Does the AS9102 FAI requirement apply to wire assembly sub-kits?
N
n8vebeauty
:bigwave: Hello,
I am fairly new at my company. I am concerned that we are not meeting the AS9102 FAI requirement for our wire assembly sub-kits.
When I started there were no FAI records for wire assembly sub-kits. So, we began completing them for all sub-kits, this has caused several jobs held for the completion of a FAI. (An example of each kit contains, Wire that has been cut and coded; Connectors; Contacts; Pins; Lacing Tape; Wire Bundle Identification Labels/Tapes). We are no longer completing FAI's for Wire Assembly Sub-Kits due to the amount of man power and $$$ needed.
Do sub-kits require first article inspection records? If so, any suggestions how we can satisfy the AS9102 requirement in a simple manner that will not cost our non-profit company a great amount of man power and money? My interpretation of AS9102 (clause 5.3) is that we can satisfy the requirement if there has been "previosly approved FAI performed on identical characteristics of similar parts produced by identical means". Meaning we can complete a FAI report for each family number of wire assembly sub-kits. Does anyone agree or disagree??? :thanks:
andygr
For those cases in subcomponents that have common sub-subcomponents:confused: You only have to perform the FAI on one PN that would then have the FAI recored number "assigned" to mutiple FAI at the next level up.
For a simple example you have a print showing that you cut an individal wire 10 inchs long. This wire ( fabricated to a print) is then used in 20 differant wire harness subassemblies. You only have to perform the FAI once on a single wire and assign the FAI report number for the wire 20 times at the next level in block 18 of the next level assembly FAI report.
:2cents:
Which parts in the kit do you produce and which parts do you buy? Can any of the purchased parts be considered “standard catalog hardware”? Personally, I would focus on the differences between the kits regarding those parts that you produce and exempt any purchase standard catalog hardware. Then, when you do an FAI for a sub-kit, just inspect those components and characteristics that are unique to the kit. If you produce components that are common to all kits, just make reference to that FAIR within the FAIR’s for the individual kits. Clear as mud, eh?
BTW, it seems to me that a non-profit AS9100 certified company is a bit of a rarity. Do you have a customer that is requiring AS9102 compliance?
alspread
Does the kit have a part number or other designation with any requirements? Or is it a compilation of other part numbers with their own requirements.
If the kit is has it's own part number with requirements, then yes, it does require a first article. These requirements (probably very little) should be listed on the form 3. All of the items in the kit would be listed on form 1 and reference all of their own unique first articles. Form 2 would probably be blank, assuming you perform no special processes or procure any raw material.
Imagine if you revised the kit to replace one item with another. You would then perform a delta first article, revising the form 1 and any affect this item change would of had on the requirements listed on form 3.
It sounds like a lot, but its probably more paperwork documentation than anything else. At least someone had to go through a structured approach to the change and consider the affects.
Good Luck
N
n8vebeauty
Thanks to all that responded. This is my first time posting and I am impressed with your responses. It's still unclear how we should handle these.
BagerMan: Depending on our customer, all parts are supplied by the customer or are purchased by us. Yes, some of the parts that will become part of the kit are "standard catalog hardware". And yes. Our customer is Boeing, which requires us to be AS9102 complaint.
alspread: Yes, each kit has it’s own part number. The only thing we alter is the wire that we laser code and cut to length and imprint text on labels/tapes and include them with the kit. The issue is that there are so many different components (standard catalog hardware) required. It is taking a tremendous amount of time completing the FAI record.
Is it acceptable to attach the drawing to the FAI record and reference that page on the record itself? The drawing list all components needed for the kit.
alspread
I don't know if it has been pointed out yet, but stabdard catalog hardware does not require a first article. So, if your delivered part number is a compliation of catalog hardware, then your first article is mostly paperwork to reconcile all of these items. You may have a few characteristics that you generate that you will have to account for and take care of.
I'm not sure I understand all of your constraints but, but if you want some help, or just want to talk about it, please contact me.
