Does this calibration method of a specific fixture make sense?
  • Thread starter qualitygoddess - 2010
  • Start date
Q
Hello:
I have read through other prior threads and postings regarding go/no go gauge calibration. I have a question regarding a specific fixture and our plan to calibrate it prior to use. I would appreciate your input if you think this makes sense.
1. we are assembling various components inside a large box made of sheet metal. The customer had us build a fixture #1 on which we place the box for assembly. There are locating pins on the fixture, and the box has corresponding machined holes that allow it to rest on the fixture and stay in one place. FYI, fixture #1 is bolted to the floor and made from a painted metal stock that has been welded together.
2. the customer had us build a checking fixture #2 to verify that the fixture #1 was "in calibration". That fixture #2 has been verified for form and fit, such as it is made from a material with excellent dimensional stability and we know that its alignment holes are in the right place (using calibrated devices at the machine shop). We are calling fixture #2 calibrated. We have defined storage and handling conditions for fixture #2.
3. fixture #2 is then used to calibrate fixture #1 via a visual verification that the holes and pins fit together. If they do, then fixture #1 is within the tolerances for x and y dimensions we have to meet for overall size and squareness.
4. for records, I plan to keep the initial verification done for fixture #2 from the machine shop, and put it's re-calibration on a 2 year cycle (it gets used 10-15 times per year). I will also keep records of the calibration of fixture #1 each time we use fixture #2 to check it.
Does this make sense?
Thanks!
somashekar
Re: Does this calibration method make sense?
Hello:
Thanks!
Makes perfect sense ... but just call your this procedure a verification method.
bobdoering
Stop X-bar/R Madness!!
Makes perfect sense ... but just call your this procedure a verification.
I would say it looks adequate. As long as the gages used to verify the master is within its specifications are calibrated and at least 4:1 or 10:1 more accurate than the print callouts, you can feel free to call it calibration (as it is traceable). Be sure to check for hole ID wear, too.
somashekar
When F#2 is used on F#1 the resulting record is an attribute and not a measureable value. Hence I could not think of how a traceability can be established. For this reason I hesitated to call this check procedure a calibration.
bobdoering
When F#2 is used on F#1 the resulting record is an attribute and not a measurable value. Hence I could not think of how a traceability can be established. For this reason I hesitated to call this check procedure a calibration.
There really is no definitive definition of the terms. I would go with calibration because of traceability. I have not come across anything that would convince me that attribute versus variable results trumps traceability and makes it verification. Certainly the inability to adjust does not come into play. Although the terms are tossed about in discussion, if a customer requested using a 'calibrated gage', I would say this qualifies since 1) it is traceable and 2) the customer themselves probably have made no distinction between calibration and verification.
David Hartman
Sounds perfectly adequate. Your gage number 2 is what the old Mil specs would have referred to as a transfer gage. Just ensure that the traceability is capable of going back to NIST (i.e. the specific calibrated instruments used to "calibrate" gage 2 are traceable to NIST), this would provide full closure to the trace issue.
sitapaty
Hello:
Thanks!
Document a calibration work instruction in the lines you have described.Fix periodicity of calibration.It will meet the requirements.
sitapaty
alspread
I think it sounds okay too. It has to comply with the following
Where necessary to ensure valid results, measuring equipment shall
a) be calibrated or verified, or both, at specified intervals, or prior to use, against measurement standards traceable to
international or national measurement standards; where no such standards exist, the basis used for calibration or
verification shall be recorded (see 4.2.4);
b) be adjusted or re-adjusted as necessary;
c) have identification in order to determine its calibration status;
d) be safeguarded from adjustments that would invalidate the measurement result;
e) be protected from damage and deterioration during handling, maintenance and storage.
F1 is your measuring equipment and F2 is the calibration standard. See clause a above.
