Does long-term body worn medical monitoring device need to meet IEC 60601-1-11?
Roland chung
Hi all,
There is a long-term body worn monitoring device (48 hours at least). Since the patient can go everywhere including home while wearing, the auditor said IEC 60601-1-11 should be considered. Is that true?
Thanks,
Roland
Peter Selvey
Yes, the standard indicates that it is applicable if the equipment can be used in the home, even if the device is for example owned by a hospital, set up by the hospital, and only given to the patient for temporary use.
The standard is new and there are some parts which I think are controversial, such as the IP and Class II ratings. There are also some expensive tests for performance under various stress tests like vibration and temperature.
These expensive tests are controversial for two points: 1) why just home use? They should apply to all equipment. 2) in the real world, a degree of engineering judgment is necessary i.e. look at the individual design what tests are important. Some equipment is sensitive to temperature and humidity so careful tests over the full normal environment is reasonable, other types are sensitive to vibration. To keep the costs down, the manufacturer should be able to select the tests as appropriate for the device (I hesitate to say risk management, since it is really an engineering judgement).
Roland chung
Thank you. You already mentioned my concerns (IP test and mechanical strength test).
When I checked Holter's standard (60601-2-47:2012), such strict requirements cannot be found. I think Holters available on the market are hard to fully meet the 60601-1-11. Are we aware of any incidents happened with 2nd edition approved Holters outside the clinical setting?
S How long does it take to register a product with MHRA? UK Medical Device Regulations 3
Proud Liberal How long does your company take to close an 8D on average? Problem Solving, Root Cause Fault and Failure Analysis 12
L Medical Device New Product Design & Development- How long does this process take you? Other Medical Device and Orthopedic Related Topics 1
W AS9100C registration - How long does the system have to run before initial audit? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 9
C How long does AS9100 QMS need to be in place before the Audit? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 13
A How long does it take US FDA to issue a Warning Letter Close Out Letter Other US Medical Device Regulations 2
C How long does it take to get the ISO 9001 certificate after passing the audit? Registrars and Notified Bodies 21
Y Why does it take so long for a Food Recall to come out? US Food and Drug Administration (FDA) 1
E How long does it take to certify a scope extension? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
C How long does it take to clear back ground checking? Career and Occupation Discussions 7
R How long does it take for registrar to issue certificate? Registrars and Notified Bodies 8
L CE Mark - FDA - Class I traction systems - What is involved and how long does it take EU Medical Device Regulations 5
0 To which part of 13485 does this refer? ISO 13485:2016 - Medical Device Quality Management Systems 3
lanley liao Does the customer`s trademark belong to customer-supplied property? Oil and Gas Industry Standards and Regulations 2
H How does a gas turbine work on diesel fuel? Oil and Gas Industry Standards and Regulations 12
G What does performance specification include? US Food and Drug Administration (FDA) 1
W Where does a coatings and paint company fall in IATF? IATF 16949 - Automotive Quality Systems Standard 5
C Does an accessory need an IFU if it use is discussed in the Parent device IFU? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 5
M Quality Manual - Where does Revision History Section go? Document Control Systems, Procedures, Forms and Templates 8
A Brexit When does the UK responsible person need to be in place? UK Medical Device Regulations 10
N Does anyone have experience of GB/T 34986-2017? China Medical Device Regulations 1
Z Does anyone have experience with EN ISO 17664 ? IEC 62366 - Medical Device Usability Engineering 9
F Does anyone have an ESD quality/cooler talk to share? Training - Internal, External, Online and Distance Learning 4
A What does this line from MDCG 2020-3 (MDR art. 120 substantial change) mean to you? EU Medical Device Regulations 4
T What does AS9100 mean when it says you must establish a process to do X? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 24
L Does a backdate form format can be changed if wrong revision is used? Document Control Systems, Procedures, Forms and Templates 8
B General Motors and Honda Alliance - What does this mean to suppliers? IATF 16949 - Automotive Quality Systems Standard 3
C ISO 13485 :2016 - CAPA - Does every CAPA need to be checked by regulations? ISO 13485:2016 - Medical Device Quality Management Systems 9
A Does ISO 9001:2015 cover all the requirements of ISO 10012:2003? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
N FDA UDI - Label vs. Labeling - Does the insert need to include UDI? Other US Medical Device Regulations 1
A Does anyone have a checklist of API Spec 650 13th Edition? Oil and Gas Industry Standards and Regulations 0
D Does Manufacture can submit CE mark application under MDD with NB for his New product after May 2020? EU Medical Device Regulations 3
A What does this sentence "this symbol shall be used in the orientation shown" mean in ISO 780:2015? Other Medical Device Related Standards 4
L Turkish Requirements - Does the Software need to be translated? CE Marking (Conformité Européene) / CB Scheme 2
J Does Pakistan Medical Device Import License allows parallel import? Other Medical Device Regulations World-Wide 0
BeaBea Interesting Discussion Where Does Marketing/ Advertisement of Products fit in to ISO 9001? Process Maps, Process Mapping and Turtle Diagrams 39
P Does anyone have a API Q1 Documentation Package? Quality Management System (QMS) Manuals 1
N What is our product classification? (Does Unclassified classification still exists) Other US Medical Device Regulations 14
C Does a CE mark infer meeting all applicable standards? CE Marking (Conformité Européene) / CB Scheme 4
N Small Company - Internal audit process - Who does the audit? Internal Auditing 16