M FAI AS9102 - What does a First Article Inspection cover? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 11
V AS9100 and AS9102 - Does our supplier have to do the FAI using the 3 AS9102 forms? Document Control Systems, Procedures, Forms and Templates 3
D Following AS9102 for FAI Requirements - Does EVERY Component Need Its Own FAI? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 40
R Does anyone know when AS9102 Rev B will be released? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
T What does an auditor review when auditing a AS9102 FAIR? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
A AS9102 Training - Does anyone have a good AS9102 training presentation AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
F Does anyone have an ESD quality/cooler talk to share? Training - Internal, External, Online and Distance Learning 4
A What does this line from MDCG 2020-3 (MDR art. 120 substantial change) mean to you? EU Medical Device Regulations 3
T What does AS9100 mean when it says you must establish a process to do X? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 24
L Does a backdate form format can be changed if wrong revision is used? Document Control Systems, Procedures, Forms and Templates 8
B General Motors and Honda Alliance - What does this mean to suppliers? IATF 16949 - Automotive Quality Systems Standard 3
C ISO 13485 :2016 - CAPA - Does every CAPA need to be checked by regulations? ISO 13485:2016 - Medical Device Quality Management Systems 9
A Does ISO 9001:2015 cover all the requirements of ISO 10012:2003? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
N FDA UDI - Label vs. Labeling - Does the insert need to include UDI? Other US Medical Device Regulations 0
A Does anyone have a checklist of API Spec 650 13th Edition? Oil and Gas Industry Standards and Regulations 0
D Does Manufacture can submit CE mark application under MDD with NB for his New product after May 2020? EU Medical Device Regulations 3
A What does this sentence "this symbol shall be used in the orientation shown" mean in ISO 780:2015? Other Medical Device Related Standards 4
L Turkish Requirements - Does the Software need to be translated? CE Marking (Conformité Européene) / CB Scheme 2
J Does Pakistan Medical Device Import License allows parallel import? Other Medical Device Regulations World-Wide 0
BeaBea Interesting Discussion Where Does Marketing/ Advertisement of Products fit in to ISO 9001? Process Maps, Process Mapping and Turtle Diagrams 39
P Does anyone have a API Q1 Documentation Package? Quality Management System (QMS) Manuals 1
N What is our product classification? (Does Unclassified classification still exists) Other US Medical Device Regulations 14
C Does a CE mark infer meeting all applicable standards? CE Marking (Conformité Européene) / CB Scheme 4
N Small Company - Internal audit process - Who does the audit? Internal Auditing 16
J Does anyone have an excel IATF 16949 Internal Audit checklist I could use? IATF 16949 - Automotive Quality Systems Standard 7
A Does AS9100 require traceability to operators performing the work? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
I Does anybody use Detection in medical device Design FMEA? ISO 14971 - Medical Device Risk Management 18
A EN ISO 14971:2019 does not include the Annex Zs ISO 14971 - Medical Device Risk Management 4
Watchcat Does "Similar Device" = "Predicate"? EU Medical Device Regulations 7
Y Does Solidworks (2D/3D drafting modules) need validation? Other Medical Device and Orthopedic Related Topics 5
M Definition Open Audit - What does an Open Audit mean? Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 3
I Does training have to be written? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
P What does UPH/m² mean? Quality Tools, Improvement and Analysis 3
L "IATF-Compliant" IATF 16949:2016 certification? What does this mean? IATF 16949 - Automotive Quality Systems Standard 13
D Why does Official Journal list superseded standards? EU Medical Device Regulations 6
B Record Management - Does the QMS need to control templates of records? Records and Data - Quality, Legal and Other Evidence 17
MDD_QNA QR Code Standard ISO/IEC 15417:2007 - Does anyone use it? Other Medical Device Related Standards 3
R Does any here use an internal auditing tool that works on different platforms? Internal Auditing 3
Sidney Vianna IAQG SCMH explains "positive risk"..........but does it? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
D Where does "as far as possible" stop? FMEA - EN 14971 ISO 14971 - Medical Device Risk Management 29
W Does anyone have an API Q2 checklist for internal auditing? Oil and Gas Industry Standards and Regulations 1
L External power supplies: How close does the safety report have to match the end-use application? IEC 60601 - Medical Electrical Equipment Safety Standards Series 4
Watchcat Does 820.30 include the manufacturing process? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 2
Watchcat Does ISO 13485 7.3 include the manufacturing process? ISO 13485:2016 - Medical Device Quality Management Systems 14
R When does the FDA consider a component a medical device? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 17
B Does EN ISO 15223-1:2016 include the graphic symbols to be added to software and IFU? Other Medical Device Related Standards 9
