Does ISO 9001 require a procedure for every part of the business?
G
grumpytam
Hello All
We are a small aerospace repair station and have ISO 9001. The problem is for some reason the MD is under the impression that everything we do needs a procedure and process. Is this true?
The main issue is with creating a procedure for accounts. Surely its enough that we have qualified people running it so why do we need a procedure. Where do we stop...? Do I need a procedure for ordering a pen or going to the bathroom?
That said all the key core processes are in place, I just don’t want to be snowed under with unnecessary procedures detailing the smallest item.
Regards
Tam
Wes Bucey
Prophet of Profit
Re: Does ISO 9001 need every part of the buisness to have a procedure
Hello All
Regards
Tam
Welcome to the Cove!:bigwave:
Congratulations on making your first post.
To your question:
Many folks still have residual memory of the pre-2000 ISO Quality Management System Standards which were VERY prescriptive on documenting everything with some sort of a written Procedure.
Thankfully, things have a little more common sense in the world of ISO today.
First, understand the difference between these terms
  1. process
  2. procedure
  3. work instruction
as used in modern QMS
Then be willing to give little credit for brains to the employees of your organization, tempered with REALITY.
Think of this analogy: most folks growing up in Europe or the USA understand how to use a knife and fork to eat and probably need little instruction beyond some basic table manners in using them. Folks who use chopsticks or their fingers in their native land MAY need a little bit more help in mastering these instruments and vice versa for knife and fork users coming to a chopstick environment.
Using the terminology listed above, a process (steps from inquiry to finished aircraft on the runway ready for flight) might be documented with something as simple as a flow chart showing cycling through various departments in your organization. Individual Procedures and Work Instructions for segments of that flow chart can be non-existent (sharpening pencils or making sure printer has toner or "turn screw clockwise") or complicated (check list for flight readiness) as required for the knowledge, skill, and training of the employees who will be carrying out the steps.
I'm sure other will add more comments. This could be an interesting thread to follow.
Ted Schmitt
Regards
Tam
Let me add my :2cents:... you most probably know that the 2000 version of the standard only requires 6 procedures...... the 1994 version (as Wes stated) "incentivated" documentation of almost everything... lot´s of people that where against ISO back then complained that it was to beaurocratic, to much paper, people felt like they had their hands tied and that the system was not flexible... now with the new version, your QMS can be much "lighter" and more flexible...
Document only what´s necessary... the Accounts department ? They learned that in accounting class in college... no need for a procedure.... ordering a pen is ordering a pen... going to the bathroom our Mommies taught us in Kindergarden.... concentrate your documentation on what really impacts the quality of your product... what REALLY MATTERS !!
Since the definition of a procedure is the specified way to carry out a process, each process will have a procedure. The question is do these procedures need to be documented? The answer can be found in 4.2.1 d). If you need to have the procedure documented to ensure effective planning, operation or control of the process, then you have to document it. There is a difference between "mandated" procedures and "required". ISO 9001 mandates only the 6, however, necessity might (and probably will) require more.
With that in mind....
If your organization cannot order pens without error in absence of a written procedure, then a written procedure is required. If you cannot go bathroom without some formal documentation.....then again. I suppose some paper is critical in going bathroom, but I digress. :)
added.....
Welcome to the Cove, Tam :bigwave:
Hello All
Regards
Tam
If the MD is 'under an impression' it's a good time to help them understand what this is all about. Take some time and review what the standard is about and what it requires. Let him see where and when a procedure is required, it's his company.......
As others have stated already: Most certainly not. In this situation I usually refer to note 2 of clause 4.2.1: :read:
ISO9001:2000 said:
The extent of the quality management system documentation can differ from one organization to another due to
a) the size of organization and type of activities,
b) the complexityof processes and their interactions, and
c) the competence of personnel.
In other words, you are supposed to build a system suited to the needs of your company. Thus, your MD can relax.
Which makes perfect sense. Information overload never made anyone happy. In fact, it is likely to cause a system to fail: Too many written procedures (particularly useless ones) will make people see the system as a load of crock. They will then treat it accordingly.
/Claes
G
grumpytam
Thanks guys, get advice. :applause:
Though, you have said the 2000 version of the standard only requires 6 procedures.....
We have 20 procedures already :notme:
Ted Schmitt
As long as these 20 procedures do you some good, then no problem... :notme:
Yes, plus the ones you deem necessary. Again: You are supposed to create a system that suits the needs of your company.
And hey: Please let us know about your progress, ok?
