Does ISO 9001 require that hard copies of documents be archived?
L
Ladyrunaway
i hope somebody could enlighten me :D
i would like to know if
1. does ISO 9001 requires that hard copy of documents shall be archived? or is electronic copy good enough?
2. as per our procedure, document front sheets (not whole document) are being printed out and signed by originators, document control then scans front sheets and throws out the signed hard copy. We then 'use' the pdf version of the document and keep the scanned copy of front sheets to prove the review and approval of the document - the question is, is this valid on ISO 9001 point of view?
any thoughts? thanks in advance :rolleyes:
Well, I'm going to ask if you have or have access to a copy of ISO 9001:2008. That's always the best answer - the one in the document. But, to back that up - if you don't have one - the answer is NO. It doesn't mention anything about that.
If what you describe is your process and the process owner is happy to have people do that, and there's sufficient detail available on which to base a review of a later version etc., then I see not reason to change.
If you ask me does it make sense to me, to do that? I'd be asking some questions...like what does the front sheet actually tell anyone? If you don't have the rest of the document in any form, what's the purpose of a signature?
Big Jim
Note 3 of 4.2.1 says that documentation can be in any form or type of media.
If I understand correctly, you keep both the full copy electronically as well as the scanned front page showing the signature.
As long as your written procedure does not say anything to the contrary, what you are doing is fine.
As to if you really need the signature or not is another discussion, one that I don't care to get into.
Randy
Does 4.2.1 say anything about hardcopy archives?
If the answer is yes, then you have to keep one.
If the answer is no, then you don't have to keep one.
It doesn't matter how one feels, wishes, hopes, desires, or wants all that matters is do you have to do it yes or no.
Rickser
We solved this question by printing out one full copy of the QMS and keeping it in my office for visitor reference. Of course there is documentation in the QMS that there is only one printed copy. All employees have access to the entire QMS via electronic means on SharePoint. I have assigned rights as who can edit (no one but me and my assistant) and we can download and fill out forms (as needed basis, some get all; all get some). We are AS9100 Rev C, but requirement is still the same. Hope this helps.
Rickser
Also, whenever a document is changed, SharePoint archives the older version for us. Again, only the QA folks have access to archived versions. We have the printed copy of each process signed by the process owner, but the electronic copy carries "Original Signed" in that block.
jguild
I'm pretty sure you can document it however you see fit.
My concern for you would be that scanning and creating pdf.s is time consuming. considering that you will be making changes and improvements to these documents, it will be a pain in the bum to update these files in the future.
Maybe you should consider a shared network like stated above by Rickser:bigwave:
JaneB
Q1. Electronic is fine.
As Randy says, the answer is already in ISO 9001 and Jim refers you to the appropriate section (Note 3 of clause 4.2.1 which specifically says that documentation can be in any form or type of media.). It's worth knowing the reference, because it gives you confidence in your decision.
2. What you're doing is fine. Just make sure you've either included it (or at least not contradicted it!) in your procedure.
Actually, while we're on the topic, there's no specific requirement in 9001 to archive documents nor to keep records of signatures approving documents. Whether you archive documents blends into 'records management' to some extent - it's something you have to decided is necessary or not, and why, and for which documents. Ditto signature records.
somashekar
Archiving documents suitably is to prevent them from being used as a live document. In other words these are obsoletes and if you wish to retain them for any purpose (mostly knowledge purpose and for the change trends) you must suitably identify.
The electronic copy will do this purpose but in full and not just the front page.
JaneB
Archiving documents suitably is to prevent them from being used as a live document..
I can see where you're coming from, but I am not sure that I agree this is the purpose of archiving. After all, you can simply destroy a document to prevent it from being used - archiving takes a bit more work, and the more commonly accepted purpose is to have a copy available in case you need to refer to it.
:topic: Leaving aside specialised fields or ones where there is or might be a legal requirement to consult a previous version, over many years I've found very, very, very few occasions when one does want to go back and refer to a previous version of a document. These days, I'm more inclined to destroy as a default position rather than to keep. But of course one must make that decision for each particular quality system, and/or documents that form part of the system.
