Does ISO 9001 require Supplier Pre-Qualification?
K
kgott
Hi all; Im involved in discussions about pre-qualification of suppliers.
I'm being told we have to pre-qualify our suppliers and I have to come up with some criteria for pre-qualifcation.
My view is that pre-qualification takes place when suppliers complete the forms required by finance to get paid and they then go on the suppliers list maintained by finance.
I am saying that evulation of suppliers takes place after they have been engaged and are on the job suppling goods and services and yes; we have must a criteria for evaluating them but this does not need to be documented by the standard but perhaps its useful to do so in a project plan or in the quality manual to please the customer.
I am also saying that we maintain records of evulation through the project or work scope closure report.
The standard states:
The organization shall evaluate and select suppliers based on their ability to supply product in accordance with the organization's requirements. Criteria for selection, evaluation and re-evaluation shall be established. Records of the results of evaluations and any necessary actions arising from the evaluation shall be maintained
Am I right?
Marcelo
Am I right?
No.
Every qualification requirement of the standard (process, human resources, physical resources, suppliers, equipment, documentation, etc. - let´s call them resources in general) is there because the idea is that you can only use the resources that you verified that will fulfill the objectives they are defined to.
In the case of suppliers, you need to make sure that they can " product in accordance with the organization's requirements" before buying from them, otherwise you cannot buy from them.
Randy
Do you see prequalification in the requirement you posted?
If you do then it has to be done
If you don't then it doesn't have to be done
Back off a bit because you're digging too deep and making it way too complicated.
K
kgott
Thanks for your comments Marcello, I appreciate that every organisation has 'reasons' for using a particular supplier and my employer 'pre-qualified' me in the form of an interview but pre-qualification as its currently done anyway, involves having a stated criteria which involves sending the supplier a questionnaire etc etc.
Most people have list of criteria but every organisation also uses criteria that’s not stated. E.g. if a subcontractor punched the boss in the face they would be thrown out immediately but this criteria is not stated in their selection criteria as are many other criteria that is unofficially used.
I can see the point in inserting a sentence like ‘ suppliers are selected on a range of criteria that usually includes availability, familiarity with the project, previous history and price’ into the quality manual but I don’t see any point in formal pre-qualification as its all too often practiced. I have seen a supplier fail the pre-qualification criteria but they get used anyway because they are the sole supplier in town. It just makes a nonsense of the whole thing.
Moreover, I don’t see from the requirement from the standard below that records of pre-qualification have to be kept, or have I got the wrong idea altogether?
K
kgott
Do you see prequalification in the requirement you posted?.
yes and I reckon the registration process is the prequalification.
I'm fighting this battle with some powers that be Randy because if I lose I'll end up doing something simply because 'that’s what everyone else does' and I want something closer to best practice here not something closer to a 'me too' company that makes us indistinguishable from any other company.
Golfman25
You simply have to be able to answer the question: Is the supplier able to supply the product needed in accordance with our requirements? The answer will vary based upon the product and what your requirements are. Selection of some suppliers might be relatively straight forward -- like they where the only guy in town. Some might need a lot more evaluation. Trying to create some all encompasing criteria will probably lead to problems. I think you take it on a case by case basis. Good luck.
Marcelo
Okay, let'ssee if I can make myself somewhat more clear.
A purchased product is a resource you need to use in a process of your system.
The standard requires that you define (determine) the resource needed for the processes (implement and maintain blah blah blah).
So, when you are bying something, you need to know beforehand what it is, meaning, what are the requirements (need or expectation that is stated, generally implied or obligatory) for this product you need to obtain so that you can run your process.
The standard requires that you evaluate and select suppliers "based on their ability to supply product in accordance with the organization's requirements", meaning, using the requirements for the product that you defined the resource, you need to make sure that the supplier can provide you a product in conformance with those requirements, and if after evaluation it's founthat he does, you then can select it and begin using it.
Why all this?
If you do not define your resource (requirements for the product), you do not know what you need to get in order for your process to run. So you can't buy.
If you do not evaluate the supplier before using it, you may obtain non-conforming supply, which means your process cannot run or will run but won't obtain the required results.
This is not what is required by the standard. A "questionaire" which has nothing to do with the requirements for the resource you need is not in conformance with the standard.
Each supplier should be evaluated based on what it's supplying , meaning, if 10 different suppliers are supplying 10 different products, you would need to have 10 different set of requirements that each supplier would have to fulfill.
Again, this is not what is required by the standard.
In those two cases, you are saying that what people is doing is not value added. You are right, but what you might be wrong is thinking that what people is doing is in conformance with the standard. It's not.
Another point to keep in mind is that standards are created to companies which wants to follow them. If a company does not, there's nothing a standard (which is a piece of paper :)) can do.
And this also means that yes, people can get cerificates even not being in conformity...nothing new here.
You need to record the evaluation of the supplier. If you want to call it qualification, as I said before, no problem, but this is the evaluation that the standard requires and need to be recorded. Why? Well, records have a very direct objective in the ISO 9000 series of standards - they were created as part of the auditing requirement - in which you need to "prove" that you did something. The gneral idea is that you define which requirements are needed for you processes, however in some cases, the standard directly requires come records. This is such a case. There's no objective in recording the evaluation than to have a verifiable evidence that you did it.
Marcelo
Regarding my last thoughts on records from the last post, please note that ISO 9001 coould have no procedure nor record requirement. It "should" let all decisions regarding those for the company implementing it. However, due to a lot of reasons (for example, a biggggg discussion in the committee which writes the standard) there's still some required documents and a lot of required records.
somashekar
Dear kgott..
