Does Sampling Plan Revision need Customer Approval?
Dottie123
[FONT=&quot]1) W[/FONT]hen I look at the finished product specification provided by the customer for their disposable medical devices, it provides the sampling plan and inspection for release of finished product. It then lists the critical, major and minor areas of the product to be tested along with the attributes that need to be tested to ensure we are releasing a ?quality? product. Do we have to test every aspect listed on this sampling plan or can I pick and choose as long as we can justify why we are not testing some area and documenting the results. Also, there may be several inspection levels listed int eh sampling plan which means that the QC Tech has to keep up with which sampling plan and which AQL to use for each attribute of the medical device. I would like to implement an internal inspection plan where we choose the highest inspection level and AQL and inspect rather than going back and forth. If I revise this, do I need the customer?s approval to change and use my plan.
NikkiQSM
Re: Sampling Plan Revision
If you agreed to produce a product to the customer's specification, then you have to do what the spec says.
If you feel some testing is not needed, or some information is not needed, then contact the customer and voice your concerns. Ask that they update their specification if they agree the testing is not needed either and get the new revision in your system.
I
isoalchemist
The Customer may not always be right, but they are the customer and if you have agreed to meet their specifications, you need to perform the testing as they have defined it.
If their testing is a problem, you need to have a discussion. You will find one of two things either they have a valid reason for why they chose the testing scheme the did or you will get blank stares. It's worth the discussion if you can have it, but don't change anything without their approval or technically you will be in breach of contract which is a lot worse than extra testing.
amit_rd
It is wise to have the revised plan signed off with the Customer. You may need to demonstrate that the quality targets can be achieved with the revised plan.
You may initiate this as a continual improvement project, during the process involve your customer and get the "not necessary" inspection points parked for a test run. Once this test run proves that quality can be assured without these identified points you may revise your plan.
This way you will also win the confidence of the customer.
Jon Nonns
As the other responses have said you need to be very cautious not to breach contract so customer approval is a definite (I would require them send a revised specification or sign off on yours prior to implemenetation). One additional twist is since this is a medical device, the quality control plan, including tests and testing frequency, may have been reviewed and approved by a regulatory agency or body and therefore this might not be a simple change to be made. Of course this highly depends on the class of medical device and where it is distributed. Good luck!
Jon
P Sampling Plan - What sampling plan does Customs or Regulatory Authority use at border Other Medical Device Regulations World-Wide 3
T Continuous Sampling Plan for small lot sizes: Does MIL-STD 1235B provide one? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
A Sampling - What does it mean by Sampling in ISO:IEC 17025 ISO 17025 related Discussions 1
D Ppk Sampling Method - Does data for Ppk have to been continuous? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 4
J Sampling Definition I.A.W. 17025 - Does sampling apply to calibration laboratories? ISO 17025 related Discussions 8
D Does the DoC require a technical documentation version? ISO 13485:2016 - Medical Device Quality Management Systems 1
S Local (country) registration of medical devices - Who does it in best case? Other Medical Device Regulations World-Wide 2
G When does containment event not require 100% sort? Nonconformance and Corrective Action 5
H Does this clause mean i must be in compliance with AS9100 or is 9001 enough? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
H Does ISO state in anyway that we MUST keep physical first piece parts? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
XRAY_3121 Class II heating pad - does the power supply have to have IEC 60601-1 testing?? US Medical Device Regulations 5
F Change in address for critical supplier - does NB need to be informed? CE Marking (Conformité Européene) / CB Scheme 20
S Brexit ISO 13485:2016 + Corrigendum - What does a UKCA DoC require? EU Medical Device Regulations 2
G Does anyone know about tobacco-free nicotine pouches? US Food and Drug Administration (FDA) 0
cgaro62 Does FDA apply to a non-medical 13485 certified custom manufacturing company? ISO 13485:2016 - Medical Device Quality Management Systems 11
R Does anyone use iQMS for their ISO based document control? Manufacturing and Related Processes 1
V How many hrs does it take to create a Technical File (TD)? EU Medical Device Regulations 4
M How does FDA determine OAI and VAI after inspection? ISO 13485:2016 - Medical Device Quality Management Systems 0
G Does TPI agencies comes under outsourced process as per Q1 Oil and Gas Industry Standards and Regulations 11
N FPY requested for an industry that does not have rework IATF 16949 - Automotive Quality Systems Standard 4
William55401 21 CFR 11 Password Aging - What does "periodically" revised mean in your org? Qualification and Validation (including 21 CFR Part 11) 3
I CQI-15 Welding System Assessment 2nd edition - Does not require Ultrasonic Welding anymore? Customer and Company Specific Requirements 0
Ajit Basrur Does "Refurbishment" fall under "Service"? ISO 13485:2016 - Medical Device Quality Management Systems 13
T Does marketing company require CE mark if manufacturer has CE mark on product? EU Medical Device Regulations 5
Watchcat REGULATORY WATCHCAT De Novo Post-Mortem 6 – How Does This Even Happen? Other US Medical Device Regulations 0
T What does VW mean by annual requalification? Customer and Company Specific Requirements 4
I Does BSI require suppliers to be ISO 9001 Certified? EU Medical Device Regulations 12
Watchcat Does Regulatory Affairs put the "no" in innovation? Other US Medical Device Regulations 14
Q Does anyone know what this call out means? Manufacturing and Related Processes 3
K COPLANARITY: Composite profile tolerance on multiple surfaces- what does" lower dimensional reference frame tolerance" control? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 11
P Does FDA require certification for quality system internal audit for auditor? Qualification and Validation (including 21 CFR Part 11) 1
H Does anyone has feedback on a notified body for small companies? EU Medical Device Regulations 3
M Does 4.5 - Alternative RISK CONTROL apply to the Particular Standards? IEC 60601 - Medical Electrical Equipment Safety Standards Series 3
E Does IVD need to integrate with hospital IT infrastructure? Medical Information Technology, Medical Software and Health Informatics 2
D What does a level 1 (PSW) PPAP actually promise? APQP and PPAP 19
R GS1 DataMatrix code does not meet GS1 Specification EU Medical Device Regulations 0
M Does the scope of ISO 9001:2015 applies to tenders, pricing and sales department of a medical devices distributor? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
K Why does load cell supplier requires force verification General Measurement Device and Calibration Topics 3
M Does C=0 strictly mean 1 bad, all bad, all the time? ISO 13485:2016 - Medical Device Quality Management Systems 6
C Does a medical device active (zinc oxide) needs BPR registration in EU? Other ISO and International Standards and European Regulations 6
D Does Risk Management apply to re-labeler (MDR) EU Medical Device Regulations 1
Ed Panek Does this FDA Requirement Apply to international (not USA) distributors for USA based manufacturing companies? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 0
S Does anyone have a checklist to prepare for ISO 13485, Stage I audit? ISO 13485:2016 - Medical Device Quality Management Systems 3
S Does a refurbished product required a new UDI? US Food and Drug Administration (FDA) 3
D Change to labelling - does it require a new 510(k)? US Food and Drug Administration (FDA) 5
M What does "constantly" mean ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 13
N Does anyone use SGS for ISO 13485 / CE certification Registrars and Notified Bodies 0
G Does FDA allows remote approvals of quality documentation. Is there any specific guidance on signing any quality records remotely? Document Control Systems, Procedures, Forms and Templates 1
B Does FDA Registration QSR need to cover non-medical devices for contract repackager? US Food and Drug Administration (FDA) 1