M Does the scope of ISO 9001:2015 applies to tenders, pricing and sales department of a medical devices distributor? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
A Does ISO 9001:2015 cover all the requirements of ISO 10012:2003? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
BeaBea Interesting Discussion Where Does Marketing/ Advertisement of Products fit in to ISO 9001? Process Maps, Process Mapping and Turtle Diagrams 39
G Is ISO 9001:2015 certification worth it for a company that does only contract manufacturing? Quality Management System (QMS) Manuals 14
C Does ISO 9001-2015 have a requirement for manufacturing equipment to be numbered? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 11
Q Does our material suppliers’ supplier have to be at least ISO 9001 certified? IATF 16949 - Automotive Quality Systems Standard 3
M Does ISO 9001 mandates cooking procedure for restaurants ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
Tagin Does ISO 9001:2015 require a full internal audit annually? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 21
N Does anyone know a registrar that offers both ISO 9001 and ISO 17020? Registrars and Notified Bodies 6
Q Does ISO 9001 require CARs for all customer complaints? Customer Complaints 2
qualprod ISO 9001 Cl. 4.1 and 4.2 - What does monitoring and review mean? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 13
Sidney Vianna ASQ apparently doesn't know ISO does not issue ISO 9001 certificates? ASQ, ANAB, UKAS, IAF, IRCA, Exemplar Global and Related Organizations 4
C Optic Patchcord Cables - Does 8.3 (Design) Apply Here? ISO 9001:2015 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
A Does anyone have a comparison between ISO 9001:2015 and ISO 13485:2016? ISO 13485:2016 - Medical Device Quality Management Systems 2
G Does ISO 9001:2015 call for a Policy or a Statement ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 11
Q Does ISO 9001 Requirement for Document Approval (a service organization) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
J Does the word "claim" in ISO 9001 Clause 8.2.2 mean "requirement"? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
T Does your Quality Dept Control Procedures Outside the Scope of ISO 9001? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
S ISO 9001:2008 Certification Scope does not mention "manufacturing" ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
Q Where does 5S technique fit into ISO 9001? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
L What does "conformance matrix" means in terms of ISO 9001:2008? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
G Does AS9100 Certificate include ISO 9001 Certification? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 9
P Does the term ISO 9001:2008 imply we are all five years out of date? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
Marc Does ISO 9001 *require* that Internal Audits be Process Audits? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
L What exactly does Configuration Management in ISO 9001, Clause 7.5.3 means? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
T If a company becomes TS 16949 certified does it still need ISO 9001 certification? IATF 16949 - Automotive Quality Systems Standard 12
G Customer Property Cl. 7.5.4 - Where does ISO 9001 stop and ISO 27001 start? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 33
F Paperless Procedures - Does ISO 9001 Require Paper Documents? Quality Manager and Management Related Issues 37
K Does ISO 9001 require Supplier Pre-Qualification? Supplier Quality Assurance and other Supplier Issues 27
T Does the Layout Design of a PCB fall under clause 7.3 in ISO 9001 Design and Development of Products and Processes 7
T Employee Satisfaction - Does ISO 9001 Require Monitoring of Employee Satisfaction? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 14
M Does ISO/IEC 17025:2005 require the Laboratory to have separate ISO 9001 Procedures ISO 17025 related Discussions 4
N How does a company determine what ISO standard (9000 or 9001) to register to? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
S How does ISO 9001:2008 apply to a logistics Company? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
C How long does it take to get the ISO 9001 certificate after passing the audit? Registrars and Notified Bodies 21
S Does ISO 9001 Clause 7.3 Design and Development apply? Design and Development of Products and Processes 18
J Customer Property ISO 9001:2008 Clause 7.5.4 - Does this include E-mails? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
H Does ISO 9001 have nothing to do with profitability? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 18
T ISO 9001 Clause 7.3.2 (a) Functional & performance requirement - what does it mean? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
G Does BSI do ISO 9001/TS 16949 Lead Auditor training? Training - Internal, External, Online and Distance Learning 5
J Does plant personnel need to be re-trained to the new ISO 9001:2008 revision?? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 15
V ISO 9001:2008 - How does an organization demonstrate "sustain success"? General Auditing Discussions 14
H QMS - How does ISO 9001 apply to Service Providers (utility or facility management) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
A What is ISO 9001 Certification and how does it relate to Product Quality? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 38
J What does the revised standard ISO 9001:2008 mean to Jim "Q" public ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 44
J Change Management System - Does ISO 9001 specify you need a process flow? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 11
B Does that Q-Policy fulfill ISO 9001 requirements? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
G Does ISO 9001 require a procedure for every part of the business? Document Control Systems, Procedures, Forms and Templates 8
N Poor control of testing chemicals ? which ISO 13485/9001 clause does it contravene? ISO 13485:2016 - Medical Device Quality Management Systems 8
