Does ISO9001 require that a hard copy of a signed procedure be kept?
MsHeeler
Is it required that a hard copy of a signed procedure be kept, or is an electronic copy enough?
liuyy
Re: Is it required that you have a hard copy?
But you must consider regulatory requirement concerning dicuments.
Marc
ISO 9001 does not specifically require that procedures be signed nor that hard copies be kept. However -- If someone is physically signing a procedure as an approval, that is typically the 'Master' copy. You should consider that aspect. Many companies have their master documents on their server and those aren't (obviously) physically signed.
Look at all aspects of your specific document control system especially your document control procedure.
Le Chiffre
I agree and would just add that the standard requires that you control procedures, etc. If the "master" copy is in a location that only the person who would otherwise have signed it has access (everyone else being read-only) and reasonable steps are taken to prohibit someone else using their identity then that's enough control, IMO.
The "controlled" procedure would be placed in the write protected area in lieu of it being signed, with a statement to that effect in the document control procedure.
Randy
I repeat, No, it doesn't.
Electronic is fine if that's your decision. Check 4.2.1, Note 3
Apply the requirements of 4.2.3
One aspect of 'signing' a document is demonstrating review and approval. With paper copies this is easy, but how would you show approvals on an electronic copy? Some software qms programs have a method for this, but if you simply use MS Word, or similar, you also have to consider approvals.
In other threads here, the use of a document approval/change sheet is discussed, so that might include a signature on hard copy.
ISO doesn't address this issue, as you will see when reading it. What has to be considered, however is what an effective document control procedure may require and what you will have to demonstrate to an outside auditor.........
Andy
MsHeeler
Thank you so much for your quick responses. I was on the right track and just needed confirmation.
Problem Solved! :thanx:
D Does ISO9001:2015 require any specific "processes"? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
G Does ISO9001 require every nonconformance to have a root cause analysis? Problem Solving, Root Cause Fault and Failure Analysis 21
J Does Every Staff need to read the ISO9001 Quality Manual from Cover to Cover? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 17
B ISO9001 Process Organisation Diagram - Does this make sense to you? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
A How does your registrar handle 2 certificates, one for AS9100 and one for ISO9001? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 18
D How does ISO9001 fit into a Recruitment Consultancy environment ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
B Does FDA Registration QSR need to cover non-medical devices for contract repackager? US Food and Drug Administration (FDA) 0
0 To which part of 13485 does this refer? ISO 13485:2016 - Medical Device Quality Management Systems 3
lanley liao Does the customer`s trademark belong to customer-supplied property? Oil and Gas Industry Standards and Regulations 2
H How does a gas turbine work on diesel fuel? Oil and Gas Industry Standards and Regulations 12
G What does performance specification include? US Food and Drug Administration (FDA) 1
W Where does a coatings and paint company fall in IATF? IATF 16949 - Automotive Quality Systems Standard 5
C Does an accessory need an IFU if it use is discussed in the Parent device IFU? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 5
S How long does it take to register a product with MHRA? UK Medical Device Regulations 3
M Quality Manual - Where does Revision History Section go? Document Control Systems, Procedures, Forms and Templates 8
A Brexit When does the UK responsible person need to be in place? UK Medical Device Regulations 10
N Does anyone have experience of GB/T 34986-2017? China Medical Device Regulations 1
Z Does anyone have experience with EN ISO 17664 ? IEC 62366 - Medical Device Usability Engineering 9
F Does anyone have an ESD quality/cooler talk to share? Training - Internal, External, Online and Distance Learning 4
A What does this line from MDCG 2020-3 (MDR art. 120 substantial change) mean to you? EU Medical Device Regulations 4
T What does AS9100 mean when it says you must establish a process to do X? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 24
L Does a backdate form format can be changed if wrong revision is used? Document Control Systems, Procedures, Forms and Templates 8
B General Motors and Honda Alliance - What does this mean to suppliers? IATF 16949 - Automotive Quality Systems Standard 3
C ISO 13485 :2016 - CAPA - Does every CAPA need to be checked by regulations? ISO 13485:2016 - Medical Device Quality Management Systems 9
A Does ISO 9001:2015 cover all the requirements of ISO 10012:2003? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
N FDA UDI - Label vs. Labeling - Does the insert need to include UDI? Other US Medical Device Regulations 1
A Does anyone have a checklist of API Spec 650 13th Edition? Oil and Gas Industry Standards and Regulations 0
D Does Manufacture can submit CE mark application under MDD with NB for his New product after May 2020? EU Medical Device Regulations 3
A What does this sentence "this symbol shall be used in the orientation shown" mean in ISO 780:2015? Other Medical Device Related Standards 4
L Turkish Requirements - Does the Software need to be translated? CE Marking (Conformité Européene) / CB Scheme 2
J Does Pakistan Medical Device Import License allows parallel import? Other Medical Device Regulations World-Wide 0
BeaBea Interesting Discussion Where Does Marketing/ Advertisement of Products fit in to ISO 9001? Process Maps, Process Mapping and Turtle Diagrams 39
P Does anyone have a API Q1 Documentation Package? Quality Management System (QMS) Manuals 1
N What is our product classification? (Does Unclassified classification still exists) Other US Medical Device Regulations 14
C Does a CE mark infer meeting all applicable standards? CE Marking (Conformité Européene) / CB Scheme 4
N Small Company - Internal audit process - Who does the audit? Internal Auditing 16
J Does anyone have an excel IATF 16949 Internal Audit checklist I could use? IATF 16949 - Automotive Quality Systems Standard 7
A Does AS9100 require traceability to operators performing the work? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
I Does anybody use Detection in medical device Design FMEA? ISO 14971 - Medical Device Risk Management 18
A EN ISO 14971:2019 does not include the Annex Zs ISO 14971 - Medical Device Risk Management 4