/Claes
M Does the scope of ISO 9001:2015 applies to tenders, pricing and sales department of a medical devices distributor? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
A Does ISO 9001:2015 cover all the requirements of ISO 10012:2003? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
BeaBea Interesting Discussion Where Does Marketing/ Advertisement of Products fit in to ISO 9001? Process Maps, Process Mapping and Turtle Diagrams 39
G Is ISO 9001:2015 certification worth it for a company that does only contract manufacturing? Quality Management System (QMS) Manuals 14
C Does ISO 9001-2015 have a requirement for manufacturing equipment to be numbered? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 11
Q Does our material suppliers’ supplier have to be at least ISO 9001 certified? IATF 16949 - Automotive Quality Systems Standard 3
M Does ISO 9001 mandates cooking procedure for restaurants ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
Tagin Does ISO 9001:2015 require a full internal audit annually? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 21
N Does anyone know a registrar that offers both ISO 9001 and ISO 17020? Registrars and Notified Bodies 6
Q Does ISO 9001 require CARs for all customer complaints? Customer Complaints 2
qualprod ISO 9001 Cl. 4.1 and 4.2 - What does monitoring and review mean? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 13
Sidney Vianna ASQ apparently doesn't know ISO does not issue ISO 9001 certificates? ASQ, ANAB, UKAS, IAF, IRCA, Exemplar Global and Related Organizations 4
C Optic Patchcord Cables - Does 8.3 (Design) Apply Here? ISO 9001:2015 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
A Does anyone have a comparison between ISO 9001:2015 and ISO 13485:2016? ISO 13485:2016 - Medical Device Quality Management Systems 2
G Does ISO 9001:2015 call for a Policy or a Statement ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 11
Q Does ISO 9001 Requirement for Document Approval (a service organization) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
J Does the word "claim" in ISO 9001 Clause 8.2.2 mean "requirement"? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
T Does your Quality Dept Control Procedures Outside the Scope of ISO 9001? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
S ISO 9001:2008 Certification Scope does not mention "manufacturing" ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
Q Where does 5S technique fit into ISO 9001? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
L What does "conformance matrix" means in terms of ISO 9001:2008? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
G Does AS9100 Certificate include ISO 9001 Certification? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 9
P Does the term ISO 9001:2008 imply we are all five years out of date? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
Marc Does ISO 9001 *require* that Internal Audits be Process Audits? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
L What exactly does Configuration Management in ISO 9001, Clause 7.5.3 means? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
T If a company becomes TS 16949 certified does it still need ISO 9001 certification? IATF 16949 - Automotive Quality Systems Standard 12
G Customer Property Cl. 7.5.4 - Where does ISO 9001 stop and ISO 27001 start? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 33
F Paperless Procedures - Does ISO 9001 Require Paper Documents? Quality Manager and Management Related Issues 37
K Does ISO 9001 require Supplier Pre-Qualification? Supplier Quality Assurance and other Supplier Issues 27
L Does ISO 9001 require that hard copies of documents be archived? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 13
T Does the Layout Design of a PCB fall under clause 7.3 in ISO 9001 Design and Development of Products and Processes 7
T Employee Satisfaction - Does ISO 9001 Require Monitoring of Employee Satisfaction? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 14
M Does ISO/IEC 17025:2005 require the Laboratory to have separate ISO 9001 Procedures ISO 17025 related Discussions 4
N How does a company determine what ISO standard (9000 or 9001) to register to? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
S How does ISO 9001:2008 apply to a logistics Company? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
C How long does it take to get the ISO 9001 certificate after passing the audit? Registrars and Notified Bodies 21
S Does ISO 9001 Clause 7.3 Design and Development apply? Design and Development of Products and Processes 18
J Customer Property ISO 9001:2008 Clause 7.5.4 - Does this include E-mails? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
H Does ISO 9001 have nothing to do with profitability? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 18
T ISO 9001 Clause 7.3.2 (a) Functional & performance requirement - what does it mean? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
G Does BSI do ISO 9001/TS 16949 Lead Auditor training? Training - Internal, External, Online and Distance Learning 5
J Does plant personnel need to be re-trained to the new ISO 9001:2008 revision?? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 15
V ISO 9001:2008 - How does an organization demonstrate "sustain success"? General Auditing Discussions 14
H QMS - How does ISO 9001 apply to Service Providers (utility or facility management) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
A What is ISO 9001 Certification and how does it relate to Product Quality? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 38
J What does the revised standard ISO 9001:2008 mean to Jim "Q" public ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 44
J Change Management System - Does ISO 9001 specify you need a process flow? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 11
B Does that Q-Policy fulfill ISO 9001 requirements? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
N Poor control of testing chemicals ? which ISO 13485/9001 clause does it contravene? ISO 13485:2016 - Medical Device Quality Management Systems 8
