (see above). All I would expect is that the auditor is aware of what conditions the boiler has to generate to assure product quality and checks to see that it is being monitored and maintained to do so.An expert in foodstuff (as required) would know zilch about working of the boiler that generates the steam to process the foodstuff. So what does he do?
