Does the Layout Design of a PCB fall under clause 7.3 in ISO 9001
tonyjj
Hello all,
I am curious to know whether or not designing the layout of a printed circuit board is considered part of an overall process or is it deemed to be conceptual design and thus cause 7.3 applies.
If yes does anyone have a design control procedure for same.
Many thanks in advance.:confused:
Marc
Fully vaccinated are you?
I can't tell you the answer to your question, but I can tell you from experience in the 1980's PCB layout is an art, especially since the advent of SMT components. I have never personally designed PCBs, but I tested many, many of them for failure modes over the years. Many of the failures were board layout issues (as opposed to component failures) such as heavy components in or near the center of the board, resonant frequencies of the board and the enclosure, and things like that.
Just a comment - Hopefully someone here can help with your specific question.
somashekar
It very much is a part, whether it is done by the organization or outsourced to a specialist. Apart from what Marc has mentioned there are several other considerations and guidelines that are applied in the process., like the EMI / EMC considerations, electrical safety isolations, grounding, size and shape and connector configurations as desired by the customer, alternate footprint for components in case there are options, test points considerations, physical mounting considerations, add on features considerd to have one PCB for various versions of the product with the BOM listing DNA (Do Not Assemble) parts where not required .... and many more.
Like all other design steps, this is also a very important step to be reviewed, verified and validated, perhaps critical to the performance. Like other skills this is also a specific technical skill mastered over time, and there are several books / litratures on this topic. There is nothing like one best layout design. Check with any good PCB layout expert for more specific design control requirements.
tonyjj
Thanks the comments guys very informative. would anyone else like to contribute their experience/ comments to the thread.discussion?
christinelim
Hi Tonyjj,
Currently I had gone through my ISO 9001 2008 stage 1 audit, the auditor asked me must prepare a procedure for PCB layout design. I am facing the same problem as you. Have you solved your problem? Do you mind to share with me?
Thank you
Jeff Frost
The design of any product falls under clause 7.3 of the standard if your organizations is designing them for manufacture by a board shop or in-house. This does not, however, require jumping through hoops to meet ISO 9001:2008 only the linking of current in-house IPC design practices to the requirements of the Standard and filling in the gap that may be present.
W
woody_rod
Hello all,
Tony,
One thing to keep in mind with design and development, is the purpose this section was included into the standard. Literal translations of the standard often miss the intent - in this case, being that for design of an item that will eventually be part of a system supplied to customer specifications.
Anything that is included into the end product, to fit within any specified requirement, will fall under section 7.3. It must do if you think about it. Consider the process of design - starting with the first line of thought that generates the need for the item in question (such as a meeting of board members to create a product to meet customer demand - the first thing said about what the product needs to look like, size, shape etc is the beginning of design and development). As distant as it seems in later stages, everything leading up to product realisation must be considered under 7.3.
Having said that, there are degrees of criticality with components that will generate the need to have a higher or lower priority within the QMS in order that the more critical processes are more closely monitored. Some examples would be:
1. A bracket holding a computer main board in place that is neither seen by the customer, nor is considered critical for the performance of the product.
2. The main board itself. This is considered critical to the performance of the product to meet specified requirements.
The items above are both required to complete the product, but their criticality is very different. An auditor (and the QMS owner) should both be able to identify that there will be vastly more resources put into the verification and validation of the main board, but not the bracket, and also that there will be much more emphasis on the main board in terms of the need to comply with section 7.3.
Both items need to have a history of design and development either way.
J How does Layout Inspection determine Reference Value? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
D What does a level 1 (PSW) PPAP actually promise? APQP and PPAP 7
R GS1 DataMatrix code does not meet GS1 Specification EU Medical Device Regulations 0
M Does the scope of ISO 9001:2015 applies to tenders, pricing and sales department of a medical devices distributor? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
K Why does load cell supplier requires force verification General Measurement Device and Calibration Topics 3
M Does C=0 strictly mean 1 bad, all bad, all the time? ISO 13485:2016 - Medical Device Quality Management Systems 6
C Does a medical device active (zinc oxide) needs BPR registration in EU? Other ISO and International Standards and European Regulations 1
D Does Risk Management apply to re-labeler (MDR) EU Medical Device Regulations 1
Ed Panek Does this FDA Requirement Apply to international (not USA) distributors for USA based manufacturing companies? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 0
S Does anyone have a checklist to prepare for ISO 13485, Stage I audit? ISO 13485:2016 - Medical Device Quality Management Systems 1
S Does a refurbished product required a new UDI? US Food and Drug Administration (FDA) 3
D Change to labelling - does it require a new 510(k)? US Food and Drug Administration (FDA) 5
M What does "constantly" mean ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 13
N Does anyone use SGS for ISO 13485 / CE certification Registrars and Notified Bodies 0
G Does FDA allows remote approvals of quality documentation. Is there any specific guidance on signing any quality records remotely? Document Control Systems, Procedures, Forms and Templates 1
B Does FDA Registration QSR need to cover non-medical devices for contract repackager? US Food and Drug Administration (FDA) 1
0 To which part of 13485 does this refer? ISO 13485:2016 - Medical Device Quality Management Systems 3
lanley liao Does the customer`s trademark belong to customer-supplied property? Oil and Gas Industry Standards and Regulations 2
H How does a gas turbine work on diesel fuel? Oil and Gas Industry Standards and Regulations 12
G What does performance specification include? US Food and Drug Administration (FDA) 1
W Where does a coatings and paint company fall in IATF? IATF 16949 - Automotive Quality Systems Standard 5
C Does an accessory need an IFU if it use is discussed in the Parent device IFU? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 5
S How long does it take to register a product with MHRA? UK Medical Device Regulations 8
M Quality Manual - Where does Revision History Section go? Document Control Systems, Procedures, Forms and Templates 8
A Brexit When does the UK responsible person need to be in place? UK Medical Device Regulations 10
N Does anyone have experience of GB/T 34986-2017? China Medical Device Regulations 1
Z Does anyone have experience with EN ISO 17664 ? IEC 62366 - Medical Device Usability Engineering 9
F Does anyone have an ESD quality/cooler talk to share? Training - Internal, External, Online and Distance Learning 4
A What does this line from MDCG 2020-3 (MDR art. 120 substantial change) mean to you? EU Medical Device Regulations 4
T What does AS9100 mean when it says you must establish a process to do X? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 24
L Does a backdate form format can be changed if wrong revision is used? Document Control Systems, Procedures, Forms and Templates 8
B General Motors and Honda Alliance - What does this mean to suppliers? IATF 16949 - Automotive Quality Systems Standard 3
C ISO 13485 :2016 - CAPA - Does every CAPA need to be checked by regulations? ISO 13485:2016 - Medical Device Quality Management Systems 9
A Does ISO 9001:2015 cover all the requirements of ISO 10012:2003? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
N FDA UDI - Label vs. Labeling - Does the insert need to include UDI? Other US Medical Device Regulations 1
A Does anyone have a checklist of API Spec 650 13th Edition? Oil and Gas Industry Standards and Regulations 0
D Does Manufacture can submit CE mark application under MDD with NB for his New product after May 2020? EU Medical Device Regulations 3
A What does this sentence "this symbol shall be used in the orientation shown" mean in ISO 780:2015? Other Medical Device Related Standards 4
L Turkish Requirements - Does the Software need to be translated? CE Marking (Conformité Européene) / CB Scheme 2
J Does Pakistan Medical Device Import License allows parallel import? Other Medical Device Regulations World-Wide 0