Good Luck
S How PMEL does a limited calibration - Tensiometers ISO 17025 related Discussions 1
M Does Calibration to ISO/IEC 17025 conform to Z540.3? ISO 17025 related Discussions 1
S Does NIST Certify Calibration Laboratories? General Measurement Device and Calibration Topics 4
R When does a pH Meter require Calibration? Calibration Frequency (Interval) 7
M Does 17025/NADCAP allow deferring Calibration Start Dates on Gages which are Stored? ISO 17025 related Discussions 10
J Maximo Calibration - Does anyone use Maximo Calibration Module? Calibration and Metrology Software and Hardware 4
B Does Welding Equipment need or require Calibration General Measurement Device and Calibration Topics 30
R Does Humidity affect Electronic Instrument Calibration? General Measurement Device and Calibration Topics 16
I Does Anyone Have any Basic Calibration Training Materials? General Measurement Device and Calibration Topics 5
S Audit and Calibration question - does verification alone meet the requirements? General Auditing Discussions 5
B Does each shot peening timer require calibration - AS9100 requirements AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
Crusader Self-Calibrating Furnace does not require calibration General Measurement Device and Calibration Topics 15
R What does dropping ANSI Z540 Calibration Standard mean to my program? General Measurement Device and Calibration Topics 16
D Does waste water equipment need calibration if we also outsource testing? Miscellaneous Environmental Standards and EMS Related Discussions 12
R Construction: Does new Inspection and Measurement Equipment require calibration? General Measurement Device and Calibration Topics 22
P Plug Gage Calibration Report does not include actual data - ISO 9001:2000 section 7.6 General Measurement Device and Calibration Topics 3
J Sampling Definition I.A.W. 17025 - Does sampling apply to calibration laboratories? ISO 17025 related Discussions 8
C External calibration provider does not issue uncertainty of measurement Measurement Uncertainty (MU) 2
D Calibration labels - Does all measuring equipment require a label to indicate status? General Measurement Device and Calibration Topics 8
B Calibration Certificates - Does 17025 require that all 'As Found' data be recorded? ISO 17025 related Discussions 7
V Does an internal calibration laboratory need to be certified on ISO 17025? ISO 17025 related Discussions 3
B Calibration of CNC Machines - Does anyone have written documentation procedures? General Measurement Device and Calibration Topics 2
M Theodolite Calibration - Does anyone know what to do about the ingar bars? QS-9000 - American Automotive Manufacturers Standard 2
B Does FDA Registration QSR need to cover non-medical devices for contract repackager? US Food and Drug Administration (FDA) 0
0 To which part of 13485 does this refer? ISO 13485:2016 - Medical Device Quality Management Systems 3
lanley liao Does the customer`s trademark belong to customer-supplied property? Oil and Gas Industry Standards and Regulations 2
H How does a gas turbine work on diesel fuel? Oil and Gas Industry Standards and Regulations 12
G What does performance specification include? US Food and Drug Administration (FDA) 1
W Where does a coatings and paint company fall in IATF? IATF 16949 - Automotive Quality Systems Standard 5
C Does an accessory need an IFU if it use is discussed in the Parent device IFU? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 5
S How long does it take to register a product with MHRA? UK Medical Device Regulations 3
M Quality Manual - Where does Revision History Section go? Document Control Systems, Procedures, Forms and Templates 8
A Brexit When does the UK responsible person need to be in place? UK Medical Device Regulations 10
N Does anyone have experience of GB/T 34986-2017? China Medical Device Regulations 1
Z Does anyone have experience with EN ISO 17664 ? IEC 62366 - Medical Device Usability Engineering 9
F Does anyone have an ESD quality/cooler talk to share? Training - Internal, External, Online and Distance Learning 4
A What does this line from MDCG 2020-3 (MDR art. 120 substantial change) mean to you? EU Medical Device Regulations 4
T What does AS9100 mean when it says you must establish a process to do X? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 24
L Does a backdate form format can be changed if wrong revision is used? Document Control Systems, Procedures, Forms and Templates 8
B General Motors and Honda Alliance - What does this mean to suppliers? IATF 16949 - Automotive Quality Systems Standard 3
C ISO 13485 :2016 - CAPA - Does every CAPA need to be checked by regulations? ISO 13485:2016 - Medical Device Quality Management Systems 9