The Organization comes first, then the QMS fits to the organization. That is the very reason why the statement says " organization's requirements "
It will be wise if you consider all the organization's requirement along with the product and customer requirement into the evaluation and selection process and not use terms like Pre-qualification along with evaluation and selection.
Just evaluate and select based on your " Organization requirement "
Consider all such organization requirements.
Remember that these records need not all be at one place and is not an auditor's requirement first. It must first be organization's requirement.
If your corporate policy is not to buy parts from supplier's who employ child labor, this becomes an organization requirement.
If your finance department wants a particular registration with taxation department for all suppliers, this becomes an organization requirement.
See what else such requirements are within the organization. QMS is for the organization, and not the other way around ~~~
K
kgott
Rightoh, no problem; I agree that we need to evaluate the suppliers capacity to deliver what we require from them and now I ahve some good reasons why.
As a reuslt of the points respondents have made, I certain that the pre-qualification of suppliers as intrepreted and applied by and for the big clients in the resource industry in this part of the world is definately not required by the standard but I suppose this is irrelevent.
thanks to all for your help - k
A Does ISO 9001:2015 cover all the requirements of ISO 10012:2003? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
BeaBea Interesting Discussion Where Does Marketing/ Advertisement of Products fit in to ISO 9001? Process Maps, Process Mapping and Turtle Diagrams 39
G Is ISO 9001:2015 certification worth it for a company that does only contract manufacturing? Quality Management System (QMS) Manuals 14
C Does ISO 9001-2015 have a requirement for manufacturing equipment to be numbered? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 11
Q Does our material suppliers’ supplier have to be at least ISO 9001 certified? IATF 16949 - Automotive Quality Systems Standard 3
M Does ISO 9001 mandates cooking procedure for restaurants ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
Tagin Does ISO 9001:2015 require a full internal audit annually? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 21
N Does anyone know a registrar that offers both ISO 9001 and ISO 17020? Registrars and Notified Bodies 6
Q Does ISO 9001 require CARs for all customer complaints? Customer Complaints 2
qualprod ISO 9001 Cl. 4.1 and 4.2 - What does monitoring and review mean? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 13
Sidney Vianna ASQ apparently doesn't know ISO does not issue ISO 9001 certificates? ASQ, ANAB, UKAS, IAF, IRCA, Exemplar Global and Related Organizations 4
C Optic Patchcord Cables - Does 8.3 (Design) Apply Here? ISO 9001:2015 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
A Does anyone have a comparison between ISO 9001:2015 and ISO 13485:2016? ISO 13485:2016 - Medical Device Quality Management Systems 2
G Does ISO 9001:2015 call for a Policy or a Statement ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 11
Q Does ISO 9001 Requirement for Document Approval (a service organization) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
J Does the word "claim" in ISO 9001 Clause 8.2.2 mean "requirement"? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
T Does your Quality Dept Control Procedures Outside the Scope of ISO 9001? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
S ISO 9001:2008 Certification Scope does not mention "manufacturing" ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
Q Where does 5S technique fit into ISO 9001? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
L What does "conformance matrix" means in terms of ISO 9001:2008? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
G Does AS9100 Certificate include ISO 9001 Certification? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 9
P Does the term ISO 9001:2008 imply we are all five years out of date? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
Marc Does ISO 9001 *require* that Internal Audits be Process Audits? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
L What exactly does Configuration Management in ISO 9001, Clause 7.5.3 means? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
T If a company becomes TS 16949 certified does it still need ISO 9001 certification? IATF 16949 - Automotive Quality Systems Standard 12
G Customer Property Cl. 7.5.4 - Where does ISO 9001 stop and ISO 27001 start? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 33
F Paperless Procedures - Does ISO 9001 Require Paper Documents? Quality Manager and Management Related Issues 37
L Does ISO 9001 require that hard copies of documents be archived? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 13
T Does the Layout Design of a PCB fall under clause 7.3 in ISO 9001 Design and Development of Products and Processes 7
T Employee Satisfaction - Does ISO 9001 Require Monitoring of Employee Satisfaction? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 14
M Does ISO/IEC 17025:2005 require the Laboratory to have separate ISO 9001 Procedures ISO 17025 related Discussions 4
N How does a company determine what ISO standard (9000 or 9001) to register to? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
S How does ISO 9001:2008 apply to a logistics Company? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
C How long does it take to get the ISO 9001 certificate after passing the audit? Registrars and Notified Bodies 21
S Does ISO 9001 Clause 7.3 Design and Development apply? Design and Development of Products and Processes 18
J Customer Property ISO 9001:2008 Clause 7.5.4 - Does this include E-mails? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
H Does ISO 9001 have nothing to do with profitability? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 18
T ISO 9001 Clause 7.3.2 (a) Functional & performance requirement - what does it mean? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
G Does BSI do ISO 9001/TS 16949 Lead Auditor training? Training - Internal, External, Online and Distance Learning 5
J Does plant personnel need to be re-trained to the new ISO 9001:2008 revision?? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 15
V ISO 9001:2008 - How does an organization demonstrate "sustain success"? General Auditing Discussions 14
H QMS - How does ISO 9001 apply to Service Providers (utility or facility management) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
A What is ISO 9001 Certification and how does it relate to Product Quality? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 38
J What does the revised standard ISO 9001:2008 mean to Jim "Q" public ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 44
J Change Management System - Does ISO 9001 specify you need a process flow? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 11
B Does that Q-Policy fulfill ISO 9001 requirements? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
G Does ISO 9001 require a procedure for every part of the business? Document Control Systems, Procedures, Forms and Templates 8
N Poor control of testing chemicals ? which ISO 13485/9001 clause does it contravene? ISO 13485:2016 - Medical Device Quality Management Systems 8
I Does ISO 9001 requires the Control of All Records generated? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
